I mean - why would you want that?
What’s the use-case.
Correct. I would like to have buckets for week, month and year (hour buckets would be nice, minute buckets are not use case for me). And then separate buckets for current and previous period (eg. this month and last month). Just like in the energy tab visualisation of native Homey app.
Ok, makes sense. Will plan this for 1.2.0
Hi Thomas, I am running into a strange behavior with the Graphs widget.
I am trying to create a graph with two lines/ranges of daily water consumption. The first range represents today’s consumption, the second yesterday’s. So the capability is the same; the timeframe differs.
If I have the widget plot two separate graphs, then this works as expected (blue is today, green is yesterday):
However, if I have the widget present both ranges into one graph, then the first range (today’s consumption) seems to be duplicated:
I am unable to get yesterday’s graph to show properly.
Some related requests
. Would it be possible to:
- Have the graph show 4 lines, instead of the current max of 2?
- Add additional time ranges beyond yesterday? Like last week, last month and last year.
- Add an option through which you can configure whether the legend is shown above or below the graph?
Fixing in 1.1.2
Adding in 1.1.2
Will be an 1.2.0 thing.
In native Homey app, the cumulative energy consumption (kWh) can be seen in the power usage (W) graph when hovering the slider to the end, otherwise power usage (W) at that specific time is shown. Can that be introduced in the chart widget as well?
BTW: A look-a-like behaviour already exists in the chart widget (at least with view yesterday), but then an average value is shown when hovering to the end. Maybe that behaviour can be made configurable: average (eg. for temp. sensor) or integrated (eg. for power sensor).
1.1.2 published for test:
- Charts: today and yesterday on one chart, each by its time of day, so a day’s use compares with the day before.
- Charts and Sparklines: this and last week, month and year as time spans; this and last week (or month, or year) can share one chart.
- Charts: a Legend setting puts each chart’s name and units below it instead of above.
- Charts and Sparklines: averages, highs, lows and tapped values keep three digits (1,304 W, not 1,304.48 W).
- Keypad: Background → State colour fills the widget with the ticked button’s colour, so you can see from across the room whether the alarm is armed.
- Lights by Room: Rename tiles gives each room and each of its lights a name of your own.
You’re welcome! And BTW I’m using the same naming convention with the room in the device name. Think this is a general thing that Athom should address. Perhaps with a “short name” or something on the device.
Or they use only the last word for the short name e.g.,
“Lounge 11 Deckenspot-4” > “Deckenspot-4”
Could actually make a setting in Widgetkeeper with a few options:
What device name to show on widgets:
- Full name as in Homey
- Last word
- Last part after a seperator
- First part before a seperator
E.g. I use the form “Device name | Room name” - seperating on | and taking the first part would just leave. “Device name”.
Hmm, that might be an idea for 1.2.0
@ThomasRS When I try in ‘Other Apps’, to add MyNissan widget is not finding my car/device. Am I doing something wrong?
And when I use Charts, I cannot add BetterLogic variables, which could be very nice too ![]()
And by the way. A fantactic work you have done her. Thanks!
/PEV
PS.
I have given full permissions in the API key, but still get this ‘error’. Something I miss to do?
Hi. Thanks for the kind words! Could you elaborate how you would want to use Better Logic variables in the chart?
You’re not doing anything wrong. Widgetkeeper picks another app’s devices from that widget’s own device filter, and it looks like we read MyNissan’s filter differently from how Homey does, so your car doesn’t make the list. I’m looking into it and will fix it in an update.
The Smart Stack has to read your dashboards, and Homey only allows that with the very top Homey permission on the API Keys page. Ticking every permission below it (Devices, Flows, Moods, Variables …) isn’t enough, because Homey has no separate permission for dashboards. did you check the top-most box?
I only think, when I add a Better Logic number variable, this have already an ‘Insight’ entry, so it would be nice if this also could be included in your ‘Charts’ Widget
A work around for me is to add the Better Logic variable into a ‘Device Capabilities’ device, because from here, I can than add the device to your Charts
Is there a way to force/lock fullscreen by url? I couldnt find anything in source for it.
My use case is Fully Kiosk Browser so it automatically goes fullscreen, and its admin controlled remotely, so if there is a way to hide the fullscreen-toggle button? As there is no need to toggle out of fullscreen to edit anything.
Something like: dashboard.html#/d/3rr8zfor9nv8/fullscreen
Hi @ThomasRS,
Love the app, really nice looking widgets, great work!
I found an issue with the Cameras widget in Widgetkeeper 1.1.2: cameras from Synology Surveillance Station are missing from the device picker.
I looked into this a bit more and Synology cameras have device class sensor, while the widget’s device filter only accepts camera|doorbell. That appears to explain why they’re excluded.
I can insert their device IDs into a regular dashboard widget through the API, so Synology cameras do indeed work for your widget, but that workaround isn’t available for the personal Home screen in iOS sadly, since that dashboard is stored on the phone itself…
Could you take a look at this?
Many many thanks!
