[APP][Pro] Universal TUYA Zigbee Device App - test
Hi @ugrbnk,
Thank you for testing! I see the sensor is detecting smoke physically (alarm sounds), but the data isn’t reaching Homey. Let me help you troubleshoot this step by step.
## :magnifying_glass_tilted_left: Current Status
Based on your screenshot and description:
- :white_check_mark: Device paired successfully
- :white_check_mark: Physical alarm works (sounds when you smoke it)
- :cross_mark: **No data transmitted to Homey**
- :cross_mark: Tiles show no alarm status
This indicates the sensor hardware works fine, but there’s a **communication issue** between the sensor and Homey.
## :hammer_and_wrench: TROUBLESHOOTING STEPS
### Step 1: Verify App Version
**Current requirement:** v3.0.17 or newer
Check your app version:
1. Homey app → **More****Apps**
2. Find **Universal Tuya Zigbee**
3. Current version shown at top
**If you’re on v3.0.16 or older:**
- Update to v3.0.17+ immediately
- v3.0.17 includes the Tuya cluster handler fix specifically for your gas sensor!
### Step 2: Re-Pair the Device (CRITICAL)
Even if you updated the app, the sensor needs to be re-paired to use the new handler.
**How to re-pair:**
1. **Remove device from Homey:**
  • Go to device tile
  • Settings (:gear:) → Advanced Settings
  • Remove Device
2. **Factory reset the sensor:**
  • Press and hold the reset button for **10 seconds**
  • LED should blink rapidly (indicating reset mode)
  • If no LED blinks, try removing battery for 30 seconds, then reinsert
3. **Add device back:**
  • Homey → Add Device
  • Universal Tuya Zigbee
  • Search for: **“Gas Sensor TS0601 (AC)”**
  • Keep sensor **very close** to Homey during pairing (< 1 meter)
  • Wait 30-60 seconds for pairing
4. **Wait for initialization:**
  • After pairing, wait **2-3 minutes**
  • The Tuya cluster handler needs time to initialize
  • Check Homey logs for confirmation
### Step 3: Check Homey Logs
This is crucial to see if data is being received:
1. **Open Homey Developer Tools:**
2. **Open Logs:**
  • Click **System****Logs**
  • Or go to: Settings → System → Logs
3. **Look for these messages:**
:white_check_mark: GOOD SIGNS:
[TuyaCluster] Initializing for type: GAS_DETECTOR
[TuyaCluster] :white_check_mark: Found on endpoint 1
[TuyaCluster] :white_check_mark: Tuya cluster found on endpoint 1
[TuyaCluster] :white_check_mark: Reporting configured
[TuyaCluster] :package: DataPoints received: {“1”:false,“13”:false}
[TuyaCluster] Processing DP 1 (gas_alarm): false
[TuyaCluster] :white_check_mark: alarm_smoke = false
:cross_mark: BAD SIGNS:
[TuyaCluster] No Tuya cluster found on any endpoint
[TuyaCluster] :warning: No dataPoints in response
Cannot find module ‘../../utils/tuya-cluster-handler’
4. **Test the sensor:**
  • While watching logs, make smoke near sensor
  • Physical alarm should sound
  • **Watch logs for datapoint changes:**
    [TuyaCluster] Processing DP 1 (gas_alarm): true
    [TuyaCluster] :white_check_mark: alarm_smoke = true
### Step 4: Verify Device Driver
Make sure the correct driver was selected:
1. Go to device settings
2. Check **Driver:** should show **“Gas Sensor TS0601 (AC)”**
3. If it shows something else, remove and re-pair with correct driver
### Step 5: Check Zigbee Network
If still no data after re-pairing:
1. **Check Zigbee mesh quality:**
  • Settings → Zigbee → Network Map
  • Find your gas sensor
  • Check signal quality (should be green/good)
2. **Improve mesh if needed:**
  • Add Zigbee router between Homey and sensor
  • Or move sensor closer to Homey
  • AC-powered devices act as routers automatically
3. **Check for interference:**
  • Move away from WiFi router (2.4GHz interference)
  • Move away from microwave, baby monitors
  • Avoid metal walls/objects between Homey and sensor
## :microscope: DIAGNOSTIC REQUEST
If still not working after all steps above, please provide:
### 1. Device Diagnostic Report
**How to generate:**
1. Go to gas sensor device page
2. Settings (:gear:) → Advanced Settings
3. **“Create Diagnostic Report”**
4. Copy the diagnostic ID
5. Post it here
### 2. Homey Logs
**After testing smoke:**
1. Make smoke near sensor
2. Wait 30 seconds
3. Copy logs from last 1 minute
4. Post here (or pastebin if long)
### 3. App Version Confirmation
Please confirm:
- Universal Tuya Zigbee version: **?**
- Homey firmware version: **?**
- When did you last update the app?
## :bullseye: EXPECTED BEHAVIOR
**After fixes in v3.0.17:**
When smoke is detected:
Physical sensor:
:white_check_mark: Alarm sounds (beeping)
:white_check_mark: LED flashes red
Homey side:
:white_check_mark: Device tile shows “ALARM: Smoke detected!”
:white_check_mark: alarm_smoke capability = true
:white_check_mark: Flow triggers fire
:white_check_mark: Notifications sent (if configured)
:white_check_mark: Timeline shows event
When smoke clears:
Physical sensor:
:white_check_mark: Alarm stops
:white_check_mark: LED back to normal
Homey side:
:white_check_mark: Device tile shows “OK”
:white_check_mark: alarm_smoke capability = false
:white_check_mark: Timeline shows “Alarm cleared”
## :sos_button: KNOWN ISSUES & WORKAROUNDS
### Issue 1: Delayed Updates
**Symptom:** Data arrives 30-60 seconds late
**Cause:** Tuya reporting interval
**Solution:**
- This is normal for battery-optimized sensors
- Your gas sensor is AC-powered, so should be faster
- If delayed, check Zigbee mesh quality
### Issue 2: First Alarm Missed
**Symptom:** First alarm doesn’t trigger, subsequent ones work
**Cause:** Initial datapoint not read
**Solution:**
- Re-pair device
- Wait 3 minutes after pairing
- Test second time
### Issue 3: Sensor Goes “Unavailable”
**Symptom:** Device shows unavailable in Homey
**Cause:** Poor Zigbee connection
**Solution:**
- Improve Zigbee mesh
- Check power supply (AC adapter working?)
- Restart Homey as last resort
## :books: TECHNICAL DETAILS
### How Tuya Gas Sensors Work
Your sensor uses **Tuya proprietary protocol**:
- Cluster: **0xEF00 (61184)**
- Datapoints:
  • **DP 1:** Gas alarm (boolean)
  • **DP 13:** CO alarm (boolean)
  • **DP 2:** Sensitivity setting
The v3.0.17 handler automatically:
1. Detects Tuya cluster on endpoint 1
2. Configures reporting (0-3600s intervals)
3. Listens for datapoint changes
4. Maps DP1 → alarm_smoke
5. Maps DP13 → alarm_co
6. Updates Homey capabilities
7. Triggers flows
### Why Re-Pairing is Important
When you pair a device:
- Driver loads and initializes
- Cluster bindings created
- Reporting configured
- Initial state read
If you updated the app but didn’t re-pair:
- Old driver still loaded
- New Tuya handler not initialized
- No cluster bindings
- No data reception
**Solution:** Always re-pair after major app updates!
## :white_check_mark: CHECKLIST
Before reporting still not working:
- Confirmed app version is v3.0.17 or newer
- Removed device from Homey
- Factory reset sensor (10s button press)
- Re-paired with correct driver
- Waited 3 minutes after pairing
- Checked Homey logs during test
- Tested smoke detection (alarm sounds physically)
- Checked Zigbee mesh quality
- Verified AC power connected
- Generated diagnostic report
- Copied logs to post
## :light_bulb: NEXT STEPS
1. **Check your app version** (most important!)
2. **Re-pair the device** (critical step)
3. **Test and watch logs**
4. **Report back with:**
  • App version
  • Log output
  • Diagnostic ID (if still not working)
I’m confident this will work after re-pairing with v3.0.17+. The Tuya cluster handler was specifically created to fix your exact issue!
Let me know how it goes! :rocket:
Best regards,
Dylan
Universal Tuya Zigbee Developer
**Related:**
- Fix commit: v3.0.17 - Tuya cluster handler created
- Technical doc: `docs/forum/RESPONSE_UGRBNK_GAS_SENSOR_FIX.md`
- Handler code: `utils/tuya-cluster-handler.js`
**Links:**
- GitHub: GitHub - dlnraja/com.tuya.zigbee: new updated version
- App Store: https://homey.app/a/com.dlnraja.tuya.zigbee/
