Best TRV / Radiator valves?
Hello, Homey pro user here (2023). I have a Nest Thermostat at home and would like to add some connected valves to have “zones” to heat intelligently during the day (work from home etc.).
What are the best options? The Tado ones seem good but I’d like to avoid adding additional hubs (which is required for Tado unless I misunderstood)
Bonjour, si vous ne voulez pas installer de hub supplementaire, il faut installer des vannes TRV zwave ou zigbee, qui puissent etre pilotée par homey directement.
If you could please keep the conversation in English as much as possible, then more people will be able to participate. If you would rather not or can’t communicate in English then please check out Non-English boards/categories:
Français (French)
English is fine yeah. Will get more answers :slight_smile:
