Button + (Release 0.7.25, Test 0.7.26)
Hej @Adrian_Rockall , many thanks for setting up this app. While all the Button+ stuff is still in “beta” in combination with your app it can be already quite useful.
I’m wondering if I’m doing this in the right way.
Here in Sweden we have our car equipped with an electrical car heater. In combination with the Calendar app and a Neo plug we will have it switched on when necessary. Because the garage is quite far (on the edge of Z-wave network) sometimes the signal isn’t working. So the Neo plug is reporting the wattage, and when higher then I know the car is plugged in and heated.
I’ve assigned one button for this and is working quite fine, however when I want to show the used wattage it is only in the Title label possible and not in the label it self. Is that right?
I’m using this card to get the variable in the title:
Downside is that the variable doesn´t seems to get update probably it is just a momentary value on the time the label is created, which makes sense, no mqtt involved in this.
I also prefer to keep the title the title and have the label updated.
Is this anyway even possible of am I thinking the wrong way?
