I tested it with Aeotec Wallmote Quad and Fibaro RGBW Controller FGRGBWM-441
Using the Association you have following possibilities.
- Button 1 Association Group 3 (dimming control) -> RGBW Controller (instance 1) all Chanels together
- Button 2 Association Group 5 (dimming control) -> RGBW Controller (instance 2) R channel
- Button 3 Association Group 7 (dimming control) -> RGBW Controller (instance 3) G channel
- Button 4 Association Group 9 (dimming control) -> RGBW Controller (instance 4) B channel
- Button x Association Group x (dimming control) -> RGBW Controller (instance 5) W channel
So, you can control all channel together or each channel separately.
Press the Button you can switch the RGBW/Chanel on and off
Slide down -> decrease the dimm level
Slide up -> increase the dimm level
Alternativ to the Wallmote you can also use the Philio Smart Color Button. (only 1 Button)
