[APP][Pro] XPENG Car Manager for Homey
I have now released a new Updated version that solve this.
there was a change in the Enode API.
It works fine now, thanks!!
Same here, it now works! Thanks for the effort!
Hey guys. Trying to connect to my G6. All goes well with the connection, till the last step. Error message: {“success” : false, “message” : “Missing: code”}….. Any idea what this can be?
Are you on the latest version?
Yes, version 1.2.54. Removed an reinstalled, same issue still…
Can you give me a diagnostic report from the app?
Hi Kjetil, the diagnostic code: 73a71bf3-762a-4b79-8fd5-ed759f2f1d4c
Hi Kjetil, despite the error message, I now could add the G6 as a device. So problem solved for me. Thanks.
Hi all, I have a problem when adding my car to Homey.
The problem is not related to the Xpeng Car Manager.
It’s related to the user login on the Xpeng site when adding the car to homey.
When trying to log in I get an error saying “Please verify the slider verification code”
But there is no slider.
I have also tried reseting password, but same error.
Anyone else experienced this?
Solved by logging in with google.
Hi Kjetil,
Since some days the app stopped working for me (for my Toyota bZ4X). I see the correct data from the car, but when I send a “start loading” command, Homey says “Your account credentials need to be updated. Please reconnect your Enode account in the settings.”
I tried reïnstalling the app and reïnstalling the car several times.
I’m on version v1.2.55 of the app. Any idea where it goes wrong?
This is a new error and i have no info about this
You can do a error report and send to me
Hi Kjetil,
Thanks for your reply. After several tries to install the app and/or my car again the app stopped working altogether.
When I come to step 1 in the installation of my car (“Generate connection link”), after some time I get the message “Cannot connect to Enode services. Check your internet connection and try again”
So there seems to be some kind of problem with the link to Enode (maybe tried to many times in some periode of time?). So at this time I can’t send you an error report.
Met vriendelijke groet,
René
Updated version
Thanks, but now you can’t connect to another brand like Toyota. That’s a pitty…
Update: I went back to app-version 1.2.36, tweeked some lines in the code (because it would’t import batterylevel) and use my own Enode-account. And for me it works now (on a Toyota bZ4X).
Hello, i will recieve my G6 soon and i would know if it’s possible with your app to tracks charging session history to get a report each month of all charging session and kwh associated?
Thanks
As there is analytic in the app you can make this report yourself in homey.
Hello, i can’t connect my car as the first step “generate link”doesn’t work at all . Am i alone to get this issue?
report code 5c82226e-7730-414a-a594-c63f47674e95
I’m getting the same error.
