[APP][Pro] XPENG Car Manager for Homey
Did you get any news for those who can’t add a new xpeng vehicule?
New G6 user here, also can’t connect.
After installing abrp en linked AbRP via enode, i’m not able to connect to the xpeng. I wanted to reinstall xpeng car manager but i get the following error (see screenshot). Even trying after several times over the last 3 days.
Any idea’s to solve this issue? Nn
Same here step 1 generating link is failing
Same here with the first step of creating the connection link. New G6-my2025
Diagnostic report:dd31ba56-0af1-4d97-a7b5-58837cf94b88
Same here while trying to connect a new car :cry: Any suggestions?
Hi all, same on my side. As anyone found a solution to it ? is there any support possible ?
Thanks and Happy New Year to everyone !
Also here the same problem with not being able to generate a connection link, am getting the same connection error. Any idea of the time frame when this can be resolved?
i also have the that problem with the link
[APP] XPENG - Version Update: More Cars & Easier Maintenance
Hi everyone,
I’ve just released a new update for the XPENG app that makes connecting and managing your cars much more reliable.
What’s New:
  1. Capacity Boost We have increased the enode capacity. This should solve the “Account Full” errors many of you were seeing.
  2. The “Repair” Button If your car stops updating or shows a connection error, you no longer need to delete it.
    • Simply go to the car’s Settings in Homey.
    • Click Repair.
    • Log in again to re-link your car. Your flows and history will stay exactly as they were!
Note: If your car is currently showing a manual error, please use the new Repair feature once to get it back online.
Happy driving!
Works! Thank you very much! This is realy :+1:
Many thanks to @Kjetil_Vert:After installing the last update (v1.2.60) I managed to connect my Xpeng G9 :partying_face:
However, when trying to create an advanced flow to charge the car during the cheapest hours, the card ‘Predict charging time’ stops with the following error: Invalid Token: charging_time_minutes
Does anyone have a solution to get the estimated charging time to create such a flow?
Great work Kjetil! You are really appreciated.
Any posibility to get MG ismart added to this app?
I still cannot see the “Repair” option in settings, can anyone post a screenshot of it please?
Hi, i get my G6 in, but no update. I set the update time to 10min, but the SOC didn´t update since 3hrs.
i charged the car and it shows same soc as before.
After restart it loads all new.
That is not my system some time the xpeng or the api don’t send updates as fast as it is set but nothing I can fix.
Is it by design that with every update you need to re-add the vehicle and need to recreate all items in all flows ?
Not att all. The latest releases was that you needed to refresh the car but for me I did not need to do new flows for this.
So no this is not by design
With the latest update i needed to re-add everything. now the car is offline again. When refreshing car status i get the error : data refresh : your account credentials neet be updated. please reconnect your enode account in the settings. i also do not see any repair button
I had the same issue, and I also cannot find a repair option. The only solution I found was adding the car again and replacing all flow cards :cry:
Hopefully, this doesn’t happen too often
