I don’t mind sharing the entire ino file.
#include <Wire.h>
#include <BH1750.h> // Lightsensor
#include <ESP8266WiFi.h>
#include <PubSubClient.h> //https://github.com/knolleary/pubsubclient
#define ledPin D7 // Green LED
#define pirPin D1 // Input for PIR HC-SR501
BH1750 lightMeter(0x23);
int state = LOW; // by default, no motion detected
int pirPinValue; // variable to store read PIR Value
unsigned long previousLuminosity = 0;
unsigned long previousMillis = 0;
const unsigned long ldrInterval = 2 * 60 * 1000; //default interval for lightsensor in milliseconds
String clientId = "ESP_" + String(ESP.getChipId(), HEX);
char *ssid = "ssid";
char *password = "password";
const char *mqttServer = "192.168.1.61";
const int mqttPort = 8883;
const char *mqttUser = "test";
const char *mqttPassword = "uno";
const char *motion_topic = "home/hallway/pir/motion";
const char *luminance_topic = "home/hallway/pir/luminance";
//WiFiClientSecure is required if you are using mqtts usually port 8883
WiFiClientSecure espClient;
// If you are using port 1883 without a certificatie then use WiFiClient instead
PubSubClient client(espClient);
void setup()
Serial.begin(115200);
pinMode(ledPin, OUTPUT);
pinMode(pirPin, INPUT);
digitalWrite(ledPin, LOW); // led off
// Initialize the I2C bus (BH1750 library doesn't do this automatically)
Wire.begin(D3, D4);
// On esp8266 you can select SCL and SDA pins using Wire.begin(D4, D3);
// begin returns a boolean that can be used to detect setup problems.
if (lightMeter.begin(BH1750::CONTINUOUS_HIGH_RES_MODE)) {
Serial.println(F("BH1750 Advanced begin"));
else {
Serial.println(F("Error initialising BH1750"));
previousMillis = ldrInterval;
randomSeed(analogRead(A0));
void loop()
//always running no delay
lightDetection(false);
motionDetection();
void lightDetection(bool immediate)
if (immediate || previousMillis == 0 || readLight())
float lux = lightMeter.readLightLevel();
Serial.print("Luminosity "); Serial.println(lux);
wifiConnect();
client.publish(luminance_topic, String(lux).c_str(), true);
bool readLight()
unsigned long currentMillis = millis();
if (currentMillis - previousMillis > ldrInterval)
previousMillis = currentMillis;
return true;
else
return false;
void motionDetection()
pirPinValue = digitalRead(pirPin);
if (pirPinValue == HIGH)
digitalWrite(ledPin, HIGH); // turn LED ON
delay(100); // delay 100 milliseconds
if (state == LOW)
Serial.println("Motion detected!");
state = HIGH;
lightDetection(true); // before setting motion alarm, send lightsensor value first
delay(50);
setMotionAlarm(true);
else
digitalWrite(ledPin, LOW); // turn LED OFF
delay(200); // delay 200 milliseconds
if (state == HIGH)
Serial.println("Motion stopped!");
state = LOW;
setMotionAlarm(false);
void setMotionAlarm(bool motionDetected) {
wifiConnect();
Serial.print("Publish "); sprintf(motion_topic, motionDetected ? "true": "false");
client.publish(motion_topic, motionDetected ? "true": "false", true); // by sending true and false as text, Homey automagically converts those to actual booleans
void wifiConnect()
if (WiFi.status() != WL_CONNECTED)
Serial.print("Not connected to wifi, connecting now");
WiFi.mode(WIFI_STA); // Static
WiFi.hostname("Navnet PIR");
//Connect to network
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED)
delay(500);
Serial.print(".");
//Print IP address
Serial.print("Connected to IP address: ");
Serial.print("Ip: "); Serial.print(WiFi.localIP());
Serial.println("\tMAC: "); Serial.println(WiFi.macAddress());
if (!client.connected()) {
client.setServer(mqttServer, mqttPort);
Serial.print("Connecting to MQTT server "); Serial.print(mqttServer);
while (!client.connected()) {
if (client.connect(clientId.c_str(), mqttUser, mqttPassword ))
Serial.println("\tconnected");
} else {
delay(500);
Serial.print(".");
More info on the Homey flows and MQTT Broker settings checkout this post
Good luck!
