Hi Dylan, I have a MOES ZC-LS / AM43 blind motor that is not working with Universal Tuya.
Diagnostic code: 1fa26737-2acf-4255-b07d-2f7b65083da5
Manufacturer ID: _TZE200_icka1clh
Product ID: TS0601
The device pairs correctly, but opening/closing does nothing and Homey returns UNSUPPORTED_CLUSTER.
Device type: enddevice
Receive when idle: false
Could you please check the diagnostic and add/fix the driver/fingerprint for this AM43 blind motor?
Thanks!
Hi Dylan Good evening, the Smartbutton is responding now but not very consistent, connected lights are switching on and off or flickering or staying on at 1 Click and dubbele click the first and the second light are switched on or flickering, hold the button is like disco sometimes al the 3 lights are flickering and light 1 stays on, so really weird behavior.
Diagnostic code 048cff91-d453-4659-ae1c-fe94bf4bc50d
And no battery reading.
Thanks again so far and have a nice evening.
Best regards Peter.
Helo @dlnraja, can you see that?
I don’t think I’ve seen anything about that in the new versions.
Thank you very much!
Hi Dylan Good evening, after update to your latest app and reading the changelog where you wrote that you’ve changed things to the Smartbutton I’ve tried to reinstall it after Homey restart but no luck, totally no response and still no battery reading.
And as you see in the screenshot there is never a history tab where you can see the activities.
Diagnostic code 8afffc76-a36c-4588-9714-4e196c50aab3
Thanks so far and good luck with best regards Peter.
Hi Dylan Good morning and great job again Smartbutton is responding and switching normally now 1, 2 click’s and hold works well switching the lights on or off ![]()
Only no battery reading yet and still no History tab there.
App version 9.0.881
Diagnostic code 1e071a86-093b-4d47-8af0-ce2ff5a19680
Thanks and have a great day, best regards Peter.
Hi Dylan Good afternoon, after the new update app keeps crashing.
Diagnostic code
375def7f-d73b-4078-9e87-3ff28e578805
Good luck
Have a nice day, Peter.
app is still crashing after your latest update.
Diagnostic code 8278ec79-cee4-44ea-8697-b3e448bed729
Good luck and thanks again and have a nice day
Regards Peter
Hi @dlnraja , Not sure if there were changes in the meantime, but after adding the device again today, it works. Thanks!
Thanks @dlnraja for the updates. It seems the relay type doesn’t change on its own anymore as long as I don’t update the app, so I’ve disabled automatic updates.
But, when I configure flows, if I try to trigger a flow upon detecting human presence, the trigger doesn’t fire, even though the sensor does indicate that it detects human presence. My impression is that it isn’t interpreting the presence correctly and passing that information to the “presence detected” card.
74e5cae7-dcf6-467d-a019-16e47fc49967
Hi @dlnraja , even though I have updates blocked, the sensor has changed type again and stopped working. It stopped working right around the time a new version was released, even though the app on my Homey hasn’t actually updated… Thanks a lot; let me know if you need me to provide any details. Regards.
Hi @VicHY ,
Homey can flip that radar to “curtain” even when the app doesn’t update (old caps come back from Homey’s store). Blocking updates left you without the heal.
Please unlock updates once, install Test ≥ 9.0.995, then restart the app. Wait 2–3 minutes — if it’s still curtain, remove + re-pair as Presence Sensor Radar.
If it comes back, send diagnostic + the app version shown on the device. Thanks.
Hi @dlnraja
I have created the diags logs using the latest available version (9.0.992). The code is b84526bg-ec5b-45a3-b9e8-23f197401089.
I am not at home right now; I will try testing it this afternoon when I get back.
Thanks for the quick response and the assistance.
Hi @dlnraja
I’m trying to add a Tuya Zigbee thermostatic radiator valve to Universal Tuya Zigbee on Homey Pro.
Device: ZG253 thermostatic radiator valve
Model ID: TS0601
Manufacturer: _TZE284_ogx8u5z6
The device pairs successfully with Homey but Universal Tuya adds it as an unknown/generic Zigbee device.
The Homey interview confirms the Tuya 0xEF00 cluster.
Another _TZE284 TS0601 radiator valve (_TZE284_ne4pikwm) already appears to be supported by the TRV driver, so I’m hoping this variant can be mapped to the same or a similar driver.
I can provide any additional diagnostic/logs needed.
Thanks!
Device interview:
Summary
"ids": {
"modelId": "TS0601",
"manufacturerName": "_TZE284_ogx8u5z6"
"endpoints": {
"ieeeAddress": "a4:c1:38:1b:8c:68:e6:51",
"networkAddress": 40213,
"manufacturerName": "_TZE284_ogx8u5z6",
"endpointDescriptors": [
"status": "SUCCESS",
"nwkAddrOfInterest": 40213,
"_reserved": 22,
"endpointId": 1,
"applicationProfileId": 260,
"applicationDeviceId": 81,
"_reserved1": 1,
"inputClusters": [
4,
5,
61184,
0,
60672
"outputClusters": [
25,
10
"deviceType": "enddevice",
"receiveWhenIdle": false,
"capabilities": {
"alternatePANCoordinator": false,
"deviceType": false,
"powerSourceMains": false,
"security": false,
"allocateAddress": true
"extendedEndpointDescriptors": {
"1": {
"clusters": {
"groups": {
"attributes": [
"acl": [
"readable",
"reportable"
"id": 0,
"dataTypeId": 24,
"name": "nameSupport",
"value": {
"type": "Buffer",
"data": [
0
"reportingConfiguration": {
"status": "NOT_FOUND",
"direction": "reported"
"acl": [
"readable",
"reportable"
"id": 65533,
"dataTypeId": 33,
"name": "clusterRevision",
"value": 2,
"scenes": {
"attributes": [
"acl": [
"readable",
"reportable"
"id": 0,
"dataTypeId": 32,
"acl": [
"readable",
"reportable"
"id": 1,
"dataTypeId": 32,
"acl": [
"readable",
"reportable"
"id": 2,
"dataTypeId": 33,
"acl": [
"readable",
"reportable"
"id": 3,
"dataTypeId": 16,
"acl": [
"readable",
"reportable"
"id": 4,
"dataTypeId": 24,
"acl": [
"readable",
"reportable"
"id": 65533,
"dataTypeId": 33,
"value": 2,
"basic": {
"attributes": [
"acl": [
"readable",
"reportable"
"id": 0,
"dataTypeId": 32,
"name": "zclVersion",
"value": 3
"acl": [
"readable",
"reportable"
"id": 1,
"dataTypeId": 32,
"name": "appVersion",
"value": 77
"acl": [
"readable",
"reportable"
"id": 2,
"dataTypeId": 32,
"name": "stackVersion",
"value": 0
"acl": [
"readable",
"reportable"
"id": 3,
"dataTypeId": 32,
"name": "hwVersion",
"value": 1
"acl": [
"readable",
"reportable"
"id": 4,
"dataTypeId": 66,
"name": "manufacturerName",
"value": "_TZE284_ogx8u5z6"
"acl": [
"readable",
"reportable"
"id": 5,
"dataTypeId": 66,
"name": "modelId",
"value": "TS0601"
"acl": [
"readable",
"reportable"
"id": 6,
"dataTypeId": 66,
"name": "dateCode",
"value": ""
"acl": [
"readable",
"reportable"
"id": 7,
"dataTypeId": 48,
"name": "powerSource",
"value": "battery"
"acl": [
"readable",
"writable",
"reportable"
"id": 65502,
"dataTypeId": 32
"acl": [
"readable",
"reportable"
"id": 65533,
"dataTypeId": 33,
"value": 2
"acl": [
"readable",
"reportable"
"id": 65534,
"dataTypeId": 48,
"name": "attributeReportingStatus",
"value": "PENDING"
"acl": [
"readable",
"reportable"
"id": 65506,
"dataTypeId": 32
"acl": [
"readable",
"reportable"
"id": 65507,
"dataTypeId": 72
"acl": [
"readable",
"writable",
"reportable"
"id": 65487,
"dataTypeId": 33
"bindings": {
"ota": {
"attributes": [
"acl": [
"readable"
"id": 0,
"dataTypeId": 240,
"name": "upgradeServerID",
"value": "ff:ff:ff:ff:ff:ff:ff:ff"
"acl": [
"readable"
"id": 1,
"dataTypeId": 35,
"name": "fileOffset",
"value": 4294967295
"acl": [
"readable"
"id": 2,
"dataTypeId": 35,
"name": "currentFileVersion",
"value": 77
"acl": [
"readable"
"id": 3,
"dataTypeId": 33,
"name": "currentZigBeeStackVersion",
"value": 2
"acl": [
"readable"
"id": 4,
"dataTypeId": 35,
"name": "downloadedFileVersion",
"value": 4294967295
"acl": [
"readable"
"id": 5,
"dataTypeId": 33,
"name": "downloadedZigBeeStackVersion",
"value": 65535
"acl": [
"readable"
"id": 6,
"dataTypeId": 48,
"name": "imageUpgradeStatus",
"value": "normal"
"acl": [
"readable"
"id": 7,
"dataTypeId": 33,
"name": "manufacturerID",
"value": 4417
"acl": [
"readable"
"id": 8,
"dataTypeId": 33,
"name": "imageTypeID",
"value": 65535
"acl": [
"readable"
"id": 9,
"dataTypeId": 33,
"name": "minimumBlockPeriod",
"value": 0
"acl": [
"readable"
"id": 65533,
"dataTypeId": 33,
"value": 3
"time": {
"attributes": [
"acl": [
"readable"
"id": 65533,
"dataTypeId": 33,
"value": 1
Please consider using the following to increase readability of your post:
- Preformatted text option to keep the output in the original format and presented in a scrollable window. This reduces the length of your post.
- Hide details option, to collapse/hide the entire interview output. Clicking the collapsed item will show the interview output again.
Hi @dlnraja , I tried deleting the app and installing a new version (9.0.1016).
I re-added the devices and noticed that they are now recognized with some additional data. Initially, it seems to detect presence, motion, brightness, and detection distance.
Shortly after, however, it stops detecting presence and motion; while brightness and distance readings might change slightly if you enter the bathroom or turn on a light, the variation is minimal and doesn’t seem to reflect reality.
For the time being, at least, it appears the sensor isn’t updating, and the type is switching to “curtain.”
The code is:
546914c2-3bb9-442e-87bd-bdc0a5777
Thank you so much
Hi again @dlnraja
, the sensor has updated and is now performing worse. I have them installed in two bathrooms, but only one has updated (the one that had been synchronized the longest). The button to turn the sensor on or off has disappeared, as you can see in the images showing both units.
I am also attaching an image showing the data it captures. It constantly detects presence and motion, even when no one is there.
The code is:
8d9d0199-4da0-47c8-9788-6af5a827dff4.
Thanks again.
Hi @VicHY,
The behavior you are describing actually points to two distinct issues overlapping—a Homey cache bug, and the physical calibration of the MTG075 radar itself. Here are a few investigation tracks to help us isolate the problem:
The “Curtain” Type Bug: As mentioned earlier, Homey sometimes pulls old cached capabilities, forcing the device to switch to a curtain controller. If it stays as a curtain after updating to the latest test version and waiting a few minutes, you will need to remove and re-pair it specifically as a “Presence Sensor Radar” to force the correct driver to load.
Stuck in “Occupied” Mode: When you mention it stops detecting presence/motion while lux and distance still fluctuate slightly, it highly suggests the sensor is actually stuck in the “Occupied” (Presence = true) state. Because it never returns to “Unoccupied”, it cannot trigger any new presence or motion events in Homey.
Bathroom Environmental Interference: Bathrooms are notoriously tricky for mmWave radars. The MTG075 is extremely sensitive to micro-movements. An exhaust fan (even behind a plastic cover), a vibrating shower screen, or moving water can easily keep the radar locked in a continuous “Occupied” state.
Calibration Check: Once you have it properly paired again and displaying the correct UI, check if the presence alarm remains stuck on “Yes”. I recommend temporarily lowering the Radar Sensitivity and reducing the Departure Delay (Keep Time) in the advanced settings. You might also want to test the sensor in a standard, quiet room first to confirm it clears presence correctly outside of the bathroom environment.
Let me know how it behaves once re-paired and with these settings tweaked!
Looking at GitHub issues for this specific Tuya mmWave sensor (like the _TZE204_dtzziy1e or MTG075), your exact symptom—Lux and distance updating, but presence stuck/frozen—is a very common hardware quirk. Here is what usually causes it:
Tuya MCU Freeze: Sometimes the internal chip crashes (often after a power fluctuation). The sensor keeps sending Lux data, but the radar module stops processing presence. Fix: Unplug the sensor from power entirely for 2-3 minutes, plug it back in, and check if it resets.
Ghost Presence / Over-sensitivity: Users on other hubs report that default sensitivity settings (usually 7-9) are too high. It picks up micro-movements (like an exhaust fan or a towel moving) and resets the “Departure Delay” timer every second, meaning it never reaches “Clear”. Fix: Lower the
Radar Sensitivityto 3 or 4, and decrease theDeparture Delayto 5 seconds for testing. -
Zigbee Flooding: These sensors are notoriously “chatty” and update distance/lux every second. Sometimes the Zigbee coordinator misses the crucial “Presence Cleared” message because of network saturation
I will try to implemente a massive stability update for Tuya mmWave Radars (MTG075 / ZG-204 etc.)
Tuya’s hardware is notoriously chatty and sometimes crashes internally. This new release introduces an ‘Ultimate Software Shield’:
Anti-Spam Filter: Throttles distance/lux updates to prevent your Homey Zigbee mesh from crashing.
Auto-Restore: Automatically pushes your settings back to the sensor if it loses power and resets its brain to 0.
Software Watchdog: If the sensor gets stuck in ‘Occupied’ mode and fails to send a clear signal, the app will now automatically clear the presence based on your departure delay setting.
Emergency Clear: Added a new Flow card to manually clear presence if the bathroom exhaust fan is messing with the sensor!"*
Good morning @dlnraja,
First of all, thank you very much for your effort and patience.
This morning I installed the latest version (9.0.1037), and I had to use the Repair option on both sensors before they updated correctly.
I tested them afterwards, and only one of the bathrooms was detecting presence properly. On the other sensor, the Human Presence and Motion parameters were continuously showing “No”, even though both bathrooms have exactly the same configuration.
I ran the Repair process again, and for now both sensors seem to be detecting motion and presence correctly. They have been working for a couple of hours without issues.
I’m not at home right now, but at least I can see that neither of them has switched back to Curtain mode yet.
I’ve also noticed that the illuminance and distance detection values now seem to be correct. Previously, even with the bathroom lights on, the sensor would report only 1 or 2 lux instead of well over 100 lux, which would be expected. The same happened with distance: I could stand right next to the sensor and it would report that I was 3 meters or more away, which is impossible because the bathroom is smaller than that.
As you mentioned, these sensors are very difficult to calibrate. However, whenever they are working correctly, before eventually switching to Curtain mode, they perform quite well. It took me some time, but I believe I now have the sensitivity and the rest of the parameters more or less dialed in, although I will probably need to make a few more adjustments.
All my testing has been done with the bathroom door closed, nobody inside, the exhaust fan turned off, and the air conditioning unit switched off, so there should be no environmental interference. Also, as I mentioned, the sensors work correctly whenever I manage to keep them in the proper mode.
I currently have the following settings on both sensors:
- Radar Sensitivity: 5
- Detection Range: 3 m
- Departure Delay: 20 s
- Entry Sensitivity: 6
- Illuminance Threshold: 50 lux
Regarding Zigbee saturation, it is certainly possible. I have considered that as well because I have many Zigbee devices. However, I tried reducing the load on the network by removing a large number of Zigbee lighting relays, effectively cutting the network load roughly in half, and I did not notice any improvement.
As for the upcoming update, please let me know when it is available and I will be happy to test it and share my results.
Thanks again!
