Hi, looking at open-meteo website there are many different weather models available. Is it possible to select a specific model for my location?
Yes it’s possible. I’ll take a look at it once I find some time.
Hi, I saw on another topic you pointed to this app to get pollen in Homey. But when setting up I can’t see this option? Is it removed, or is there something else I’m missen?
It’s on the Hourly AiQ page on the bottom
Version 2.0.10 Test Preview
Highlights in 2.0.10:
- Added support for selecting weather models
- Added all weather models supported by the Open-Meteo Forecast API
- Added location-based filtering for regional weather models
- Added model run, update interval, and forecast range information
- Automatically adjusted available forecast times to each model’s forecast range
- Improved the forecast time and weather model setup and repair flow UI
Support My Development:
If you appreciate my work and want to help out, consider buying me an energy drink
or a beer
. Donations are a great way to support and motivate me!
You can donate via PayPal. Your generosity helps keep this solo project moving forward!
Calling All Developers!
Are you a developer? Want to contribute to this project? I’d love to collaborate! Feel free to send a pull request on GitHub and join me in making this app even better.
Thank you for your support and for testing!
Oh, I see! I stopped looking after the first page because I only was interested in the pollen.
My bad. Thanks for the reply!
Any plans on adding de solar pv forecast to this app ? Interesting part is that there is no limitation on api calls (solcast has)
Open-Meteo doesn’t provide a direct PV forecast like Solcast. However, I could add a dedicated device where you configure the solar array’s location, installed capacity, azimuth, tilt and performance factor. The app could then estimate the expected power output using Open-Meteo’s solar irradiance and weather forecasts.
However, this would be an estimate and would likely be less accurate than a specialized service such as Solcast.
Good day!
How can I get the Weather State in a variable or send as a notification?
Thanks for your great work!
Hi Peter, thanks for your answer, but I’m looking for the “Weather State” tag that gives the state “HOT”, “Freezing” etc… I can’t find it in the list
