YES!
Finally
No problem glad to help out
Edit: thanks a lot for your donation !
YES!
Finally
News from Peter the ”party pooper”!
I got the -5 sensor in my mail today (as I ordered just in case) and guess what, the external input doesn’t work.
It is not possible to change the Y/N for external input, which might be the problem?
Magnet works fine and also the tamper alarm (which don’t work in the old sensor, couldn’t care less)
I think we save this for the new year, but please tell me if I shall catch logs etc.
Hey @PeterW
I check the manual and see what the differences are. We might need to make it a separate device. Will come back on this
Great! No stress! I will need this one later, when weather improves.
Will try to build a solution for mail received indication.
In meantime, have a very Good New Year!
@martijnpoppen Same result, want some logs?
Which?
@PeterW yes!
Everything
The Z-Wave logs from the developer portal and a diagnostic report
1 Tried to change parameter
2 External Switch
3 Magnet
[2021-12-28T15:45:14.010Z] Node[36]: Marked as online
[2021-12-28T15:45:16.996Z] Node[36]: [COMMAND_CLASS_NOTIFICATION] {"V1 Alarm Type (Raw)":{"type":"Buffer","data":[7]},"V1 Alarm Type":7,"V1 Alarm Level (Raw)":{"type":"Buffer","data":[0]},"V1 Alarm Level":0,"Notification Status (Raw)":{"type":"Buffer","data":[255]},"Notification Status":"On","Notification Type (Raw)":{"type":"Buffer","data":[7]},"Notification Type":"Home Security","Event (Raw)":{"type":"Buffer","data":[0]},"Event":0,"Properties1 (Raw)":{"type":"Buffer","data":[0]},"Properties1":{"Event Parameters Length":0,"Sequence":false},"Sequence Number (Raw)":{"type":"Buffer","data":[0]},"Sequence Number":0}
[2021-12-28T15:45:17.634Z] Node[36]: Marked as offline
[2021-12-28T15:45:18.638Z] Node[36]: [COMMAND_CLASS_NOTIFICATION] {"V1 Alarm Type (Raw)":{"type":"Buffer","data":[7]},"V1 Alarm Type":7,"V1 Alarm Level (Raw)":{"type":"Buffer","data":[255]},"V1 Alarm Level":255,"Notification Status (Raw)":{"type":"Buffer","data":[255]},"Notification Status":"On","Notification Type (Raw)":{"type":"Buffer","data":[7]},"Notification Type":"Home Security","Event (Raw)":{"type":"Buffer","data":[3]},"Event":3,"Properties1 (Raw)":{"type":"Buffer","data":[0]},"Properties1":{"Event Parameters Length":0,"Sequence":false},"Sequence Number (Raw)":{"type":"Buffer","data":[0]},"Sequence Number":0}
[2021-12-28T15:45:21.248Z] Node[36]: [COMMAND_CLASS_NOTIFICATION] {"V1 Alarm Type (Raw)":{"type":"Buffer","data":[7]},"V1 Alarm Type":7,"V1 Alarm Level (Raw)":{"type":"Buffer","data":[0]},"V1 Alarm Level":0,"Notification Status (Raw)":{"type":"Buffer","data":[255]},"Notification Status":"On","Notification Type (Raw)":{"type":"Buffer","data":[7]},"Notification Type":"Home Security","Event (Raw)":{"type":"Buffer","data":[0]},"Event":0,"Properties1 (Raw)":{"type":"Buffer","data":[0]},"Properties1":{"Event Parameters Length":0,"Sequence":false},"Sequence Number (Raw)":{"type":"Buffer","data":[0]},"Sequence Number":0}
[2021-12-28T15:45:34.777Z] Node[36]: [COMMAND_CLASS_BASIC] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":0}
[2021-12-28T15:45:34.841Z] Node[36]: [COMMAND_CLASS_NOTIFICATION] {"V1 Alarm Type (Raw)":{"type":"Buffer","data":[6]},"V1 Alarm Type":6,"V1 Alarm Level (Raw)":{"type":"Buffer","data":[0]},"V1 Alarm Level":0,"Notification Status (Raw)":{"type":"Buffer","data":[255]},"Notification Status":"On","Notification Type (Raw)":{"type":"Buffer","data":[6]},"Notification Type":"Access Control","Event (Raw)":{"type":"Buffer","data":[23]},"Event":23,"Properties1 (Raw)":{"type":"Buffer","data":[0]},"Properties1":{"Event Parameters Length":0,"Sequence":false},"Sequence Number (Raw)":{"type":"Buffer","data":[0]},"Sequence Number":0}
[2021-12-28T15:45:34.870Z] Node[36]: [COMMAND_CLASS_NOTIFICATION] {"V1 Alarm Type (Raw)":{"type":"Buffer","data":[6]},"V1 Alarm Type":6,"V1 Alarm Level (Raw)":{"type":"Buffer","data":[0]},"V1 Alarm Level":0,"Notification Status (Raw)":{"type":"Buffer","data":[255]},"Notification Status":"On","Notification Type (Raw)":{"type":"Buffer","data":[6]},"Notification Type":"Access Control","Event (Raw)":{"type":"Buffer","data":[23]},"Event":23,"Properties1 (Raw)":{"type":"Buffer","data":[0]},"Properties1":{"Event Parameters Length":0,"Sequence":false},"Sequence Number (Raw)":{"type":"Buffer","data":[0]},"Sequence Number":0}
[2021-12-28T15:45:34.927Z] Node[36]: [COMMAND_CLASS_BASIC] {"Value (Raw)":{"type":"Buffer","data":[255]},"Value":255}
[2021-12-28T15:45:35.012Z] Node[36]: [COMMAND_CLASS_NOTIFICATION] {"V1 Alarm Type (Raw)":{"type":"Buffer","data":[6]},"V1 Alarm Type":6,"V1 Alarm Level (Raw)":{"type":"Buffer","data":[255]},"V1 Alarm Level":255,"Notification Status (Raw)":{"type":"Buffer","data":[255]},"Notification Status":"On","Notification Type (Raw)":{"type":"Buffer","data":[6]},"Notification Type":"Access Control","Event (Raw)":{"type":"Buffer","data":[22]},"Event":22,"Properties1 (Raw)":{"type":"Buffer","data":[0]},"Properties1":{"Event Parameters Length":0,"Sequence":false},"Sequence Number (Raw)":{"type":"Buffer","data":[0]},"Sequence Number":0}
[2021-12-28T15:45:35.039Z] Node[36]: [COMMAND_CLASS_NOTIFICATION] {"V1 Alarm Type (Raw)":{"type":"Buffer","data":[6]},"V1 Alarm Type":6,"V1 Alarm Level (Raw)":{"type":"Buffer","data":[255]},"V1 Alarm Level":255,"Notification Status (Raw)":{"type":"Buffer","data":[255]},"Notification Status":"On","Notification Type (Raw)":{"type":"Buffer","data":[6]},"Notification Type":"Access Control","Event (Raw)":{"type":"Buffer","data":[22]},"Event":22,"Properties1 (Raw)":{"type":"Buffer","data":[0]},"Properties1":{"Event Parameters Length":0,"Sequence":false},"Sequence Number (Raw)":{"type":"Buffer","data":[0]},"Sequence Number":0}
[2021-12-28T15:45:37.067Z] Node[36]: [COMMAND_CLASS_BASIC] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":0}
[2021-12-28T15:45:37.129Z] Node[36]: [COMMAND_CLASS_NOTIFICATION] {"V1 Alarm Type (Raw)":{"type":"Buffer","data":[6]},"V1 Alarm Type":6,"V1 Alarm Level (Raw)":{"type":"Buffer","data":[0]},"V1 Alarm Level":0,"Notification Status (Raw)":{"type":"Buffer","data":[255]},"Notification Status":"On","Notification Type (Raw)":{"type":"Buffer","data":[6]},"Notification Type":"Access Control","Event (Raw)":{"type":"Buffer","data":[23]},"Event":23,"Properties1 (Raw)":{"type":"Buffer","data":[0]},"Properties1":{"Event Parameters Length":0,"Sequence":false},"Sequence Number (Raw)":{"type":"Buffer","data":[0]},"Sequence Number":0}
[2021-12-28T15:45:37.206Z] Node[36]: [COMMAND_CLASS_BASIC] {"Value (Raw)":{"type":"Buffer","data":[255]},"Value":255}
[2021-12-28T15:45:37.290Z] Node[36]: [COMMAND_CLASS_NOTIFICATION] {"V1 Alarm Type (Raw)":{"type":"Buffer","data":[6]},"V1 Alarm Type":6,"V1 Alarm Level (Raw)":{"type":"Buffer","data":[255]},"V1 Alarm Level":255,"Notification Status (Raw)":{"type":"Buffer","data":[255]},"Notification Status":"On","Notification Type (Raw)":{"type":"Buffer","data":[6]},"Notification Type":"Access Control","Event (Raw)":{"type":"Buffer","data":[22]},"Event":22,"Properties1 (Raw)":{"type":"Buffer","data":[0]},"Properties1":{"Event Parameters Length":0,"Sequence":false},"Sequence Number (Raw)":{"type":"Buffer","data":[0]},"Sequence Number":0}
[2021-12-28T15:45:37.319Z] Node[36]: [COMMAND_CLASS_NOTIFICATION] {"V1 Alarm Type (Raw)":{"type":"Buffer","data":[6]},"V1 Alarm Type":6,"V1 Alarm Level (Raw)":{"type":"Buffer","data":[255]},"V1 Alarm Level":255,"Notification Status (Raw)":{"type":"Buffer","data":[255]},"Notification Status":"On","Notification Type (Raw)":{"type":"Buffer","data":[6]},"Notification Type":"Access Control","Event (Raw)":{"type":"Buffer","data":[22]},"Event":22,"Properties1 (Raw)":{"type":"Buffer","data":[0]},"Properties1":{"Event Parameters Length":0,"Sequence":false},"Sequence Number (Raw)":{"type":"Buffer","data":[0]},"Sequence Number":0}
[2021-12-28T15:45:38.156Z] Node[36]: [COMMAND_CLASS_BASIC] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":0}
[2021-12-28T15:45:38.218Z] Node[36]: [COMMAND_CLASS_NOTIFICATION] {"V1 Alarm Type (Raw)":{"type":"Buffer","data":[6]},"V1 Alarm Type":6,"V1 Alarm Level (Raw)":{"type":"Buffer","data":[0]},"V1 Alarm Level":0,"Notification Status (Raw)":{"type":"Buffer","data":[255]},"Notification Status":"On","Notification Type (Raw)":{"type":"Buffer","data":[6]},"Notification Type":"Access Control","Event (Raw)":{"type":"Buffer","data":[23]},"Event":23,"Properties1 (Raw)":{"type":"Buffer","data":[0]},"Properties1":{"Event Parameters Length":0,"Sequence":false},"Sequence Number (Raw)":{"type":"Buffer","data":[0]},"Sequence Number":0}
[2021-12-28T15:45:38.520Z] Node[36]: [COMMAND_CLASS_BASIC] {"Value (Raw)":{"type":"Buffer","data":[255]},"Value":255}
[2021-12-28T15:45:38.612Z] Node[36]: [COMMAND_CLASS_NOTIFICATION] {"V1 Alarm Type (Raw)":{"type":"Buffer","data":[6]},"V1 Alarm Type":6,"V1 Alarm Level (Raw)":{"type":"Buffer","data":[255]},"V1 Alarm Level":255,"Notification Status (Raw)":{"type":"Buffer","data":[255]},"Notification Status":"On","Notification Type (Raw)":{"type":"Buffer","data":[6]},"Notification Type":"Access Control","Event (Raw)":{"type":"Buffer","data":[22]},"Event":22,"Properties1 (Raw)":{"type":"Buffer","data":[0]},"Properties1":{"Event Parameters Length":0,"Sequence":false},"Sequence Number (Raw)":{"type":"Buffer","data":[0]},"Sequence Number":0}
[2021-12-28T15:45:39.926Z] Node[36]: [COMMAND_CLASS_NOTIFICATION] {"V1 Alarm Type (Raw)":{"type":"Buffer","data":[7]},"V1 Alarm Type":7,"V1 Alarm Level (Raw)":{"type":"Buffer","data":[255]},"V1 Alarm Level":255,"Notification Status (Raw)":{"type":"Buffer","data":[255]},"Notification Status":"On","Notification Type (Raw)":{"type":"Buffer","data":[7]},"Notification Type":"Home Security","Event (Raw)":{"type":"Buffer","data":[3]},"Event":3,"Properties1 (Raw)":{"type":"Buffer","data":[0]},"Properties1":{"Event Parameters Length":0,"Sequence":false},"Sequence Number (Raw)":{"type":"Buffer","data":[0]},"Sequence Number":0}
c7eb08b3-6081-4756-82ea-93568e08f2db
Also, activation of the tamper swich is part of the log
I just came away for a week on holiday and hours after I left, the vision security app was automatically updated to 2.6.12. As a result all of the flows on all my vision devices are now broken. That’s all 20+ door and window sensors in my house with many tens of different flows.
Please can you advise what breaking change you made and what I should do to get the functionality back?
Hey @Jonathan_Draper
Yes I can help
Which devices do you have?
Because the only change had been made to the ZD2102.
And I added 2 new devices
Thank you! I can’t check them being away from home but I googled the zd2102 you mentioned and they looks exactly like mine
@Jonathan_Draper
Can you send me a diagnostic report ?
More - apps - vision Security - settings wheel right top - send diagnostic report
Done. It gave me this code 471ded66-1de2-4777-955e-9cb28b3576f0
I think my flows used the contact alarm and the devices now only show up with generic alarm and nothing else
Will check!
@Jonathan_Draper a app restart might do the trick
More - apps - vision Security - settings wheel right top - restart app
Aha. App restart seems to have fixed it - thank you!
Nice! ![]()
Theres a new check which add all functionalities on startup. But something went wrong there i guess
Another thing: I made a app which reports whenever a flow stopped working: Flow Checker App voor Homey | Homey
This Will help whenever a app update breaks stuff. You’ll get notified
Enjoy your holidays!
Didn’t realise that was also your app. I have it - that’s how I knew these flows had failed! Thank you again
