I have already asked about this on Slack, but unfortunately never received an answer.
In my opinion this is an absolut no-go to publish such information without a release date.
For some reason (only Athom knows) it’s not being populated.
That’s why I’m using on Firefox add-on called Distill Web Monitor- https://distill.io/ - it’s not a solution but it’s quite useful workaround and you can see also dates when page changed (when update has been detected), when using Cloud version, you can get notified/change tracked when the page get’s updated.
In some posts I mention that function x was added in firmware version x, or problem y was fixed in firmware version y. However, currently it’s not possible to check when this firmware was released.
Athom recommends activating automatic firmware updates. If timeline and push notifications are deactivated, the user will not know at all when a new firmware was installed. If suddenly problems occur then the user has at least a chance to check when the last firmware was released and automatically installed.
Actually they have absolutely no (official) way to check when a new firmware was released and automatically installed. A day ago, a week ago, a month ago…?
Homeys Uptime: Some users let their Homey restarted automatically every day, so that’s not a valid contra argument…
Btw, to mention the release date is generally good practice.
Geurt, do you happen to know why release dates are published along with app updates?
I mean if certain people think it’s not important for firmware, why would it be for apps
No idea, they are as useless as the releasedate for Firmware for me.
The only thing I want to know if I am at the latest FW / version or not.
and we can’t wait fe until it is at least 2 months out. It could be that you never get to that point as there is a new update before that already.
The only thing I further want to know when I installed it.
For me such info is also useful, mostly when I get some reports and from some proactive users I got also information like mentioned by DirK - eg. “I believe it starts misbehaving 1 week ago, last update etc.” Sometimes it helps myself to narrow down the changes, sometimes it helps me to say to the user to check the dates, because I did not touch the apps at all and provide proof (so it indicates problem somewhere else then apps I maintain)
Btw,
(that’s Athom dev so can be stated as Athom statement)
Frankly, I don’t know why it’s so complicated but it’s probably indication that it’s not the priority at all.
As an app developer, I think release dates would be especially useful when debugging issues.
When a user reports that something suddenly stopped working, one of the first things I want to check is whether their Homey firmware changed around the same time. Without the release date, it is often difficult to establish that timeline.
This is also useful when multiple users report the same issue. If they all started seeing it after the same firmware release, that gives a pretty strong clue that something may have changed on the Homey side rather than in the app.
It doesn’t need to be anything complicated — even just:
I asked Athom on Slack whether they could add the release dates to their change log pages. They have added them in several of the logs. Some logs take some more time.
