[APP][Pro] WhatsApp - Simple. Reliable. Private
@martijnpoppen the last couple of days my ”and” card have stoped my flow from working :thinking: if I remove the ”and” card it works great. It have worked great before. Any suggestions?
/Daniel
@Daniel_Fille also these are changes from WhatsApp they are encrypting the phone numbers
Will be fixed in the new update
You can check the number which is sent probably it’s a random number you see.
It is ChatGPT I think it is always the same nr? So I can just wait for next version?
@Daniel_Fille sorry i didn’t get that, can you explain?
@martijnpoppen, I’m trying to use the ChatGPT phone number on the “and” card, which is the same as the number it has in WhatsApp. I’ve also tried the “and” card with the ”sender is”, but it doesn’t work. It only works if I remove the “and” card completely. And you mentioned something about WhatsApp encrypting the phone number? How can I see the actual numbers?
So I wonder, so the only way is to wait for your next update off the app to get it to work again? :smiley:
@Daniel_Fille use the tokens provided in the flow. It contains a senders number
If you log that to your timeline you can see it
Or wait for the update :slight_smile:
Ohh it did the trick! Thanks @martijnpoppen :folded_hands::grinning_face_with_smiling_eyes:
New app update (:orange_square: TEST: 2.0.0):
Changelog:
NEW:
1: NEW: Update whatsapp SDK to version 7.0.0.
2: MAJOR: Update app to NodeJS 22 (requires Homey v12.9.0+)
FIXES:
1: None
:collision: If you find any issues, send a diagnostic report
:warning: Note: Before sending a report make sure to reproduce the issue so the issue will be visible in the report
  1. :mobile_phone: Via Homey Mobile app:
    More - apps - WhatsApp - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
  2. :laptop: Via Homey Webapp:
    Settings wheel bottom left - Select WhatsApp - Click on send diagnostic report
You can install this version by clicking the link above and press install (do not remove the app, only press install)
:fast_reverse_button: Don’t want to be part of a test version? Install the live version → WhatsApp | Homey
Hallo Martin
I have an HP23 with version 12.10.0-rc.14, and with the test app version 2.0.0, the app keeps crashing.
50971540-3b30-43f6-9276-b2bda16cfe88
@Asterix and without the test version?
It works with this version.
@Asterix thx, then once again the SDK update is not ready :confused:
I am convinced that it will succeed :wink:
Migrated Homey to 2026 today because of memory issues and WA App which crashed often. After migrating, unfortunately WA was still unstable. After uninstalling and re-installing WA App (2.0.0), connecting Homey went fine and it seems to be running stable now :smiley:
@martijnpoppen App is chrashed for some reasen
Diagnostic report :
a6990953-52a9-41d7-a18a-014e45a185c2
@Seinuh still waiting for the SDK update. Known issue
Reinstalled it :saluting_face: let’s wait for the new sdk :folded_hands::ok_hand:
Hi, I am currently testing on Homey Self hosted Server, But I don’t seem to get messages inbound?
Outbound seems to be working ?
Hi! @Rob_Reinderink check FAQ Q1 [APP][Pro] WhatsApp - Simple. Reliable. Private - #4 by martijnpoppen
Thank you Bjorn! I’ll try this method. Just had the same issue. I’ve send a diagnostic report, 7bff70aa-db24-492c-be09-1bade74d2b6a
