@Welshsmarthome please send a report for the test Version
@John_William_Brekke please explain what is not working. I can’t see your flows or use case in a report…
So the AND TEXT IS card reports wrong. Lets say the text is /m and the AND TEXT IS checks for /m it will report as NOT /m
I don’t receive the image. Worked fine for about a year, until now.
@John_William_Brekke please share your flow and a report after reproducing the issue
@John_William_Brekke will check, this have been a issue before.
Will I lose all my current flowcards when installing the test version?
@Robkrekel no you will keep it. Just click on the version number in the post I linked
It will bring you to the app page for the test version press install and it will just be a update
It looks like it’s working again on test version!
Hi!
I keep runing in to the same problem after connecting my number to the homey app.
It work fine a couple of times, then I start getting the error message “Waiting for this message. This may take a while” everytime i send a messages from Homey.
I also don’t see that Homey has read my messages when I send something to it. When sending to Homey my number doesn’t show up as “senders number” either. All of this worked fine for a long time, then something happend . about 6 months ago or so.
Diagnostic report:
9da01a97-723a-484b-a357-9550dc4bd3b9
@O3car Did you already try the test version? → [APP][Pro] WhatsApp - Simple. Reliable. Private - #2150 by martijnpoppen
Nope, I’ll check it out right away.
After further testing with the problem seems to trigger when I send messages to the Homey App.
Tried it!
Worked right away!
@O3car great!
glad to hear. I expect the test version to go live soon!
New app update (
TEST: 3.0.1):
Big stability release. Updated to the final WhatsApp SDK release candidate (rc10) — first SDK update since November, packs 5+ months of upstream work. Combined with internal fixes targeting the high-CPU and “future messages” crashes some of you have been reporting since last releases.
Changelog:
NEW:
1: NEW: WhatsApp SDK update to 7.0.0-rc10 (final release candidate)
2: MAJOR: Update app to NodeJS 22 (requires Homey v12.9.0+)
3: Memory improvements, prevent app to crash on load. Cache became to big and caused CPU/RAM issues (going back to version 1.39.2 only possible with repair)FIXES:
1: FIX: high CPU usage and crashes caused by “future messages” pile-up
2: FIX: reconnect storms with overlapping reconnect attempts
3: FIX: device store filling up over time
4: FIX: 30 second delay on sending messages when the device was reconnecting
5: FIX: stale state surviving a logged-out / clear-session event
6: FIX: infinite query timeout causing memory growth
7: FIX: pre-key cleanup at startup could crash on installs with very large stores
8: FIX: parsing LID to phonenumber (SDK v7) (phonenumbers were encrypted this fixes it)
9: FIX: Poll card now only has 2 required items
10: FIX: Pairing issues
11: FIX: Text condition
If you find any issues, send a diagnostic report
Note: Before sending a report make sure to reproduce the issue so the issue will be visible in the report
Via Homey Mobile app:
More - apps - WhatsApp - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
Via Homey Webapp:
Settings wheel bottom left - Select WhatsApp - Click on send diagnostic report
You can install this version by clicking the link above and press install (do not remove the app, only press install)
Don’t want to be part of a test version? Install the live version → https://homey.app/a/com.whatsapp/
@John_William_Brekke I made a fix and it is part of the test version (see above)
Thank you, i will check soon!
Hi, seems though like “reply codes” doesn’t work anymore.
