[APP][Pro] Universal TUYA Zigbee Device App - test
Hi Dylan Good afternoon I’m on version 5.11.101 now and still no changes on my not working devices, I’ve posted a few problems last week about a not responding SOS button _TZ3000_0dumfk2z anymore and wrong detected devices the LCD Temperature Humidity sensor the _TZE200_vvmbj46n and the Door/Window sensor the _TZE200_pay2byax.
Did you dive into that or still to busy with all other problems to sort out.
I hope you’ll find time in your busy investigation and solving all the requests,
Thanks and best regards Peter.
Hi, ​
Could you please add support for this 3-gang Wall Switch (HOBEIAN ZG-302Z3)? ​
Manufacturer ID: HOBEIAN
​Product ID: ZG-302Z3 ​
Device ID: a4:c1:38:37:d3:79:0f:60 ​
Currently, only one button is recognized.
Thank you!
This is what I get right now. Still no function. Even re-adding, same problem.
I would like to request support for a Tuya Zigbee IR Remote control that is currently not recognized by the app. It is identified as a TS1201 and it uses Tuya-specific clusters for IR commands rather than standard Zigbee ZCL.
Device Information:
  • Model ID: TS1201
  • Manufacturer Name: _TZ3210_jic09i9a (also seen as _TZ3210_ogx8u9it)
  • Device Type: EndDevice
Technical Details (for implementation): This device communicates via the Tuya Cluster (0xef00). Based on successful implementations in Zigbee2MQTT, the following Data Points (DPs) are required to make it functional:
  • DP 0x01 (ir_code_control): Used for sending IR codes.
  • DP 0x02 (ir_code_learn): Triggers the learning mode to capture signals from a physical remote.
  • DP 0x03 (ir_code_report): The device reports the learned IR code back to the hub through this DP.
Reference: A working implementation and discussion for this specific model can be found here: https://github.com/Koenkk/zigbee2mqtt/issues/24160
The device is quite popular due to its low price, but it requires the Tuya-specific EF00 handling to work in Homey. Thank you for your great work on this app!
Hi there @dlnraja I have a devices which is not responding anymore. Tried to delete it to add it again but it is now flagged with a red signal and I can not add it anymore. Other devices are having the same issue.
Those are already in the app: _TZE200_u6x1zyv2 (climate_sensor/rain_sensor), _TZE284_hdml1aav (soil_sensor), vision (generic_tuya), TS0601 (air_purifier/air_quality_co2/air_quality_comprehensive/button_emergency_sos/button_wireless_6/ceiling_fan/climate_sensor/co_sensor/contact_sensor/curtain_motor/curtain_motor_tilt/dimmer_3gang/dimmer_dual_channel/dimmer_wall_1gang/din_rail_meter/din_rail_switch/door_controller/doorbell/energy_meter_3phase/fan_controller/fingerprint_lock/formaldehyde_sensor/garage_door/gas_detector/gas_sensor/humidifier/hvac_air_conditioner/hvac_dehumidifier/ir_blaster/lock_smart/motion_sensor/motion_sensor_radar_mmwave/pet_feeder/plug_energy_monitor/plug_smart/pool_pump/power_clamp_meter/power_meter/presence_sensor_ceiling/presence_sensor_radar/radiator_controller/radiator_valve/rain_sensor/scene_switch_4/shutter_roller_controller/siren/smart_breaker/smart_heater/smart_heater_controller/smart_rcbo/smoke_detector_advanced/soil_sensor/switch_1gang/switch_2gang/switch_3gang/switch_4gang/switch_dimmer_1gang/switch_wall_5gang/switch_wall_6gang/switch_wall_8gang/thermostat_4ch/thermostat_tuya_dp/universal_fallback/usb_outlet_advanced/valve_irrigation/valve_single/vibration_sensor/water_leak_sensor/water_tank_monitor/water_valve_smart/weather_station_outdoor). The correct driver depends on the productId (TS0001, TS0002, etc). Just remove and re-pair, make sure you pick the right device type.
Sure, here it is : 693fd5c1-702f-451e-afc2-7b33a0a21a73
Hi Dylan,
I received the following error message for rain sensor:
IAS Zone enrollment incomplete. Remove and re-add device if sensor not responding.
_TZE200_u6x1zyv2
TS0601
I tried again, but there was no result for the fertilizer level. can this be added? Many thanks in advance!
TS0601
_TZE284_hdml1aav
Summary
“ids”: {
“modelId”: “TS0601”,
“manufacturerName”: “_TZE284_hdml1aav”
“endpoints”: {
“ieeeAddress”: “a4:c1:38:39:d7:02:17:55”,
“networkAddress”: 14088,
“manufacturerName”: “_TZE284_hdml1aav”,
“endpointDescriptors”: [
“status”: “SUCCESS”,
“nwkAddrOfInterest”: 14088,
“_reserved”: 22,
“endpointId”: 1,
“applicationProfileId”: 260,
“applicationDeviceId”: 81,
“applicationDeviceVersion”: 0,
“_reserved1”: 1,
“inputClusters”: [
4,
5,
61184,
0,
60672
“outputClusters”: [
25,
10
“deviceType”: “enddevice”,
“receiveWhenIdle”: false,
“capabilities”: {
“alternatePANCoordinator”: false,
“deviceType”: false,
“powerSourceMains”: false,
“security”: false,
“allocateAddress”: true
“extendedEndpointDescriptors”: {
“1”: {
“clusters”: {
“groups”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“name”: “nameSupport”,
“value”: {
“type”: “Buffer”,
“data”: [
0
“reportingConfiguration”: {
“status”: “NOT_FOUND”,
“direction”: “reported”
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“name”: “clusterRevision”,
“value”: 2,
“scenes”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“acl”: [
“readable”,
“reportable”
“id”: 1,
“acl”: [
“readable”,
“reportable”
“id”: 2,
“acl”: [
“readable”,
“reportable”
“id”: 3,
“acl”: [
“readable”,
“reportable”
“id”: 4,
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2,
“basic”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“name”: “zclVersion”,
“value”: 3
“acl”: [
“readable”,
“reportable”
“id”: 1,
“name”: “appVersion”,
“value”: 80
“acl”: [
“readable”,
“reportable”
“id”: 2,
“name”: “stackVersion”,
“value”: 0
“acl”: [
“readable”,
“reportable”
“id”: 3,
“name”: “hwVersion”,
“value”: 1
“acl”: [
“readable”,
“reportable”
“id”: 4,
“name”: “manufacturerName”,
“value”: “_TZE284_hdml1aav”
“acl”: [
“readable”,
“reportable”
“id”: 5,
“name”: “modelId”,
“value”: “TS0601”
“acl”: [
“readable”,
“reportable”
“id”: 6,
“name”: “dateCode”,
“value”: “”
“acl”: [
“readable”,
“reportable”
“id”: 7,
“name”: “powerSource”,
“value”: “battery”
“acl”: [
“readable”,
“writable”,
“reportable”
“id”: 65502
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2
“acl”: [
“readable”,
“reportable”
“id”: 65534,
“name”: “attributeReportingStatus”,
“value”: “PENDING”
“acl”: [
“readable”,
“reportable”
“id”: 65506
“acl”: [
“readable”,
“reportable”
“id”: 65507
“acl”: [
“readable”,
“writable”,
“reportable”
“id”: 65487
“bindings”: {
“ota”: {},
“time”: {
“attributes”: [
“acl”: [
“readable”
“id”: 65533,
“value”: 1
Same error on contact sensor for me !
Hi dlnraja
Have you got time to search for my SNZB-03 ?
Thank’s
Hello
I’m at work right now I will look at it this night.
I’m a bit busy because, I have started a new job.
Best regards.
For everyone please do diag logs at each issue.
No problem … :grinning_face:
More info on the product :
Manufacturer Model : ZM-35H-Q
I found several link talking about …
Like this : [New device support]: Tuya PIR Motion Sensor ZM-35ZH-Q TS0601 _TZE200_gjldowol · Issue #24085 · Koenkk/zigbee2mqtt · GitHub
Hi Dylan Good morning and congratulations with your new Job, good luck :four_leaf_clover:
Best regards Peter.
Thx :blush:
Hello I want to try the app becourse a have two Soil Humidity Sensors. But i can’t find it in the Appstore only the test version and if i install that one i can’t add devices.
Can someone point me in the right direction ?
Post 1 in this thread:
Install
Stable: Homey App Store · Test: Test Channel · Source: GitHub
Click on this link
And you will be able to install it
https://homey.app/a/com.dlnraja.tuya.zigbee/test/
If device not working go on the app settings on the homey app and select my app and click on diag log and on the description section tell me what’s not working and the device and product information.
Best regards.
Johan is back I saw on github
Dropped v5.11.136 on the test channel just now.
v5.11.132: Implemented batch close/respond state update for improved device management., No new features added in this release., No improvements made in this release., No changes in CI/CD processes.
Covers a huge range of Tuya devices at this point.
