[APP][Pro] Universal TUYA Zigbee Device App - test
Hi Cam,
Thanks for the diagnostic! I reviewed log `5d3e1a5d-701b-4273-9fd8-2e8ffcfbf2ee`. The app initialization is clean (all 183 drivers loaded), but I need more info to diagnose your **button** and **motion sensor**.
### What I Need
**1. Manufacturer IDs** (crucial for support):
For each device:
1. Homey → Settings → Devices → [Your Device]
2. :gear: Settings → Advanced → Zigbee information
3. Copy `manufacturerName` (e.g., `_TZ3000_xabckq1v`, `TS0042`)
4. Share here
**2. Better Diagnostic** (current one only shows startup):
1. Homey → Settings → Apps → Universal Tuya Zigbee → Diagnostics
2. **Before submitting:**
  • Press button 3-4 times
  • Wave at motion sensor
  • Wait 30s
3. Submit with message: “Testing button + motion”
4. Share new log ID
**3. Symptoms:**
- Button: Paired? Battery shown? What happens when pressed?
- Motion: Paired? `alarm_motion` capability exists? Detects motion?
### Quick Fixes to Try First
**Button:**
1. Factory reset (hold 5s → LED blinks fast)
2. Re-pair within 2m of Homey
3. Use correct driver:
  • 1-button → `wireless_switch_1gang_cr2032`
  • 2-button → `wireless_switch_2gang_cr2032`
  • 4-button → `wireless_switch_4gang_cr2032`
**Motion Sensor:**
1. Factory reset (battery out 10s → hold button 5s)
2. **During pairing:** Stay 2m from Homey, wait 60s (IAS Zone enrollment)
  • PIR only → `motion_sensor_battery`
  • PIR + temp → `motion_sensor_temp_humid_battery`
  • mmWave → `motion_sensor_mmwave_battery`
**TS0601 devices:** v3.0.35 fixed TS0601 init—if your devices are TS0601, re-pair them.
### Resources
- **IAS Zone Fix:** https://github.com/dlnraja/com.tuya.zigbee/blob/master/docs/fixes/PETER_IAS_ZONE_FIX_COMPLETE.md
- **Device Request:** Sign in to GitHub · GitHub
Once you share manufacturer IDs + new diagnostic, I can pinpoint the issue!
Best,
Dylan
## Follow-Up Actions
### Check Support
```bash
# When user provides manufacturer ID
grep -r “_TZ3000_XXXXXX” drivers/
### If Not Supported
1. Add ID to appropriate driver
2. Test locally
3. Release patch
4. Notify user
### Common Issues
- **Button:** Wrong driver, missing endpoints, battery
- **Motion:** IAS Zone not enrolled, wrong driver, battery
