[APP][Pro] Gecko InTouch - Control your Gecko spa or hot tub with InTouch2 or InTouch3
Hi everyone,
I’ve released a major update to the Gecko InTouch app for Homey, adding support for both Gecko InTouch 2 and Gecko InTouch 3.
Gecko InTouch 2 is paired locally by entering the spa’s IP and MAC address. Gecko InTouch 3 is paired by signing in with your Gecko username and password.
Because of the new version and the expanded device model, users with existing flows need to update their triggers, actions, and conditions so that they use the latest Flow cards. This also applies if your existing flows worked correctly with the previous version.
If you notice anything that does not work as expected, I would appreciate it if you let me know. Your feedback helps improve the app’s stability and functionality for everyone.
If you appreciate the work that goes into this app and would like to support its continued development, donations are welcome. There is absolutely no obligation, but any support is sincerely appreciated.
Thank you for using Gecko InTouch for Homey, and thanks to everyone who has tested the app and shared feedback.
Kind regards,
Thomas Svedin
Thomas,
Thank you very very much! I have been waiting for this, for several years and now FINALLY I can ditch that horrible and slow Gecko-app! :sweat_smile:
Thank you so much for your kind words Haakon :norway: ! I’m really glad to hear that the app is useful to you and that it can replace Gecko app for you. Your feedback truly means a lot and makes all the work worthwhile :smiley: .
Much appreciated that you are fixing this, Thomas.
Gecko’s app is really bad. I have installed your app with IP/MAC but can’t get it to connect. Any tips?
Hi Kjell-Arne,
Sorry to hear that you having issues with connection of the intouch2.
Could yo please double check the IP and MAC address in advanced settings, in the device settings?
Thomas, it was all my pleasure! :blush:
Now that we know that the basics are working very well, are you planning to keep on developing the support? For instance; controlling the pumps (on/off/speed)?
(An idea I got just now: Our spa bath is located inside a closed and locked pavilion. I can ad a motion/presence sensor inside the pavilion, which turns on the lights first, then the pumps after maybe 1/2 mins. And then keeping the pumps running, while occupants are present. Turning off pump no. 2 after 3 mins. with no occupants and pump no. 1 set to minimum for 10 mins. and then off. Lights go off, last).
“really bad” is the understatement of the year! :joy:
Mine connected on first try and very quickly. Surprisingly quick actually, with the slow In.touch-app in mind. :sweat_smile: Double-check your IP and MAC, is my hot tip. Also, can your VPN (if you have one) be playing tricks on you? I have experienced that with some wireless gadgets. Not with this app though.
I have a TP-Link router WR802N in client mode connected to the InTouch2 module, and this is the device that connects to my network. If I understand it correctly, it is this device’s IP and MAC address that I see on the network. This is probably why it doesn’t work. Any thoughts?
Hi again,
I’ve been trying to find a solution for turning the light on and off via intouch2, but I haven’t managed to get it working. I don’t know exactly how your light works. My spa has about 10–15 different light modes that I can cycle through. Between each press, the light turns off, and with the next press it turns on again in a different mode.
When it comes to the pump or pumps, I will look into that, but I’m unsure since my spa only has a single pump. Therefore, my attempt at an implementation may not fully guarantee that it works as intended for everyone.
You should put it in Range extender operation mode, then both the router and the device show up in your network. Client mode is only Wireless WAN as far as I know, so in this mode the router still creates its own subnet.
You can rename the extended SSID to something else to prevent your other devices from connecting to it.
Thanks Sven, I will give it a try.
“Range extender mode” is only an extension of an existing network, and I already have good Wi-Fi coverage at the jacuzzi.
”Client mode” works and I can see the InTouch2 in my network, but even though I enter the correct MAC and IP address, it does not connect.
Hello
I wonder if in.touch3 will work with this app? :slight_smile:
Be Thomas
Unfortunately, I don’t have any information about whether in.touch3 is compatible with the app I’ve developed.
Best,
Thomas
Hej !
jag får den inte att fungera med Gecko 3.
homeyn hittar den och lägger till den men anslutningen fungerar ej.
har kollat ip och mac ett flertal ggr men icke.
Hej,
Tyvärr så stödjer appen enbart Gecko InTouch 2 i nuläget. I och med att jag inte har tillgång till Gecko InTouch 3 kan jag tyvärr inte lägga till stöd.
Hälsningar Thomas Svedin
Hello, I installed this app. Finding and connecting from Homey went without a problem.
But then it give constant "connection failled.
Some times from the app on my phone I can see the temperature set and the actual temp, but the actual temp is not correct. Removed end reinstalled the app on Homey. First connection goes ok and then the same problem …
Any suggestion ?
Dirk Houtmeyers
Hello Dirk, unfortunately, this is not something I am aware of. I have now performed some tests to check whether the app is still functioning. I have not found or noticed anything that appears to be wrong.
Are you using Gecko intouch 2? Is everything functioning properly with the original app?
BR
Thomas
@ThomasSwedin
Hi Thomas,
I’m using your Gecko InTouch2 app v1.4.0 with a Homey Pro Early 2023.
My spa is:
  • Gecko in.YE-3-H3.0
  • in.touch EN 88 v15.0
  • in.touch CO 89 v11.0
  • inYT 373 v4.0
Reading works perfectly. Current temperature, target temperature and water care mode update automatically in Homey.
However, every write operation fails immediately with:
Missing Capability Listener: target_temperature
and
Missing Capability Listener: heater_mode
The same happens from Homey Developer Tools when using “Set Value”.
I have removed the device, uninstalled and reinstalled the app, rebooted Homey and added the device again. No change.
Could this be a compatibility issue with my Gecko firmware? I’d be happy to help test or provide more information if needed.
mvh Tomas Järlstig Sweden
A quick update for those who have been asking about in.touch 3 support: it is now available in the beta version of the Gecko InTouch app for Homey.
The app now supports both in.touch 2 and in.touch 3. Gecko in.touch 2 uses local pairing with IP and MAC address, while Gecko in.touch 3 requires sign-in with your Gecko username and password during pairing.
Please note that this is currently a beta release. For now, the app may still appear in Homey as Gecko InTouch2. Once beta testing is complete and the app is ready for full release, I will rename it to Gecko InTouch to reflect support for both in.touch 2 and in.touch 3.
If you have an in.touch 3 system and would like to test the beta, your feedback is very welcome. It will help improve stability and make the app better for everyone.
/Thomas Svedin
