Hey,
i try this Part, but always get an error
Array
[error] => Missing Session ID in Token
[error_description] => Missing Session ID in Token
[stack] => Error: Missing Session ID in Token
at ManagerApi.getSession (file:///node_modules/@athombv/homey-core/dist/lib/ManagerApi.mjs:41:19)
at ManagerApi.onRequest (file:///node_modules/@athombv/homey-core/dist/lib/ManagerApi.mjs:177:38)
at file:///app/lib/Server.mjs:614:43
at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
[statusCode] => 401
[statusName] => HomeyErrorUnauthorized
My php code:
$curl = curl_init();
curl_setopt_array($curl, array(
CURLOPT_URL => 'https://abcdef...xyz.homey.athom-prod-euwest1-001.homeypro.net/api/manager/users/login',
CURLOPT_RETURNTRANSFER => true,
CURLOPT_ENCODING => '',
CURLOPT_MAXREDIRS => 10,
CURLOPT_TIMEOUT => 0,
CURLOPT_FOLLOWLOCATION => true,
CURLOPT_HTTP_VERSION => CURL_HTTP_VERSION_1_1,
CURLOPT_CUSTOMREQUEST => 'POST',
CURLOPT_POSTFIELDS => http_build_query(array('token' => $delegation_token)),
CURLOPT_HTTPHEADER => array('content-type: application/json', 'Authorization: Bearer ' . $access_token),
$response = curl_exec($curl);
curl_close($curl);
print_r(json_decode($response, true));
