[APP][Pro] Unraid
Released a new version (test and waiting for certification)
Changelog:
  • [1.4.2] Docker management by container name instead of ID, added setting (enabled by default) to ignore the onoff capability. Bug fixes and improvements
Available APIs:
Operation List
DataType Info
System Information
Shell Exec
Share List
File Action
Folder Action
Container List
Container Action
UserScript List
UserScript Action
Virtual Machine List
Virtual Machine Action
You can find the documentation and some examples on integration’s github repository
Hi. Thank you for this app. Is it possible to translate them into German? How could I help with this?
Hi @MadMax if you want I can send you the sentences to translate and add them to the next release.
PM me your email and i’ll send you them :+1:
Hi @Arturo,
I have send you a pm.
Hi @Arturo
I am trying to connect to my Unraid server but it says the server is offline while its not.
I have tried logging in with root and another user, both won’t work.
Ip that I filled in is: http://192.168.1.50
Everything else is default (except for login)
Hope you can help me out
Thanks!
Great product and great app. Is it possible to add more then1 server?
Same issue as @Mike_v_E :pensive:
Hi @Mike_v_E and hi @Matthias_Nielsen
you need to fill the IP field with the IP, without http://.
In your case, 192.168.1.50.
@Ab_Helversteijn-Smit thanks! Not at moment but in a future release i’ll add for sure!
is anyone having issue with V7.0 it does not seem to be working correctly. i can’t get it to see the dockers i am running so i can till it to start or stop one
Hello, the Undraid docker containers automation ( Flow ) work perfect in Homey Pro. The only thing what I need is to start Unraid automation via Homey Pro. Does anyone can tell me how this can work?
After updating to 7.0, the plugin also stopped working for me… any guidance?
@Arturo thanks for this app!
For my use-case, I need to know whether the Unraid server’s hard disks are active or spun down. I’ll use this information to control air conditioning in the room where the Unraid server is located. I am working on adding this feature to your app. I hope you’ll consider a pull request once it’s ready!
No I have not found one. It won’t pull the container I have so I unable to build the flows.
Hi, I’ve connected one server successfully to my homey pro. I would like to connect a second unraid server. How can I do that? Does the app support that?
Hi, Is it possible to add a second server? If I try that it says that it can’t find a new server.
It appears that there have been connection issues with Unraid since version 7.x.
My Homey Pro can ping the Unraid server, however the Unraid app is unable to connect. It appears that there may be compatibility issues with Unraid versions 7.x - my server is running Unraid 7.3.2.
