I have a boiler I want to heat when the price is low using Frank Energie
I made two flows but can’t get the “on flow” to work, the “off flow” is working fine.
See the pictures.
Why isn’t the “on flow” working?
Thanks in advance,
Allard
I think you must start with a row “If Stroomprijs changed”
And then the with your %
Else it only works on the moment that the moment that the "Stroomprijs"is 33.00% / 42% lower
All so Maybetter to build this in a avanced flow (if you have it)
Thanks for the hint
In mean I did try but it is still not working
I try to switch the boiler on when it reach 45% below the daggemiddelde and want to go off when it reach 35 % below the “daggemiddelde”.
There is NO possibility to Switch off the boiler when the the % is going up and goes to 35 below the daggemiddelde.
To use “switch of when 35% higher then the daggemiddelde is no option, that’s much too high.
Any suggestions?
Regards
Allard
