True false, also a good tip, but in my use case Id like to run one of 8 different “scene” flows for a room.
My attempt did work well the first time, but then I suddenly was not able to set a tag anymore. I did a restart. And now I run into the same problem described here:
The specific error I get is:
Cannot set value, token is not registered
Have you been using await setTagValue, and have you had trouble with it?
