Just started using Homey Flow and Advanced Flows.
Trying to get Homey to reset zwave energy meters to zero at midnight and I keep getting flowcard_not_registered error.
Any ideas what that means and how to fix this error?
Thanks
Thanks
It is a bit of guessing if you don’t share the flow right away. Thanks ![]()
Maybe it is a syntax error, or something in the zwave app’s code.
Aha, I suspect it is in the App code.
I’ll just send a zwave string to do an energy reset.
I thought the error was something more fundamental, you have tweak the bidet before you use a flow type of thing.
No problem workaround exists.
