I have a
Homey Pro 2023
ZooZ Zen 72 Z wave switch
BFT LM052 Zigbee 5in1 controller
RGBW 24V LED recess can
Is it possible to assign the dim value of the switch to the dim value of the controller?
I have a
Homey Pro 2023
Not to be silly, but because you are the only one with this combination of equipment, only you can answer this question with a full-fedged “yes”.
So start with a flow that reads the dim value and a flow that sets the dim value. If that doesn’t work with app flow cards, it should work with Logic flow cards and tags. Then you combine those flows.
Thank you. I used device capabilities to obtain the dim value from the switch and then a flow card to set dim value.
