[APP][Pro] Universal TUYA Zigbee Device App - test
Presence Sensor shows incorrect lumen (one is working other is empty) distance is gone. And no values for temp an humidity.
930709bf-cda0-4281-bf88-ccf0665c658a
Ver.5917. Watersensor installs, but no alarm. Contact sensor installs, but in reverse. Trying reverse state, sensor freezer. In Ver. 5843 It was possible to change state internally in sensor.
Contact sensor watersensor.
@dlnraja , thank you for the new release. I have tested version 5.10.1:
Working: button x was pressed, button x was double pressed, button x was long pressed, button x was released after hold.
Not working: button x was tripple pressed. A tripple press triggers ‘Button x was double pressed’ directly followed by a ‘Button x was pressed’. However, judging by the lights in the buttons, that might be a device limitation, not your code :blush:
I don’t need tripple press but in case you want to investigate:
aa9ab027-9a4d-42f1-9e7f-562492c7dadd
App update please try again hopping that the new fix solve the issue
Hi Dylan,
after update to v5.11.3 and re-pairing of the device I did a new interview:
Interview of TS0726 / \\\_TZ3002_pzao9ls1
“ids”: {
“modelId”: “TS0726”,
“manufacturerName”: “_TZ3002_pzao9ls1”
“endpoints”: {
“ieeeAddress”: “a4:c1:38:37:6d:12:06:30”,
“networkAddress”: 33077,
“manufacturerName”: “_TZ3002_pzao9ls1”,
“endpointDescriptors”: [
“status”: “SUCCESS”,
“nwkAddrOfInterest”: 33077,
“_reserved”: 26,
“endpointId”: 1,
“applicationProfileId”: 260,
“applicationDeviceId”: 4,
“applicationDeviceVersion”: 0,
“_reserved1”: 1,
“inputClusters”: [
3,
4,
5,
6,
57344,
57345,
0
“outputClusters”: [
25,
10
“_reserved”: 16,
“endpointId”: 2,
“_reserved1”: 1,
“inputClusters”: [
4,
5,
6,
57345
“outputClusters”: []
“_reserved”: 16,
“endpointId”: 3,
“_reserved1”: 1,
“inputClusters”: [
4,
5,
6,
57345
“_reserved”: 16,
“endpointId”: 4,
“_reserved1”: 1,
“inputClusters”: [
4,
5,
6,
57345
“_reserved”: 10,
“endpointId”: 242,
“applicationProfileId”: 41440,
“applicationDeviceId”: 97,
“_reserved1”: 0,
“inputClusters”: [],
“outputClusters”: [
33
“deviceType”: “router”,
“receiveWhenIdle”: true,
“capabilities”: {
“alternatePANCoordinator”: false,
“deviceType”: true,
“powerSourceMains”: true,
“security”: false,
“allocateAddress”: true
“extendedEndpointDescriptors”: {
“1”: {
“clusters”: {
“identify”: {
“attributes”: []
“groups”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“name”: “nameSupport”,
“value”: {
“type”: “Buffer”,
“data”: [
0
“reportingConfiguration”: {
“status”: “NOT_FOUND”,
“direction”: “reported”
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“name”: “clusterRevision”,
“value”: 2,
“scenes”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“acl”: [
“readable”,
“reportable”
“id”: 1,
“acl”: [
“readable”,
“reportable”
“id”: 2,
“acl”: [
“readable”,
“reportable”
“id”: 3,
“acl”: [
“readable”,
“reportable”
“id”: 4,
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2,
“onOff”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“name”: “onOff”,
“value”: false,
“direction”: “reported”,
“attributeDataType”: 16,
“minInterval”: 0,
“maxInterval”: 300,
“status”: “SUCCESS”
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2,
“acl”: [
“readable”,
“writable”,
“reportable”
“id”: 16385,
“name”: “onTime”,
“value”: 0,
“acl”: [
“readable”,
“writable”,
“reportable”
“id”: 16386,
“name”: “offWaitTime”,
“value”: 0,
“acl”: [
“readable”,
“writable”,
“reportable”
“id”: 32769,
“acl”: [
“readable”,
“writable”,
“reportable”
“id”: 32770,
“acl”: [
“readable”,
“writable”,
“reportable”
“id”: 20480,
“basic”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“name”: “zclVersion”,
“value”: 3
“acl”: [
“readable”,
“reportable”
“id”: 1,
“name”: “appVersion”,
“value”: 85
“acl”: [
“readable”,
“reportable”
“id”: 2,
“name”: “stackVersion”,
“value”: 0
“acl”: [
“readable”,
“reportable”
“id”: 3,
“name”: “hwVersion”,
“value”: 1
“acl”: [
“readable”,
“reportable”
“id”: 4,
“name”: “manufacturerName”,
“value”: “_TZ3002_pzao9ls1”
“acl”: [
“readable”,
“reportable”
“id”: 5,
“name”: “modelId”,
“value”: “TS0726”
“acl”: [
“readable”,
“reportable”
“id”: 6,
“name”: “dateCode”,
“value”: “”
“acl”: [
“readable”,
“reportable”
“id”: 7,
“name”: “powerSource”,
“value”: “mains”
“acl”: [
“readable”,
“writable”,
“reportable”
“id”: 65502
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2
“acl”: [
“readable”,
“reportable”
“id”: 65534,
“name”: “attributeReportingStatus”,
“value”: “PENDING”
“acl”: [
“readable”,
“reportable”
“id”: 65506
“acl”: [
“readable”,
“reportable”
“id”: 65507
“bindings”: {
“ota”: {},
“time”: {
“attributes”: [
“acl”: [
“readable”
“id”: 65533,
“value”: 1
“2”: {
“clusters”: {
“groups”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“value”: {
“type”: “Buffer”,
“data”: [
0
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2,
“scenes”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“acl”: [
“readable”,
“reportable”
“id”: 1,
“acl”: [
“readable”,
“reportable”
“id”: 2,
“acl”: [
“readable”,
“reportable”
“id”: 3,
“acl”: [
“readable”,
“reportable”
“id”: 4,
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2,
“onOff”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“name”: “onOff”,
“value”: false,
“minInterval”: 0,
“maxInterval”: 300,
“status”: “SUCCESS”
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2,
“acl”: [
“readable”,
“writable”,
“reportable”
“id”: 16385,
“name”: “onTime”,
“value”: 0,
“acl”: [
“readable”,
“writable”,
“reportable”
“id”: 16386,
“value”: 0,
“bindings”: {}
“3”: {
“clusters”: {
“groups”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“value”: {
“type”: “Buffer”,
“data”: [
0
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2,
“scenes”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“acl”: [
“readable”,
“reportable”
“id”: 1,
“acl”: [
“readable”,
“reportable”
“id”: 2,
“acl”: [
“readable”,
“reportable”
“id”: 3,
“acl”: [
“readable”,
“reportable”
“id”: 4,
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2,
“onOff”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“name”: “onOff”,
“value”: false,
“minInterval”: 0,
“maxInterval”: 300,
“status”: “SUCCESS”
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2,
“acl”: [
“readable”,
“writable”,
“reportable”
“id”: 16385,
“name”: “onTime”,
“value”: 0,
“acl”: [
“readable”,
“writable”,
“reportable”
“id”: 16386,
“value”: 0,
“bindings”: {}
“4”: {
“clusters”: {
“groups”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“value”: {
“type”: “Buffer”,
“data”: [
0
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2,
“scenes”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“acl”: [
“readable”,
“reportable”
“id”: 1,
“acl”: [
“readable”,
“reportable”
“id”: 2,
“acl”: [
“readable”,
“reportable”
“id”: 3,
“acl”: [
“readable”,
“reportable”
“id”: 4,
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2,
“onOff”: {
“attributes”: [
“acl”: [
“readable”,
“reportable”
“id”: 0,
“name”: “onOff”,
“value”: false,
“minInterval”: 0,
“maxInterval”: 300,
“status”: “SUCCESS”
“acl”: [
“readable”,
“reportable”
“id”: 65533,
“value”: 2,
“acl”: [
“readable”,
“writable”,
“reportable”
“id”: 16385,
“name”: “onTime”,
“value”: 0,
“acl”: [
“readable”,
“writable”,
“reportable”
“id”: 16386,
“value”: 0,
“bindings”: {}
“242”: {
“clusters”: {},
“bindings”: {}
Just in case, i also did a new diag:
2ce2df38-a775-42bf-a517-3354ebdfe4e8
Maybee this helps for a new driver outside from switch_4gang, if necessary.
Best regards, Hartmut
Presence Sensor, doesnt show distance. It does show temperature but that remains at 0° (not supported by device).
69f82041-407f-4305-85a4-0b3daa0e247e
Unfortunately not. Exactly the same problem. Thanks for trying.
Hey @dlnraja
Just checking in to say that you’ve got my button working! I’ve tested single and double presses and they both work perfectly.
There’s no GUI button in the device settings but at the very least, it’s now usable. Thank you!
I have 2 different door/window sensors. Both have the same model ID (TS0203) but different Manufacturers (_TZ3000_okohwwap) and (Zbeacon)
I had requested the TS0203 by _TZ3000_okohwwap a while back now, I can see it listed here Universal Tuya Zigbee - Smart Device Finder but it’s just being added as a generic Zigbee device. Same with the other model.
Happy to share more info if needed!
Humidity is changing, but i see now this is the value related to the distance. So distance is incorrectly reported as humidity
Did I get correctly that this app now also supports Tuya WiFi devices?
I think it should support WiFi devices, but i just tried it and i have some problems to store the API key and secret… so i did not get it to work yet.
Diag log please
Wifi it’s an new experimental features
Please see the rapport:
32709eaf-384c-4779-bec7-3b1532fc5d87
Problem: i cant get to the app settings to fill in the wifi details (like API key, secret, username, etc). When i press App settings the screen remains blank with a spinner in the middle.
When i try to add a wifi sensor via ‘new device’ i do get to the screen to fill in the details, but it keeps spinning when i press scan. When i continue no devices are found.
Similar to @JJ10 the _TZE204_ztqnh5cg presence sensor shows two “lx” brightness values of which one seems to be the human presence. The values displayed did change a lot with the latest releases… sometimes even a non-changing distance was shown.
68414c21-de2b-4fe7-9ce4-8d381fec3157
The values reported I would need some further analysis to understand.
Question: Is it better to remove all my devices from Johan’s app and add them back here? Also, the Wi-Fi devices from Tuya Cloud?
Why change a setup that works? Beware that with this app (Universal TUYA Zigbee Device) you might need to reconnect flows or moods dependent on device connections. It’s not said that you might need to re-pair them with future versions.
It would be great if this developer could work on the original app. The reason I ask is that Johan’s app will no longer receive updates, which could cause problems in the future. Ther ar already Some missing devices. I did not get support for 1 device for mor than 3 years
Its a fork of the original app, I don’t understand your message meaning
