Anyone know if there’s a way to create some sort of weather station using cheap(er) devices? I have sensors monitoring temperature, pressure and humidity. This should be more than enough to create the same logic as in cheaper weather stations - but requires logging and comparing live values to historical ones. I tried looking in the app store, but could only find apps that work with “proper weather stations”.
You can create an Advanced Virtual Device from the Device Capabilities app.
With that you can combine all wanted sensor-input on one device and turn on insights for any field that you like.
You would than have just one device reflecting all weather data you want.
Edit:
Alao, the DC app has multiple flowcards to get historicle data or watch specific data/values.
Like the Get Insights flowcard, or the When x has been higher/lower than x for x time.
Thanks. I’ll look into that ![]()
