Check if a logic variable is / is not NULL?
How can I check if a variable/tag is / is not NULL/empty with a logic condition card?
THX
Can it be NULL/empty??
When you create a variable you have to fill the default.
When you restart homey that value is set.
In my case a homescript returns β€˜β€™, so the tag is empty (of course I could return something else).
And yes, your answer is the reason for my question :wink:
Null is hard, but setting it to an Empty string (β€œβ€) is very easy, because an empty string validates correctly when setting capabilities or tokens.
Answer:
  • Create a text variable (set it with a space).
  • run a homeyscript with return β€œβ€ (just 2 double quotes)
  • place the HS token in the variable.
Now you have an Empty text variable which you can use to see if a text-token or whatever is also empty.
As far as i know there is no way to set a capability/token-value to null.
You and @FKey are right.
It is even not possible to return null in a token with homeyscript or use it as a variable value out of the box.
Your advise works fine. And with the new inline homescripit it is not even necessary to use a global variable. Just for fun:
THX
Indeed, the global variable is handy tho, if you check it much: you just reference the existing gloval variable called Empty :wink:
Saves flowcards :wink:
Also, reading Result equals Empty is imho somewhat nicer then Result equals Result.
I agree!
Nice weekend
