@Yvo known issue, see all messages above. Working on it
Edit: see update below
Changelog:
NEW:
1: NEW: update SDKFIXES:
1: FIX: memory issue causing crashes
2: FIX: Repair
More - apps - Whatsapp - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
You can install the test version by clicking the link above and press install
Don’t want to be part of this test version? Install the live version → WhatsApp | Homey
Thank you Martijn. Just installed latest update. Unfortunately Homey keeps crashing ![]()
Maybe any issues to find here? >> b39375ca-585b-4dd2-a126-8c2f1f826cb9
@Yvo Report is completely empty
can you try again after restart?
Not sure what happened but when I wasn`t getting messages i had a look at the app, it said it wasn’t installed, so I tried re-installing from the app community apps, no dice, so I added a new device searched for whatsapp and its stuck, I cant send a report from the app as it isn’t there in homey, anyway long story short it doesnt install at least for me - Device Homey Pro
It’s so hard to explain in English. Anyway, we’ll try with Google Translate.
I’ve created flows that say the following (this one works perfectly): Send me a message as soon as the back door opens (I get a very polite WhatsApp message). Or send me hourly price information, which is also very nice and polite.
But suppose my partner asks a question via WhatsApp. The question is: Lights on?
I used to always get a prompt WhatsApp message back with a message about which lights are on. I no longer receive this information. I do this from my private WhatsApp (iPhone) and send it to my other WhatsApp number (this is the WhatsApp number for the WhatsApp Homey app). I can send whatever I want, but I don’t get a message back. He used to do this.
I can’t explain it any better.
@Kevin_Hunt already tried a homey restart?
@EdNL I Will ask the same question again…
Do you have any working flows or are All of them stuck?
I have working flows
@EdNL then the issue seems not in this app but in the way the flow is setup
Hi Martijn, I’ve fixed the issue by deleting and re-adding the device. Fortunately, there is your script for replacing the device ID in the flows’ cards.
If I reencounter the issue, I will come back to you.
Thanks,
Luca
Unfortunately I’m not able to, because of Homey crashing instantly when starting WA App…
@Yvo which app version of WA are you using?
@martijnpoppen Tried to make a new report at: 30ddc40c-3987-47e4-a6a5-75bcbb7d84cc
Also a message is shown now at the App page (see screencap)
Changelog:
NEW:
1: NoneFIXES:
1: FIX: Clear leftover memory onstartup
@Yvo my guess is is that there’s still some data leftover causing the memory to peak. Made a test version which cleans that, not sure if it’s the fix, but worth a shot. Can you install the test version? (click link above and press green button to install)
Hi @martijnpoppen I just installed the test version. Unfortunately it results almost immediately in a crash….
@Yvo really strange. You are not the only one but I can’t reproduce it unfortunately
I will look into it
I didn’t actually do anything and suddenly my flow is working again. A bit strange, but it’s fine. Thanks!
