Dashboard links are reordered cause active link is hidden
When a dashboardpage is getting active, the shortcut to this page is hidden between the dashboard shortcuts.
This is pretty annoying because this causes all links will be re-ordered. So sometimes the same link is on the right side, other times on the left side. This could be easily solved if the active shortcut is placed, but grayed out.
It is better to have the links sitting in the same spot so you know where to look for it.
