Device settings validation
Only example I can find, in the SDK description, regarding using pattern for validation of device settings is [a-zA-Z].
Has anyone managed to find a pattern for validation of for instance an ip address? Normal regex doesn’t seems to work.
I’m fairly sure that it will use input[pattern], so a valid JS regexp should work, but there may be some challenges regarding proper escaping.
What’s the “normal regex” that you tried?
@robertklep, Thanks for your reply.
After some more testing I actually, with correct escaping, got it to work.
IP address validation:
"pattern": "^(?!0)(?!.*\\.$)((1?\\d?\\d|25[0-5]|2[0-4]\\d)(\\.|$)){4}$"
But unfortunately, no error message is displayed if validation fails, so for a better UX-experience it’s probably better to do the validation in onSettings() instead:
 onSettings(event) {
    // Validate
    const regExIp = new RegExp('^(?!0)(?!.*\\.$)((1?\\d?\\d|25[0-5]|2[0-4]\\d)(\\.|$)){4}$');
    if (!regExIp.test(event.newSettings['host'])) throw new Error('Invalid IP adress!');
