[APP][Pro] XPENG Car Manager for Homey
there is now 9 sets free so go in quick as i will not go for the paid version as this is way to expensive
Wouldnt it be possible to adress a second different (free) enode account?
Unfortunately I cannot register yet although I have an Xpeng Account as my xpeng g9 will only be delivered in November…
Mulig å øke hvor ofte den oppdaterer bilens posisjon?
Ønsker den skal trigge garasjen til å åpne seg når den nærmer seg., men 10m er ganske mye for det.
Thanks for building and maintaining this app — really appreciate having XPENG integration in Homey at all.
I’m new to the app, so take this as a fresh-eyes observation rather than a complaint: I noticed pluggedInStatus/chargingStatus can lag real events by hours (mine sat frozen ~2 hours despite a 10-min poll interval and me actively using the official XPENG app in that window, including opening the charge port) — while range, location, and battery on the same device kept updating normally in that same period (minutes-old, not hours). So it looks like a per-field issue upstream (Enode/XPENG API) rather than the whole feed being stuck — matches what others reported here too, and your reply that it’s not fixable app-side makes sense given that.
One workaround for anyone hitting the same thing: if you also have a smart charger reporting a cable-connected/charging status of its own, or you’re OK using GPS proximity-to-home as a signal, either is a much faster/more reliable “car is home and plugged in” indicator than waiting on this app’s pluggedInStatus alone. That’s what I ended up using as a fallback for my own automations.
Thanks again for the work on this!
@Kjetil_Vert Is chargingLimit read-only because Enode’s API doesn’t support setting it, or is the write listener just not implemented yet — any chance of adding SET support (e.g. via a flow action)?
My friend has Xpeng G9 and he’s getting this “Problem generating link: Something went wrong. Please try again later. If the problem persists. Please check your vehicle status or restart the app.” error when trying to add it as a device? Can you fix it?
6ed41fd2-3e71-4eaa-ac5e-779deb7e771c
I had to reinstall my Xpeng Car Manager-app in Homey. And when trying to re-add my car, I get the same problem as described above with generation of connection link..
Do you know what could be causing this @Kjetil_Vert?
Sorry, but this app simply doesn’t work. It never updates the information, so pretty useless. I get that there is a limitation on enode, but in the end that still just renders the app useless. The reason behind it is irrelevant.
Updates have been working perfect for me, I have been using this app for about 1,5 year and I always get SoC and GPS updates etc. However, now I cant re-add my vehicle after reinstalling the app in Homey.
Hi @Kjetil_Vert
can tou please check if you can create any space for new connnections?
The error comes up after disconnecting and trying to reconnect again. I assume the enode space is full?
Thanks! Marco
all seats are taken yes, I clean like ones every mont so if there is free seats they will coma back but do not count on this
Can I ask again if it would be possible to use a second free account that enables another 125 users?
Hello Kjetil. I noticed a update of the app and once again tried to re-add my car, now I get different failure message than before - see below. Is this just another way to inform that there are no free seats?
Today the data of my car is not updated anymore in the Homey app. Even when I try to force it with a Refresh Vehicle Data workflow card it keeps showing old data.
Does this have anything to do with the 1.3.1 update that was installed last night?
When trying to repair the device, I get the following error:
I have now the same issue, last update was 7 hours ago :frowning:
I experience the same.
Hi @Kjetil_Vert,
I’m trying to connect my XPENG to Homey, but generating the connection link fails with:
“Problem generating link: You don’t have permission to perform this action. Please check your access rights and try again.”
The app shows “Enode API credentials are configured and ready to use”, so it looks like Enode is refusing the request rather than a local issue. Before the latest update I got “Account Full”, and after the update a 30000 ms timeout. Now it’s this permission error.
Diagnostic report: d4325eb2-cf48-4767-b553-e24df64728e5
Is the Enode account full again, or has Enode restricted access? Happy to test a new version if that helps. Also willing to pay for a premium app if that helps you maintaining the enode.
Thanks for maintaining the app!
To all new version is in test and soon will be ready for all with 166 new car slots Thanks to @Jens_Edberg for the support that and the Enode account
Thanks, unfortunately the connection fails at the final step with the following error (after the xpeng account credentials had been successfully accepted where it should then finally connect)
It worked fine for me directly when the new slots where added. Try adding you car from the Homey web interface instead of the app (that’s how I did).
