[App][Pro] Uyuni Lighting
Official thread for Uyuni Lightings app for Homey.
Paste your issues or feature requests and will try to implement them.
Support for Homey Cloud is in the works.
Uyuni app for Homey | Homey Pro
Source code
anyone who has been able to connect an uyuni candle to homey pro? I find a remote control but I can’t control the candle…
Mine are working.
  • Do you have straight line of sight between the Homey and the lights? It is Infrared and is very delicate.
  • The remote device can turn them on and the flows can do the same. You tried both methods?
  • Also candles needs to be set to “on”, not “timer”.
  • And check that they are not dimmed to lowest setting. I did not found the codes for dim level. If they are new they should be default max dimmed.
Thanks for checking and reporting back.
Thank you! It works when I put it close to my homey, but that’s what not what I hoped for when I saw the app. I wasn’t aware of the infrared control. Thanks again!
Nice to hear. I can suggest using an external IR hub if you need to control devices in a different room separated from your Homey Pro. A cheap device like the Switchbot Hub mini is powerful and can copy signals from any IR remote. You can then add the remote to Homey. I have curtains, button-bots and a cheap led strip all connected to the switchbot hub and they work better than when connected to Homey directly. It has stronger antennas, Bluetooth, IR and RF.
If you want to use the Homey Uyuni app you can buy a Homey Bridge and add it to Pro as satellite. It can then send the signals.
