I want to connect my Homey to my Openclaw via Cloud due to different locations. Therefore I want to use a homey cli skill for openclaw. Giving my agent the PAT it is able to connect to the cloud but it doesn’t see any homey devices it also sees my mail adress for example - any ideas?
Because the PAT can only be used to publish apps with. You need to ask your agent to run homey login and give you the URL, after which you should log in and give your agent the code back. Then it stays logged in
Can you remote access the PC where it’s running on? Or maybe ask the agent to install rustdesk or something? Then you can just do it manually with homey login
