orry, I had to be away and I wasn’t able to do the test. I just installed version 3.0.7 and when the application is supposed to give me the code to enter in the WhatsApp application, no code is displayed.
I created a diagnostic report 90bb53c0-1899-41c0-b84f-f2a1edb85965
Im experiencing the same issue as NY79 concerning the inability to add a new number and it being stuck on providing the code, please find the screenshot attached. Its stuck on this screen and doesnt give a code. I’m running the most recent test build (3.0.7)
Big stability release. Updated to the final WhatsApp SDK release candidate (rc13) — first SDK update since November, packs 6+ months of upstream work. Combined with internal fixes targeting the high-CPU and “future messages” crashes some of you have been reporting since last releases.
Changelog:
NEW: 1: NEW: WhatsApp SDK update to 7.0.0-rc13 (final release candidate) 2: MAJOR: Update app to NodeJS 22 (requires Homey v12.9.0+) 3:Memory improvements, prevent app to crash on load. Cache became to big and caused CPU/RAM issues (going back to version 1.39.2 only possible with repair) 4: Add new condition flowcard - Text Starts With …
FIXES:
1: FIX: high CPU usage and crashes caused by “future messages” pile-up 2: FIX: reconnect storms with overlapping reconnect attempts 3: FIX: device store filling up over time 4: FIX: 30 second delay on sending messages when the device was reconnecting 5: FIX: stale state surviving a logged-out / clear-session event 6: FIX: infinite query timeout causing memory growth 7: FIX: pre-key cleanup at startup could crash on installs with very large stores 8: FIX: parsing LID to phonenumber (SDK v7) (phonenumbers were encrypted this fixes it) 9: FIX: Poll card now only has 2 required items 10: FIX: Pairing issues 11: FIX: Text condition 12: FIX: reply Code token (due to LID parsing this got corrupted) 13: FIX: issue where loaded state was too old and instance tries to load 2000+ messages which are no longer relevant 14: FIX: “Waiting for this message” — when WhatsApp asks for a retry of an older message, we can now answer it instead of leaving the sender stuck 15.: FIX: pairing code not showing
If you find any issues, send a diagnostic report
Note: Before sending a report make sure to reproduce the issue so the issue will be visible in the report
Via Homey Mobile app:
More - apps - WhatsApp - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
Via Homey Webapp:
Settings wheel bottom left - Select WhatsApp - Click on send diagnostic report
You can install this version by clicking the link above and press install (do not remove the app, only press install)
Don’t want to be part of a test version? Install the live version → WhatsApp | Homey
@martijnpoppen I don’t understand why I can’t use my WhatsApp account so I tried to delete everything and deïnstalleren but no result I can’t connect my account any more. After again deleting old install I have installeren the experimental version but also here no resultaat I’m getto g the information it’s not possible to connect try a new code I did this ten times now, and I don’t know any tricks to get the result help please I really don’t know what the matter is
Hello @martijnpoppen i have trided to login with an other account the one that’s on my phone, that went well, but when I try to Connect with an account on an other phone I Goes wrong.
I’m going to try later on again because tis works now, so maby the other one will work to now.
