@EdNL please send a report when this happens otherwise I won’t be able to check what’s wrong
Also if you keep seeing the white screen the repair doesn’t work and the only solution is remove and add it again. Not sure if you did that already
To fix your flows you can also do that automatically: [HOW-TO][Pro][Cloud] - Tool to FIX (advanced) flows after removing and re-adding devices
