Could you try to get the test version? I did a change in getting the data from the API, and I might have this resolved.
Hi sebastian,
I have just added the DK to the list, please use the test version to check this out
The next step is to implement the remote commands, but during development I accidently added to much phones which blocked my account.
I raised a ticket at Peugeot to get this resolved, until then I am stuck in development with this.
If the country matters, I would like to ask you for Czech Republic. Many thanks.
Hej Martijn, Much appreciated, thank you very much.
I tried to add my car, I get successful connect, but when I add the car in homey I get the error Invalid Flow Card ID: updatevehiclestatus_MyDS.
The URL I get from developertools and added the car with started with mymdssdk:// and not my mymap://
Am I doing something wrong? Also, i noticed that when adding the car, it says DK(nb-NO) and not DK(da-DK).
Hej Martijn, i just noticed that the car was added with the correct VIN number, so im quite sure the connection is correct.
Regards, Sebastian.
Yes I made a copy past error when I wanted to change the country.
If you still have the invalid flowcard id, please remove and add the car again
cz has been added as well.
I published a new version of the app to have the latest version live
Hej Martijn, I updated the app to 1.4.0, readded my login in the configuration, and readded the car.
I stille have the same issue with the Invalid Flow Card ID: updatevehiclestatus_MyDS error.
Is there any information i can provide you that could help sovle this issue?
Regards, Heien.
Ah, found it! (Als for citroen)
I have pushed it to test
Stellantis Vehicles | Homey
Lets see if you just have to update the app, I believe no new device is needed
Is this still the case?
The data is refreshed every 15 minutes in order to not stress out the stellantis api service.
You can force an update with a THEN card within a flow, to force an update.
Hey Martijn.
Yes it is still the case, i tried the following:
-Force refresh
-Delte car and configuration in app
-Reconnect configuration and readd car
-Force refresh with newly added car.
It still says added 56 years ago.
Hi Martijn, many thanks. I authorize the citroen account in app setting successfully, but when adding the car, no new device is found. I had that problem also with other countries. I tried to delete and install app again. Same problem.
Hi Martijn,
Thanks for building this app! I would like to test it for my E208.
When I use the link to log in, it doesnt give me a option to go to developer mode, nor give me an error. The only option is to click on continue and then it tries to open the Peugeot app (or on desktop it does nothing)
Any suggestions?
Thanks!
You have to open de developer tools of your browser.
Please use a pc to configure.
When you navigate to the page, complete your login , then open de developer tools (F12) of your browser and go to the network tab.
Refresh the page and find the suggested url.
Copy and paste with the textbox and complete the setup
The last step needs to be done quickly as the token expires rather quickly
I feel really stupid: where in the network trace overview do I find the needed URL? I see lots of items popping up after refreshing the page, but none seem to contain an item in the format your app is indicating. Perhaps you can post a screenshot.
Thanks. I initially could not find that specific entry in the network trace overview. Apparently, instead of refreshing the page, you need to click the ‘Continue’ button on the web page for it to appear.
Another question. I don’t have an electric/hybrid version (petrol only). I see the following information. It makes sense that the Charge Status and Voltage items are not available. But what about the last two items, shouldn’t that info be displayed?
The last two should be displayed, but apparently you are not getting the maintenance state of your car.
The latest renewal (laatste vernieuwing) is based on the general status of your car. Why this is not displayed I am unsure.
I will try to have some sort of opt-in possibility to share car data with me.
