@martijnpoppen - Sorry only just got a chance to test beta. No errors mentioned on the homey pro however on WhatsApp I get this message now:
Ran diagnostics report: 5ffdb3d0-f45e-4069-80fc-212bc86df8ca
@Gary_Russell that’s a shame. The test version of the app still uses a beta version of the SDK so have to wait for a final version to fix it properly
Most of the time this will resolve itself, but it’s a known WhatsApp issue
@martijnpoppen understood. Thank you very much for the time you’ve spent on this so far — really appreciate it. Happy to wait for the final SDK and revisit once it’s available.
49ae7ef0-fc1d-4cdf-b5c3-bf56c7c26198
My apologies, next time I will write things in English. I see that my problem occurs more often, even after a reinstallation. Thanks for the link, I’m going to try it right away
@Lars_Berkers this is a English topic
Please edit and translate your post
Known issue, until new SDK nothing I can do. You can try the test version which runs the beta SDK: [APP][Pro] WhatsApp - Simple. Reliable. Private - #2070 by martijnpoppen
In the meantime, I’ve made a donation. Thanks for the great app!
@Lars_Berkers thank you!
important update while running the beta version, my HP23 crashed complete→ everyday ! ( red ring ) after disable the app HP23 running normal.
@Lars_Berkers known issue of the test version. As mentioned in the post of the test version it states that it runs a beta version. If it crashes it’s best to install the stable version
Thanks for the update Martijn, hopefully the new SDK will be available soon ![]()
When sending a WhatsApp message, the message arrives well on Android but on iPhone the receiver will get a message “Waiting for this message. This can take a while”
Tested several times. As the sender, on my Android phone, I can see the message that Homey has send. The receiver will get the waiting message. Consistent across a few iPhone phones. I am using the latest version of the app.
Thanks,
Christoph
@Christoph_Rooms are you using the live or the test version of the app?
The live app. Version 1.39.2
Hallo Martijn,
The app crashes every few minutes. When I restart it, it works for a while, but after a few minutes I get the red ‘crashed’ notification.
Is there a reason for this or a solution? I generated a diagnostic report when the app crashed.
Thanks in advance. Dick.
c36c47b7-5246-4275-a4f6-2404f3d77611
@Dick_de_Vries this is a English topic
@Dick_de_Vries this is a known issue for quite a while which i can’t fix. Only a SDK update would fix that which i’m still waiting for for the official release
There’s a test version of the app available but crashes are known too with the beta sdk
But you can try it out if you want: [APP][Pro] WhatsApp - Simple. Reliable. Private - #2070 by martijnpoppen
Thanks for the update. Let’s hope a solution will come eventually.
Will make a donation for your efforts ![]()
Thanks a lot @Dick_de_Vries
Hello Here the Same. When you send a groupslink it is better
Hi Martijn,
I’ve got two whatsapp devices linked to my Homey2023. One of them doesn’t want to reconnect when I try to repair. I get a Timeout 10000ms. The other device just reconnects (after an app crash). I tried restarting the app but it doesn’t work.
Any other tricks before I have to delete the device and fix all associated flows? ![]()
