[APP][Pro] Vision Security
Did some testing in the Zipzto box…
It looks like the magnet switch use Closed and Open states, while the external switch use On and Off.
I found two manual giving some maybe useful information. Note! The descriptions in the two documents are giving defferent pieces of information about the external switch.
Hey @OzFrog Will check those values. Might be that I added it wrong. Will let you know once you can test
@PeterW Thanks for checking.
I found there are 2 version of the ZD2102. 1 with the configuration for the external switch and one without.
Yours doesn’t have a configuration switch so should always report.
I made a change for that yesterday evening. It’s in version 2.6.6. No sure if you checked that already.
I’ll check the docs you send :slight_smile:
Found another, way more complete manual. Maybe exactly what you need?
That one indicates that it is the same alarm for both magnet and external.
Ah yes! Will check. As you can see that’s the ZD2102EU-5 and I think you have the ZD2102.
Which doesn’t have the configuration switch :stuck_out_tongue:
I have used the external switch up to this week in the Zipato box, but that was maybe not what you meant?
Edit: Tested 2.6.6 and now the sensor doesn’t work at all. :slight_smile:
alright, then i’ll revert that. Will read the manual and try some new stuff :stuck_out_tongue:
maybe one thing: If i’m correct we can see logs from devices.
When you go to this page: Homey Developer Tools
  • Enable the logging.
  • try to interact with the sensor (magnet and exernal)
  • see if it send some data.
  • send that data to me :smiley:
Will do!
To be a step ahead, I just ordered a -5 sensor. :slight_smile:
That might give us a better chanse to succed.
[2021-12-23T09:49:21.018Z] Node[33]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,163]},"Sensor Value":{"type":"Buffer","data":[0,163]}}
[2021-12-23T09:49:22.280Z] Node[8]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[33]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":false},"Properties2 (Raw)":{"type":"Buffer","data":[116]},"Properties2":{"Size":4,"Scale bits 10":2,"Precision":3},"Meter Value (Raw)":{"type":"Buffer","data":[0,0,0,0]},"Meter Value":{"type":"Buffer","data":[0,0,0,0]}}
[2021-12-23T09:49:22.406Z] Node[31]: [COMMAND_CLASS_BASIC] {"Value (Raw)":{"type":"Buffer","data":[255]},"Value":255}
[2021-12-23T09:49:22.426Z] Node[31]: [COMMAND_CLASS_ALARM] {"Alarm Type (Raw)":{"type":"Buffer","data":[7]},"Alarm Type":7,"Alarm Level (Raw)":{"type":"Buffer","data":[255]},"Alarm Level":255,"Zensor Net Source Node ID (Raw)":{"type":"Buffer","data":[0]},"Zensor Net Source Node ID":0,"ZWave Alarm Status (Raw)":{"type":"Buffer","data":[255]},"ZWave Alarm Status":"On","ZWave Alarm Type (Raw)":{"type":"Buffer","data":[7]},"ZWave Alarm Type":"Burglar","ZWave Alarm Event (Raw)":{"type":"Buffer","data":[2]},"ZWave Alarm Event":2,"Number of Event Parameters (Raw)":{"type":"Buffer","data":[0]},"Number of Event Parameters":0}
[2021-12-23T09:49:24.735Z] Node[31]: [COMMAND_CLASS_BASIC] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":0}
[2021-12-23T09:49:24.754Z] Node[31]: [COMMAND_CLASS_ALARM] {"Alarm Type (Raw)":{"type":"Buffer","data":[7]},"Alarm Type":7,"Alarm Level (Raw)":{"type":"Buffer","data":[0]},"Alarm Level":0,"Zensor Net Source Node ID (Raw)":{"type":"Buffer","data":[0]},"Zensor Net Source Node ID":0,"ZWave Alarm Status (Raw)":{"type":"Buffer","data":[255]},"ZWave Alarm Status":"On","ZWave Alarm Type (Raw)":{"type":"Buffer","data":[7]},"ZWave Alarm Type":"Burglar","ZWave Alarm Event (Raw)":{"type":"Buffer","data":[2]},"ZWave Alarm Event":2,"Number of Event Parameters (Raw)":{"type":"Buffer","data":[0]},"Number of Event Parameters":0}
[2021-12-23T09:49:27.604Z] Node[31]: [COMMAND_CLASS_BASIC] {"Value (Raw)":{"type":"Buffer","data":[255]},"Value":255}
[2021-12-23T09:49:27.624Z] Node[31]: [COMMAND_CLASS_ALARM] {"Alarm Type (Raw)":{"type":"Buffer","data":[7]},"Alarm Type":7,"Alarm Level (Raw)":{"type":"Buffer","data":[255]},"Alarm Level":255,"Zensor Net Source Node ID (Raw)":{"type":"Buffer","data":[0]},"Zensor Net Source Node ID":0,"ZWave Alarm Status (Raw)":{"type":"Buffer","data":[255]},"ZWave Alarm Status":"On","ZWave Alarm Type (Raw)":{"type":"Buffer","data":[7]},"ZWave Alarm Type":"Burglar","ZWave Alarm Event (Raw)":{"type":"Buffer","data":[2]},"ZWave Alarm Event":2,"Number of Event Parameters (Raw)":{"type":"Buffer","data":[0]},"Number of Event Parameters":0}
[2021-12-23T09:49:29.598Z] Node[31]: [COMMAND_CLASS_BASIC] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":0}
[2021-12-23T09:49:29.618Z] Node[31]: [COMMAND_CLASS_ALARM] {"Alarm Type (Raw)":{"type":"Buffer","data":[7]},"Alarm Type":7,"Alarm Level (Raw)":{"type":"Buffer","data":[0]},"Alarm Level":0,"Zensor Net Source Node ID (Raw)":{"type":"Buffer","data":[0]},"Zensor Net Source Node ID":0,"ZWave Alarm Status (Raw)":{"type":"Buffer","data":[255]},"ZWave Alarm Status":"On","ZWave Alarm Type (Raw)":{"type":"Buffer","data":[7]},"ZWave Alarm Type":"Burglar","ZWave Alarm Event (Raw)":{"type":"Buffer","data":[2]},"ZWave Alarm Event":2,"Number of Event Parameters (Raw)":{"type":"Buffer","data":[0]},"Number of Event Parameters":0}
[2021-12-23T09:49:32.032Z] Node[31]: [COMMAND_CLASS_ALARM] {"Alarm Type (Raw)":{"type":"Buffer","data":[7]},"Alarm Type":7,"Alarm Level (Raw)":{"type":"Buffer","data":[0]},"Alarm Level":0,"Zensor Net Source Node ID (Raw)":{"type":"Buffer","data":[0]},"Zensor Net Source Node ID":0,"ZWave Alarm Status (Raw)":{"type":"Buffer","data":[255]},"ZWave Alarm Status":"On","ZWave Alarm Type (Raw)":{"type":"Buffer","data":[7]},"ZWave Alarm Type":"Burglar","ZWave Alarm Event (Raw)":{"type":"Buffer","data":[254]},"ZWave Alarm Event":254,"Number of Event Parameters (Raw)":{"type":"Buffer","data":[0]},"Number of Event Parameters":0}
[2021-12-23T09:49:32.489Z] Node[31]: [COMMAND_CLASS_ALARM] {"Alarm Type (Raw)":{"type":"Buffer","data":[7]},"Alarm Type":7,"Alarm Level (Raw)":{"type":"Buffer","data":[255]},"Alarm Level":255,"Zensor Net Source Node ID (Raw)":{"type":"Buffer","data":[0]},"Zensor Net Source Node ID":0,"ZWave Alarm Status (Raw)":{"type":"Buffer","data":[255]},"ZWave Alarm Status":"On","ZWave Alarm Type (Raw)":{"type":"Buffer","data":[7]},"ZWave Alarm Type":"Burglar","ZWave Alarm Event (Raw)":{"type":"Buffer","data":[254]},"ZWave Alarm Event":254,"Number of Event Parameters (Raw)":{"type":"Buffer","data":[0]},"Number of Event Parameters":0}
[2021-12-23T09:49:35.582Z] Node[31]: [COMMAND_CLASS_ALARM] {"Alarm Type (Raw)":{"type":"Buffer","data":[7]},"Alarm Type":7,"Alarm Level (Raw)":{"type":"Buffer","data":[0]},"Alarm Level":0,"Zensor Net Source Node ID (Raw)":{"type":"Buffer","data":[0]},"Zensor Net Source Node ID":0,"ZWave Alarm Status (Raw)":{"type":"Buffer","data":[255]},"ZWave Alarm Status":"On","ZWave Alarm Type (Raw)":{"type":"Buffer","data":[7]},"ZWave Alarm Type":"Burglar","ZWave Alarm Event (Raw)":{"type":"Buffer","data":[254]},"ZWave Alarm Event":254,"Number of Event Parameters (Raw)":{"type":"Buffer","data":[0]},"Number of Event Parameters":0}
[2021-12-23T09:49:35.970Z] Node[7]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[33]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":false},"Properties2 (Raw)":{"type":"Buffer","data":[116]},"Properties2":{"Size":4,"Scale bits 10":2,"Precision":3},"Meter Value (Raw)":{"type":"Buffer","data":[0,0,0,0]},"Meter Value":{"type":"Buffer","data":[0,0,0,0]}}
[2021-12-23T09:49:37.139Z] Node[31]: [COMMAND_CLASS_ALARM] {"Alarm Type (Raw)":{"type":"Buffer","data":[7]},"Alarm Type":7,"Alarm Level (Raw)":{"type":"Buffer","data":[255]},"Alarm Level":255,"Zensor Net Source Node ID (Raw)":{"type":"Buffer","data":[0]},"Zensor Net Source Node ID":0,"ZWave Alarm Status (Raw)":{"type":"Buffer","data":[255]},"ZWave Alarm Status":"On","ZWave Alarm Type (Raw)":{"type":"Buffer","data":[7]},"ZWave Alarm Type":"Burglar","ZWave Alarm Event (Raw)":{"type":"Buffer","data":[254]},"ZWave Alarm Event":254,"Number of Event Parameters (Raw)":{"type":"Buffer","data":[0]},"Number of Event Parameters":0}
[2021-12-23T09:49:40.578Z] Node[14]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[33]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":false},"Properties2 (Raw)":{"type":"Buffer","data":[116]},"Properties2":{"Size":4,"Scale bits 10":2,"Precision":3},"Meter Value (Raw)":{"type":"Buffer","data":[0,0,240,35]},"Meter Value":{"type":"Buffer","data":[0,0,240,35]}}
[2021-12-23T09:49:40.880Z] Node[31]: [COMMAND_CLASS_ALARM] {"Alarm Type (Raw)":{"type":"Buffer","data":[7]},"Alarm Type":7,"Alarm Level (Raw)":{"type":"Buffer","data":[0]},"Alarm Level":0,"Zensor Net Source Node ID (Raw)":{"type":"Buffer","data":[0]},"Zensor Net Source Node ID":0,"ZWave Alarm Status (Raw)":{"type":"Buffer","data":[255]},"ZWave Alarm Status":"On","ZWave Alarm Type (Raw)":{"type":"Buffer","data":[7]},"ZWave Alarm Type":"Burglar","ZWave Alarm Event (Raw)":{"type":"Buffer","data":[254]},"ZWave Alarm Event":254,"Number of Event Parameters (Raw)":{"type":"Buffer","data":[0]},"Number of Event Parameters":0}
[2021-12-23T09:49:44.185Z] Node[31]: [COMMAND_CLASS_ALARM] {"Alarm Type (Raw)":{"type":"Buffer","data":[7]},"Alarm Type":7,"Alarm Level (Raw)":{"type":"Buffer","data":[255]},"Alarm Level":255,"Zensor Net Source Node ID (Raw)":{"type":"Buffer","data":[0]},"Zensor Net Source Node ID":0,"ZWave Alarm Status (Raw)":{"type":"Buffer","data":[255]},"ZWave Alarm Status":"On","ZWave Alarm Type (Raw)":{"type":"Buffer","data":[7]},"ZWave Alarm Type":"Burglar","ZWave Alarm Event (Raw)":{"type":"Buffer","data":[254]},"ZWave Alarm Event":254,"Number of Event Parameters (Raw)":{"type":"Buffer","data":[0]},"Number of Event Parameters":0}
[2021-12-23T09:49:50.288Z] Node[25]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,30]},"Sensor Value":{"type":"Buffer","data":[0,30]}}
[2021-12-23T09:49:51.455Z] Node[25]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,30]},"Sensor Value":{"type":"Buffer","data":[0,30]}}
[2021-12-23T09:49:51.551Z] Node[8]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[33]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":false},"Properties2 (Raw)":{"type":"Buffer","data":[116]},"Properties2":{"Size":4,"Scale bits 10":2,"Precision":3},"Meter Value (Raw)":{"type":"Buffer","data":[0,0,0,0]},"Meter Value":{"type":"Buffer","data":[0,0,0,0]}}
[2021-12-23T09:49:51.596Z] Node[8]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[33]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":false},"Properties2 (Raw)":{"type":"Buffer","data":[116]},"Properties2":{"Size":4,"Scale bits 10":2,"Precision":3},"Meter Value (Raw)":{"type":"Buffer","data":[0,0,0,0]},"Meter Value":{"type":"Buffer","data":[0,0,0,0]}}
[2021-12-23T09:49:55.128Z] Node[33]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,161]},"Sensor Value":{"type":"Buffer","data":[0,161]}}
[2021-12-23T09:50:05.972Z] Node[7]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[33]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":false},"Properties2 (Raw)":{"type":"Buffer","data":[116]},"Properties2":{"Size":4,"Scale bits 10":2,"Precision":3},"Meter Value (Raw)":{"type":"Buffer","data":[0,0,0,0]},"Meter Value":{"type":"Buffer","data":[0,0,0,0]}}
[2021-12-23T09:50:10.578Z] Node[14]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[33]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":false},"Properties2 (Raw)":{"type":"Buffer","data":[116]},"Properties2":{"Size":4,"Scale bits 10":2,"Precision":3},"Meter Value (Raw)":{"type":"Buffer","data":[0,0,240,132]},"Meter Value":{"type":"Buffer","data":[0,0,240,132]}}
[2021-12-23T09:50:21.075Z] Node[33]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,160]},"Sensor Value":{"type":"Buffer","data":[0,160]}}
[2021-12-23T09:50:22.306Z] Node[8]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[33]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":false},"Properties2 (Raw)":{"type":"Buffer","data":[116]},"Properties2":{"Size":4,"Scale bits 10":2,"Precision":3},"Meter Value (Raw)":{"type":"Buffer","data":[0,0,0,0]},"Meter Value":{"type":"Buffer","data":[0,0,0,0]}}
[2021-12-23T09:50:23.477Z] Node[8]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[33]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":false},"Properties2 (Raw)":{"type":"Buffer","data":[116]},"Properties2":{"Size":4,"Scale bits 10":2,"Precision":3},"Meter Value (Raw)":{"type":"Buffer","data":[0,0,0,0]},"Meter Value":{"type":"Buffer","data":[0,0,0,0]}}
[2021-12-23T09:50:35.975Z] Node[7]: [COMMAND_CLASS_METER] {"Properties1 (Raw)":{"type":"Buffer","data":[33]},"Properties1":{"Meter Type":1,"Rate Type":1,"Scale bit 2":false},"Properties2 (Raw)":{"type":"Buffer","data":[116]},"Properties2":{"Size":4,"Scale bits 10":2,"Precision":3},"Meter Value (Raw)":{"type":"Buffer","data":[0,0,0,0]},"Meter Value":{"type":"Buffer","data":[0,0,0,0]}}
Tested first magnet and efter that the external.
Thanks,
Can you tell me which node id is the ZD2102?
Edit: I think it’s 31 ?
Yes, it’s 31 was just going to write that. :slight_smile:
New app update (test: 2.6.7):
  • NEW: ADD ZD2201 and ZD2105
  • FIX: ZD2102 external switch setting
  • ADD: ZD2102 interval for wake up + battery fix
  • FIX: product ids for ZD2201 & ZD2105
  • FIX: ZD2102 External Switch
  • FIX: ZD2102
@PeterW Try number 200 ? :stuck_out_tongue:
Magnet switch works ok now, still not External :slight_smile:
Log:
10:23:50 = external input
10:23:53 = Magnet
[2021-12-23T10:23:50.514Z] Node[31]: [COMMAND_CLASS_BASIC] {"Value (Raw)":{"type":"Buffer","data":[255]},"Value":255}
[2021-12-23T10:23:50.541Z] Node[31]: [COMMAND_CLASS_ALARM] {"Alarm Type (Raw)":{"type":"Buffer","data":[7]},"Alarm Type":7,"Alarm Level (Raw)":{"type":"Buffer","data":[255]},"Alarm Level":255,"Zensor Net Source Node ID (Raw)":{"type":"Buffer","data":[0]},"Zensor Net Source Node ID":0,"ZWave Alarm Status (Raw)":{"type":"Buffer","data":[255]},"ZWave Alarm Status":"On","ZWave Alarm Type (Raw)":{"type":"Buffer","data":[7]},"ZWave Alarm Type":"Burglar","ZWave Alarm Event (Raw)":{"type":"Buffer","data":[2]},"ZWave Alarm Event":2,"Number of Event Parameters (Raw)":{"type":"Buffer","data":[0]},"Number of Event Parameters":0}
[2021-12-23T10:23:53.891Z] Node[31]: [COMMAND_CLASS_BASIC] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":0}
[2021-12-23T10:23:53.910Z] Node[31]: [COMMAND_CLASS_ALARM] {"Alarm Type (Raw)":{"type":"Buffer","data":[7]},"Alarm Type":7,"Alarm Level (Raw)":{"type":"Buffer","data":[0]},"Alarm Level":0,"Zensor Net Source Node ID (Raw)":{"type":"Buffer","data":[0]},"Zensor Net Source Node ID":0,"ZWave Alarm Status (Raw)":{"type":"Buffer","data":[255]},"ZWave Alarm Status":"On","ZWave Alarm Type (Raw)":{"type":"Buffer","data":[7]},"ZWave Alarm Type":"Burglar","ZWave Alarm Event (Raw)":{"type":"Buffer","data":[2]},"ZWave Alarm Event":2,"Number of Event Parameters (Raw)":{"type":"Buffer","data":[0]},"Number of Event Parameters":0}
@Caseda I hope you can help out :stuck_out_tongue:
So the ZD2102 has 2 options:
  • magnet sensor
  • external switch
on newer devices the external switch can be set with COMMAND_CLASS_CONFIGURATION but on this model not.
I don’t really see any event related to the external switch according to the logs in the message from Peter.
(see above)
COMMAND_CLASS_ALARM = alarm_tamper
COMMAND_CLASS_BASIC = alarm_contact
So not sure what the external switch reports.
As you helped out before. Do you have any idea how this should work?
Tried to isolate the logs better.
Did first a connect - disconnect with the external connection and then the same using the magnet, close - open.
External input
[2021-12-23T15:24:07.206Z] Node[31]: [COMMAND_CLASS_ALARM] {"Alarm Type (Raw)":{"type":"Buffer","data":[7]},"Alarm Type":7,"Alarm Level (Raw)":{"type":"Buffer","data":[0]},"Alarm Level":0,"Zensor Net Source Node ID (Raw)":{"type":"Buffer","data":[0]},"Zensor Net Source Node ID":0,"ZWave Alarm Status (Raw)":{"type":"Buffer","data":[255]},"ZWave Alarm Status":"On","ZWave Alarm Type (Raw)":{"type":"Buffer","data":[7]},"ZWave Alarm Type":"Burglar","ZWave Alarm Event (Raw)":{"type":"Buffer","data":[254]},"ZWave Alarm Event":254,"Number of Event Parameters (Raw)":{"type":"Buffer","data":[0]},"Number of Event Parameters":0}
[2021-12-23T15:24:09.016Z] Node[31]: [COMMAND_CLASS_ALARM] {"Alarm Type (Raw)":{"type":"Buffer","data":[7]},"Alarm Type":7,"Alarm Level (Raw)":{"type":"Buffer","data":[255]},"Alarm Level":255,"Zensor Net Source Node ID (Raw)":{"type":"Buffer","data":[0]},"Zensor Net Source Node ID":0,"ZWave Alarm Status (Raw)":{"type":"Buffer","data":[255]},"ZWave Alarm Status":"On","ZWave Alarm Type (Raw)":{"type":"Buffer","data":[7]},"ZWave Alarm Type":"Burglar","ZWave Alarm Event (Raw)":{"type":"Buffer","data":[254]},"ZWave Alarm Event":254,"Number of Event Parameters (Raw)":{"type":"Buffer","data":[0]},"Number of Event Parameters":0}
[2021-12-23T15:24:09.081Z] Node[31]: [COMMAND_CLASS_ALARM] {"Alarm Type (Raw)":{"type":"Buffer","data":[7]},"Alarm Type":7,"Alarm Level (Raw)":{"type":"Buffer","data":[255]},"Alarm Level":255,"Zensor Net Source Node ID (Raw)":{"type":"Buffer","data":[0]},"Zensor Net Source Node ID":0,"ZWave Alarm Status (Raw)":{"type":"Buffer","data":[255]},"ZWave Alarm Status":"On","ZWave Alarm Type (Raw)":{"type":"Buffer","data":[7]},"ZWave Alarm Type":"Burglar","ZWave Alarm Event (Raw)":{"type":"Buffer","data":[254]},"ZWave Alarm Event":254,"Number of Event Parameters (Raw)":{"type":"Buffer","data":[0]},"Number of Event Parameters":0}
[2021-12-23T15:24:09.221Z] Node[31]: [COMMAND_CLASS_ALARM] {"Alarm Type (Raw)":{"type":"Buffer","data":[7]},"Alarm Type":7,"Alarm Level (Raw)":{"type":"Buffer","data":[255]},"Alarm Level":255,"Zensor Net Source Node ID (Raw)":{"type":"Buffer","data":[0]},"Zensor Net Source Node ID":0,"ZWave Alarm Status (Raw)":{"type":"Buffer","data":[255]},"ZWave Alarm Status":"On","ZWave Alarm Type (Raw)":{"type":"Buffer","data":[7]},"ZWave Alarm Type":"Burglar","ZWave Alarm Event (Raw)":{"type":"Buffer","data":[254]},"ZWave Alarm Event":254,"Number of Event Parameters (Raw)":{"type":"Buffer","data":[0]},"Number of Event Parameters":0}
Magnet
[2021-12-23T15:28:06.891Z] Node[31]: [COMMAND_CLASS_BASIC] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":0}
[2021-12-23T15:28:06.916Z] Node[31]: [COMMAND_CLASS_ALARM] {"Alarm Type (Raw)":{"type":"Buffer","data":[7]},"Alarm Type":7,"Alarm Level (Raw)":{"type":"Buffer","data":[0]},"Alarm Level":0,"Zensor Net Source Node ID (Raw)":{"type":"Buffer","data":[0]},"Zensor Net Source Node ID":0,"ZWave Alarm Status (Raw)":{"type":"Buffer","data":[255]},"ZWave Alarm Status":"On","ZWave Alarm Type (Raw)":{"type":"Buffer","data":[7]},"ZWave Alarm Type":"Burglar","ZWave Alarm Event (Raw)":{"type":"Buffer","data":[2]},"ZWave Alarm Event":2,"Number of Event Parameters (Raw)":{"type":"Buffer","data":[0]},"Number of Event Parameters":0}
[2021-12-23T15:28:12.853Z] Node[31]: [COMMAND_CLASS_BASIC] {"Value (Raw)":{"type":"Buffer","data":[255]},"Value":255}
[2021-12-23T15:28:12.880Z] Node[31]: [COMMAND_CLASS_ALARM] {"Alarm Type (Raw)":{"type":"Buffer","data":[7]},"Alarm Type":7,"Alarm Level (Raw)":{"type":"Buffer","data":[255]},"Alarm Level":255,"Zensor Net Source Node ID (Raw)":{"type":"Buffer","data":[0]},"Zensor Net Source Node ID":0,"ZWave Alarm Status (Raw)":{"type":"Buffer","data":[255]},"ZWave Alarm Status":"On","ZWave Alarm Type (Raw)":{"type":"Buffer","data":[7]},"ZWave Alarm Type":"Burglar","ZWave Alarm Event (Raw)":{"type":"Buffer","data":[2]},"ZWave Alarm Event":2,"Number of Event Parameters (Raw)":{"type":"Buffer","data":[0]},"Number of Event Parameters":0}
Here is a difference, the value for Magnet is 2
The value for External is 254
Thanks @JPe4619 good find!
Will check :smiley:
New app update (test: 2.6.9):
  • FIX: ZD2102
  • FIX: Door sensor ZD2105 battery status
  • FIX: Multisensor ZD2201 Contact Alarm
@PeterW :crossed_fingers:
@OzFrog made some changes. Luminance seems correct on my side. Not sure if you can calibrate the device?
Sorry, still the same.
