[APP][Pro] Universal TUYA Zigbee Device App - test
Thanx for your effort. Is this fix for the bulb? Because I still get the same error. Maybe it ‘s time to Enjoy the weekend and try another time.
Cheers
In my case there’s a change. Now nothing happens when I move the magnet away from sensor or move it tight to the sensor. i.e. no indication what so ever.
Unfortunately we are at the same point Dylan
The switches moved to scene but without the option of choosing buttons and also with the below error
Motion sensor exactly the same
7fc451ca-ed9a-4997-a070-979118b8e6c2
Thanks again
Eftychis
Does someone know if this sensor wil work in the tuya app?
Tuya ZG-204ZM PIR + 24Ghz human presence sensors ( Tuya ZG-204ZM control via MQTT | Zigbee2MQTT - https://www.zigbee2mqtt.io/devices/ZG-204ZM.html) seems to basically work.
Many thanks for that! - You guys seem to work day and night.
There are however three issues:
  1. Constantly issuing battery warnings
My settings are as follows:
Advanced Settings
Power Source
Battery Powered
Battery Type
AAA
Low Battery Threshold
20
Critical Battery Threshold
10
Enable Battery Notifications
Nein
Battery Report Interval
24
Energy Optimization Mode
Balanced
Show Battery Voltage
Nein
Enable Power Estimation
Nein
Had played around with these setting but didn´t see any change.
Strange, that it exposes this many battery settings…. - Could it be, that some properties are misinterpreted as battery settings while their meaning is actually different (see 3. below)?
This issue is serious because it “spams” the timeline making the device unusable, while the next two issues are more “nice to have”:
  1. Brightness, temperature and humidity are shown although the device does provide brightness only.
  2. The device has nuch more options, which would be nice to have
Thanks a lot it works now, but it works the wrong way around. i.e. it alarms when the magnet is tight to the sensor and no alarm when the magnet is far from the sensor. I do appreciate your hard work. Thanks again.
Hi this one won’t work in the ZigBee app because it’s a WiFi module.
Best regards Peter.
jes, you a totaly right, my bad! i did not look further then the two words APP and TUYA.
lets see if there is another topic to help me connect a tuya wifi device.
The Tuya Cloud app can.
Tuya Smart Temperature And Humidity Sensor working now! Thank you so much for your effort. Enjoy the weekend :slight_smile:
must i modiffy the app to also support wifi without any tuya account or ganeway ( if it’s possible ) ?
Hi Dylan happy :blush: new year :confetti_ball: if it’s possible it would be great to have it all in one app.
It would be mostly appreciated by everyone I think :+1:t2:
Best regards Peter and good luck :crossed_fingers:t2:
If that is possible then it is really appreciated.
i have checked without any tuya account or tuya gateway it’s impoessible
in that case i wil just use the app recomended by @Peter_van_Werkhoven thanks for checking
Hi Dylan
I still cannot use the 4 gang switches to flows as they are different from the previous logic.
Maybe it’s my bad but if someone could help it would be really appreciated!
Motion sensor luminance still changes only when a motion is captured.
thanks again
Eftychis
Okay than that’s it and everyone has to deal and stay with the Tuya Cloud app for Wifi based devices.
And you’ve got already lot’s of work with implementing all the different ZigBee based devices to get them all properly to work.
Have a nice evening and weekend,
Regards Peter.
Still no Aktion detected.
Is it not possible?
Thx!
7cb5ca58-3eff-4b41-922c-020b54fbd3f9
Hi
Tuya ZG-204ZM PIR + 24Ghz human presence sensors ( Tuya ZG-204ZM control via MQTT | Zigbee2MQTT - https://www.zigbee2mqtt.io/devices/ZG-204ZM.html) can be added to Homey as “Presence Sensor Radar” (not “Presence Sensor (Radar)”) just as before.
The “battery spam” is gone but now it unfortunately does also no longer detect motion and is not showing any data at all.
New property “Distance” is shown, which is great. - When checking on Home Assistant, there is a property “static_detection_distance” which, however, is a setting not a measurement for this device.
Non existing/supported properties temperature and humidity are still shown.
This Tuya device is really cool and I am very excited to finally getting it into Homey.
You guys got so close with your incredible pace! :+1:
Is there anything I can do to help you?
Back from holidays, i can now re-testing, sorry for the delay
So the 4 buttons MOES doesn’t work with physical buttons. I have dissociated/associated with no success
The button is recognized but not functional. Only battery and inapp buttons works
Evolution : my flow “when a button is pushed > then send a notification” doesn’t send me a notification every 10mn anymore :blush:
I have made a diag after pressing the buttons (short, double, long) : 5dc85d82-3e2d-4327-82b8-1423186463ab
Thanks a lot for your hard work !
