[APP][Pro] XPENG Car Manager for Homey
Thanks. Starting the connection process via the Web interface did not work, since it says that the account is already full.
Nevertheless it seemed to have remembered my credentials from my attempts in the homey app and I could directly try and connect in the web interface without re- entering credentials and it worked to connect. Thank you! Michael
Version 1.3.10 is now in test and goes to Homey for review, so it will reach everyone soon. Test link: XPENG Car Manager | Homey
This update is all about connecting your car:
  • No more “Missing: code” page. After you log in to XPENG you used to land on {"success":false,"message":"Missing: code"}, which made it look like the connection failed (it didn’t). You now get a “Your XPENG is connected” page. Just close it and go back to Homey.
  • More reliable connection link. Generating the link no longer fails for everyone when one of the Enode accounts has a problem, and temporary errors are retried automatically. New connections also skip Enode accounts that are already full.
  • Repair works on full Enode accounts. If your car is on an Enode account that is full, Repair used to fail with “connection capacity is full” every time. It now moves your car to an account with free seats and removes the old copy afterwards, so that seat is freed. Your flows and history are kept.
  • Simpler pairing screen with the buttons at the top. A car that is already in Homey is no longer offered again; use Repair on the device instead.
  • Repair works right away. After a repair the car starts updating immediately instead of waiting up to an hour.
  • Easier on the 12V battery. An unplugged, parked car is woken less often. While the car is plugged in nothing changes, so charging flows (“charging started”, charge status, start/stop charging) are just as quick as before. The moment you plug in an unplugged car can occasionally take a bit longer to show up; the “Refresh vehicle data” card always gets fresh data if a flow needs it right away.
If you had trouble connecting or repairing before, please try again with the test version and let me know how it goes here.
Awesome @Kjetil_Vert, thanks a lot for you lr work and efforts.
Tried the new test link to connect my G6, but got immediately this message are alle the extra seats already taken or is it due to the update?
@Marco_Holthof I looked into your screenshot again, and you found a real bug, not just an old version. Your car is no longer connected in Enode, and Repair kept trying to reconnect it through the old Enode account it was on, which is full. Repair never tried an account with free seats.
That is fixed in version 1.3.9, which will be on the test link shortly: XPENG Car Manager | Homey
Once you have 1.3.9, open your G6 device and use Repair again. It now picks an Enode account with room, and your flows and history are kept.
If you can’t wait: deleting the car in Homey and adding it again also works, but then you lose its flows.
Hey @Kjetil_Vert
Thanks for looking into it and the fix you made on this short notice!
I downloaded the test 1.3.9 and tried to connect again via the repair button. At this moment I see the same error text when trying. No successful test later still the error text below.
If I need to test something else let me know! Happy to help.
See screenshot of 6:15CET.
@Marco_Holthof Thanks for testing so quickly, that helped a lot. You were right that it still didn’t work, and I found the real cause: when an Enode account is full, Enode refuses every new connection on it, even for a car that is already on that account. Your car is on one of the full accounts, so Repair could never get a link.
Version 1.3.10 fixes this and is on the test link now: XPENG Car Manager | Homey
Install it, open your G6 device and use Repair again. The app now moves your car to an Enode account with free seats, and afterwards removes the old copy so that seat is freed for someone else. Your flows and history are kept.
Please let me know if it works this time!
Hi @Kjetil_Vert
Tested and it was successful.
My Xpeng is now connected again via the repair connection.
Thanks for your support. Great work!
I noticed that battery SoC doesn’t update, anyone else seeing this? The “Last seen” gets updated all the time, but not the SoC.
This is actual SoC from the official Xpeng-widget.
I experience the same @Jens_Edberg using test version 1.3.10.
The vehicle date/time stamp is updated every 10 minutes, but most other cards are more than 14 hours ago last updated and some are not updated after my reconnection with 3 days ago (charging limit, car brand etc)
Exactly the same here. I also use the test version 1.3.10.
Seems like it is a conflict having two services connected to the car via enode. I have the car in homey and in tibber. Connecting trough homey makes tibber loose it’s connection. While reconnecting in tibber, makes the car stop updating in homey.
I also noticed this and have reported it to Kjetil. I have now removed my Tibber connection (using a “offline” car instead), since my Homey connection is more important to me.
Hi @Blacksmit
That is normal behavior for enode. It can only have 1 connection at the time with you Xpeng. it is or tibber or Homey. I expierenced the same and once you connect another the enode is only connecting to the car via that one. So you have to choose :wink:
Regarding the issue that SoC doesn’t update, even if the connection to the car updates every 10min, it seems that SoC (and other data) updates first when the car is started and used. But when car is parked for example three days without being used and SoC decreases 1-2%, it doesnt update in Homey.
Hi @Kjetil_Vert, I have a 2026 XPENG G6 Performance (AWD). The Homey app is showing a battery capacity of 67.8 kWh (which is the Standard Range version), but my car has the larger 80.8 kWh net battery. Could you ask Enode to fix the profile mapping for my vehicle? The start of my VIN is L1NA7TD…"
Hi @Kjetil_Vert thanks for the app, it works well.
I’m moving my house from a Homey Pro 2023 to a Homey Self-Hosted Server (SHS). Can I move my car (XPENG G6) to the new Homey without losing my seat?
For example, does removing the car from the Pro 2023 free its seat so I can add it on the SHS, or is there a safer way (Repair, or you moving it)?
Also, is the app meant to run on a Self-Hosted Server? On 2 Nov the Enode link screen on the SHS did not continue, maybe because the account was full at the time.
I really have any good answers for this as not something I have tested or looked into.
thanks for your quick response, are there free slots?
