I want to make a link from home assistant with my Somfy TaHome switch (central hub) but that uses a pairing code that is made via Apple Home Kit.
My TaHoma switch appears to be already connected to a device, which one is unknown to me.
Does anyone know how to remove it from the TaHome Switch.
The Somfy helpdesk 0.3 €/min did not think it was their problem and that I had to connect to Homey or Apple while the pairing-code is in their device. They have full access to the TaHoma switch which is at my house because it also went wrong during the installation and the installer contacted Somfy and the problem was quickly solved.
Any tip is welcome.
Kind greetings, Frank
