[APP][Pro] Vision Security
I have de V5 running on my homey. So i downloaded the v2 version from Freek of the community store. I have The battery operated siren but it is not suported in this V2 version so i can not test it.
Me too !!
Thanks for your help !
Unfortunately this is not sufficient for me :frowning:
I tried to play with Raw parameters in order so setup the parameters (parameter 1 to setup the siren/strobe ode and parameter 2 to setup the alarm auto-stop time). I don’t know if it has worked, but the thing is I do not manage to set the alarm ON.
I think the device is ON (I can see it in Homey with no network problem ?).
But how can I set the alarm ON ?
I tried to setup ZG8181 with the Homey generic app. It connects, but the app doesn’t cover on/off input. Only for controlling switches as far as I can see.
Would be great if someone can update it to Homeyv5.
I wish I had the skills to do that.
Offcourse i’d like to donate for the app if someone helps.
May be we should make it more clear how much someone could get to rewrite the App. I would donate 80 Euro :blush:
I had contact with homey and the are to Buzzy to do this. Maybe we can all send them a request ?
As @Rom requested earlier. I might be able to take a look at it.
Not sure if I manage to fix it, but i’ll report back :wink:
Nice. Hope you can!!
I think I fixed it :stuck_out_tongue:
Ofourse I’m unable to test myself so would be nice if you guys could do that.
I reached out to Patrick to transfer the app to me. @Berni did you also approach Patrick via the community?
When I have access to the developer dashboard i’ll make an publish of the app.
Have a nice evening!
Nice nice nice. As soon it is available i. Test what i can
Goodmorning,
The app got transferred to me.
I pushed a version for V5 to test: Vision Security App for Homey | Homey
Ofcourse i’m not sure if everything would work directly but I think you guys will let me know :slight_smile:
Great,
I downloaded it. That works :wink: but not able to test now i hope later on the day. keep yo posted Nice Martijn!!!
Dear Martijn,
Thanks for your implication :+1: :+1:
I installed your v2.0.0 application on my Homey version 5.0.0 .
I tried to include my “DC/AC Power Siren” (model ZM1602) and it worked great !
But there is an error (see screenshot below) after :frowning:
I tried to restart Homey but nothing the problem still exists.
Do not hesitate if I can help you !!
@kietu Alright i’ll take a look. Think it has something to do with the Flows. I’ll come back on this later :slight_smile:
I put a new version in test: 2.0.1
cc: @kietu
2.0.1 on H. Battery operated Siren inclusion works. Conformed with one blink LED
You can change the advanged options For A no siren but only blinking LED. Seems to besaved
Developer the node is reachable (test)
But Battery status is a ?
And you cant trigger de lights or Siren not manual not with a flow cant get it to flash or Siren
All in 10cm of Homey
@Peter_Peter Alright will look into that! It was quite and rewrite so I already thought that there were some bugs :wink:
Take your time!!!
@martijnpoppen I have the Garage door sensor and tried the test release and getting this error.
I can see the flows and history but not the status.
Hope you can help me, I use this device alot. Big thanks for taking over the app. Really a life saver.
@martijnpoppen Very cool you want to take over this app!
I’ve installed your test app, but unfortunately my ZP3102 doesn’t work with it. Deleting and re-adding the device doesn’t make any difference :frowning:
