[APP][Pro] Tuya Zigbee App - Device Request Archive
Hello Johan,
first of all thank you for the great work here on adding new items.
I would like to check the status of 4 gang scene switch TS004F / TZ3000_xabckq1v. Maybe it is still on your todo list but I tried one (TS0044) from TEST app and it is not working for my switch (device interview below).
Link to amazon item:
It seems that manufacturer changed something with upgrade from TS0044 to TS004F.
I could find some comments in different forums reporting some issues / discrepancies between these two products. (Ex. […TS004F has a very different format of messages compared to TS0044. It seems to only have one endpoint active at start (instead of 4 on the TS0044). And that one endpoint seems to be tied to all of the 4 keys, whereas the old one had 4 separate for every key…])
Thank you in advance for any help.
  "ids": {
    "modelId": "TS004F",
    "manufacturerName": "_TZ3000_xabckq1v"
  "endpoints": {
    "endpointDescriptors": [
        "endpointId": 1,
        "applicationProfileId": 260,
        "applicationDeviceId": 260,
        "_reserved1": 1,
        "inputClusters": [
          0,
          1,
          3,
          4,
          6,
          4096
        "outputClusters": [
          25,
          10,
          3,
          4,
          5,
          6,
          8,
          4096
    "endpoints": {
      "1": {
        "clusters": {
          "basic": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "zclVersion",
                "value": 3,
                "reportingConfiguration": {
                  "status": "NOT_FOUND",
                  "direction": "reported"
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "name": "appVersion",
                "value": 65,
                  "direction": "reported",
                  "attributeDataType": 32,
                  "minInterval": 1,
                  "maxInterval": 65534,
                  "minChange": 0,
                  "status": "SUCCESS"
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "name": "stackVersion",
                "value": 0,
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "name": "hwVersion",
                "value": 1,
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "name": "manufacturerName",
                "value": "_TZ3000_xabckq1v",
                "acl": [
                  "readable",
                  "reportable"
                "id": 5,
                "name": "modelId",
                "value": "TS004F",
                "acl": [
                  "readable",
                  "reportable"
                "id": 6,
                "name": "dateCode",
                "value": "",
                "acl": [
                  "readable",
                  "reportable"
                "id": 7,
                "name": "powerSource",
                "value": "battery",
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 65502,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "name": "clusterRevision",
                "value": 2,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65534,
                "name": "attributeReportingStatus",
                "value": "PENDING",
                "acl": [
                  "readable",
                  "reportable"
                "id": 65504,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65505,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65506,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65507,
            "commandsGenerated": "UNSUP_GENERAL_COMMAND",
            "commandsReceived": "UNSUP_GENERAL_COMMAND"
          "powerConfiguration": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0
                "acl": [
                  "readable",
                  "reportable"
                "id": 32,
                "name": "batteryVoltage"
                "acl": [
                  "readable",
                  "reportable"
                "id": 33,
                "name": "batteryPercentageRemaining"
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
          "identify": {},
          "groups": {},
          "onOff": {},
          "touchlink": {}
        "bindings": {
          "identify": {},
          "groups": {},
          "onOff": {},
          "touchlink": {},
          "ota": {},
          "time": {},
          "scenes": {},
          "levelControl": {}
Hello Johan
Thanx for your great work. A couple of tuya items run smootly.
But i now have a door sensor tuya not working, could you add it?
Many thanx.
Riny
CENTECHIA
ZM-CG205
  "ids": {
    "modelId": "TS0203",
    "manufacturerName": "_TYZB01_xph99wvr"
  "endpoints": {
        "endpointId": 1,
        "applicationDeviceId": 1026,
        "_reserved1": 1,
        "inputClusters": [
          0,
          3,
          1,
          1280
        "outputClusters": [
          0,
          3,
          1,
          1280
    "endpoints": {
      "1": {
        "clusters": {
          "basic": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 0,
                "acl": [
                  "readable"
                "id": 1,
                "acl": [
                  "readable"
                "id": 3,
                "name": "hwVersion"
                "acl": [
                  "readable"
                "id": 4,
                "acl": [
                  "readable"
                "id": 5,
                "name": "modelId"
                "acl": [
                  "readable"
                "id": 6,
                "name": "dateCode"
                "acl": [
                  "readable"
                "id": 7,
                "acl": [
                  "readable",
                  "writable"
                "id": 16,
                "name": "locationDesc"
                "acl": [
                  "readable",
                  "writable"
                "id": 17,
                "name": "physicalEnv"
                "acl": [
                  "readable",
                  "writable"
                "id": 18,
                "name": "deviceEnabled"
                "acl": [
                  "readable"
                "id": 65533,
          "identify": {},
            "commandsGenerated": []
          "iasZone": {}
        "bindings": {
          "basic": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 0,
                "acl": [
                  "readable"
                "id": 1,
                "acl": [
                  "readable"
                "id": 3,
                "name": "hwVersion"
                "acl": [
                  "readable"
                "id": 4,
                "acl": [
                  "readable"
                "id": 5,
                "name": "modelId"
                "acl": [
                  "readable"
                "id": 6,
                "name": "dateCode"
                "acl": [
                  "readable"
                "id": 7,
                "acl": [
                  "readable",
                  "writable"
                "id": 16,
                "acl": [
                  "readable",
                  "writable"
                "id": 17,
                "acl": [
                  "readable",
                  "writable"
                "id": 18,
                "acl": [
                  "readable"
                "id": 65533,
          "identify": {},
          "iasZone": {}
I just reveived a nedis motion sensor (Tuya). Hereafter the information from the interview. Adding this device would be appreciated
  "ids": {
    "modelId": "RH3040",
    "manufacturerName": "TUYATEC-bd5faf9p"
  "endpoints": {
        "endpointId": 1,
        "_reserved1": 0,
        "inputClusters": [
          0,
          1,
          3,
          1280
        "outputClusters": []
    "endpoints": {
      "1": {
        "clusters": {
          "basic": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "value": 1
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "value": 72
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "value": 0
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "value": 1
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "value": "TUYATEC-bd5faf9p"
                "acl": [
                  "readable",
                  "reportable"
                "id": 5,
                "name": "modelId",
                "value": "RH3040"
                "acl": [
                  "readable",
                  "reportable"
                "id": 6,
                "name": "dateCode",
                "value": "20180512"
                "acl": [
                  "readable",
                  "reportable"
                "id": 7,
                "value": "battery"
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 1
            "commandsGenerated": [],
            "commandsReceived": [
              "factoryReset"
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0
                "acl": [
                  "readable",
                  "reportable"
                "id": 32,
                "name": "batteryVoltage",
                "value": 30
                "acl": [
                  "readable",
                  "reportable"
                "id": 33,
                "name": "batteryPercentageRemaining",
                "value": 200
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 1
            "commandsReceived": []
          "identify": {
            "attributes": [
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 0
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 1
              0
              0,
              1
          "iasZone": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "zoneState",
                "value": "notEnrolled"
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "name": "zoneType",
                "value": "motionSensor"
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 2,
                "name": "zoneStatus"
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 16,
                "name": "iasCIEAddress",
                "value": "00:00:00:00:00:00:00:00"
                "acl": [
                  "readable",
                  "reportable"
                "id": 17,
                "name": "zoneId",
                "value": 255
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 1
              "zoneStatusChangeNotification",
              1
        "bindings": {}
Hi Johan,
Cn you make this door and window sensor working please?
  "ids": {
    "manufacturerName": "_TZ3000_2mbfxlzr"
  "endpoints": {
        "endpointId": 1,
        "_reserved1": 1,
        "inputClusters": [
          1,
          3,
          1280,
          0
        "outputClusters": [
          25,
          10
    "endpoints": {
      "1": {
        "clusters": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "acl": [
                  "readable",
                  "reportable"
                "id": 32,
                "value": 30,
                "acl": [
                  "readable",
                  "reportable"
                "id": 33,
                "value": 200,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 1,
          "identify": {
            "attributes": []
          "iasZone": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "value": "notEnrolled",
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "name": "zoneType",
                "value": "contactSwitch",
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "name": "zoneStatus",
                "value": {
                  "type": "Buffer",
                  "data": [
                    0,
                    0
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 16,
                "value": "ec:1b:bd:ff:fe:68:d9:a5",
                "acl": [
                  "readable",
                  "reportable"
                "id": 17,
                "name": "zoneId",
                "value": 8,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 1,
          "basic": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "value": 3
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "value": 67
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "value": 0
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "value": 1
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "value": "_TZ3000_2mbfxlzr"
                "acl": [
                  "readable",
                  "reportable"
                "id": 5,
                "name": "modelId",
                "value": "TS0203"
                "acl": [
                  "readable",
                  "reportable"
                "id": 6,
                "name": "dateCode",
                "value": ""
                "acl": [
                  "readable",
                  "reportable"
                "id": 7,
                "value": "battery"
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 65502
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2
                "acl": [
                  "readable",
                  "reportable"
                "id": 65534,
                "value": "PENDING"
                "acl": [
                  "readable",
                  "reportable"
                "id": 65506
                "acl": [
                  "readable",
                  "reportable"
                "id": 65507
        "bindings": {
          "ota": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 0
                "acl": [
                  "readable"
                "id": 1
                "acl": [
                  "readable"
                "id": 2
                "acl": [
                  "readable"
                "id": 3
                "acl": [
                  "readable"
                "id": 4
                "acl": [
                  "readable"
                "id": 5
                "acl": [
                  "readable"
                "id": 6
                "acl": [
                  "readable"
                "id": 7
                "acl": [
                  "readable"
                "id": 8
                "acl": [
                  "readable"
                "id": 9
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
          "time": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
Hi Johan,
Another Door Window Sensor (“TS0203”, “_TZ3000_402jjyro”) that I hope you could add support for:
  "ids": {
    "manufacturerName": "_TZ3000_402jjyro"
  "endpoints": {
        "endpointId": 1,
        "_reserved1": 1,
        "inputClusters": [
          0,
          1,
          3,
          1280
        "outputClusters": [
          25,
          10
    "endpoints": {
      "1": {
        "clusters": {
          "basic": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "value": 3,
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "value": 69,
                  "minInterval": 1,
                  "maxInterval": 14400,
                  "minChange": 0,
                  "status": "SUCCESS"
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "value": 0,
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "value": 1,
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "value": "_TZ3000_402jjyro",
                "acl": [
                  "readable",
                  "reportable"
                "id": 5,
                "name": "modelId",
                "value": "TS0203",
                "acl": [
                  "readable",
                  "reportable"
                "id": 6,
                "name": "dateCode",
                "value": "",
                "acl": [
                  "readable",
                  "reportable"
                "id": 7,
                "value": "battery",
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 65502,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65534,
                "value": "PENDING",
                "acl": [
                  "readable",
                  "reportable"
                "id": 65504,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65505,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65506,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65507,
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "acl": [
                  "readable",
                  "reportable"
                "id": 32,
                "value": 30,
                  "minInterval": 65535,
                  "minChange": 0,
                  "status": "SUCCESS"
                "acl": [
                  "readable",
                  "reportable"
                "id": 33,
                "value": 200,
                  "minChange": 0,
                  "status": "SUCCESS"
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 1,
          "identify": {
            "attributes": [
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 0,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 1,
          "iasZone": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "name": "zoneType",
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "value": {
                  "type": "Buffer",
                  "data": [
                    1,
                    0
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 16,
                "value": "00:00:00:00:00:00:00:00",
                "acl": [
                  "readable",
                  "reportable"
                "id": 17,
                "name": "zoneId",
                "value": 255,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 1,
        "bindings": {
          "ota": {
            "attributes": [],
          "time": {
            "attributes": [],
A second request from me to add an unsupported device (“TS0601”, "_TZE200_jthf7vb6), this time for a Smart Water Leak Alarm. Interviewing took quite some time, but fortunately I had found an explanation from you/Johan to be patient :slight_smile:
  "ids": {
    "modelId": "TS0601",
    "manufacturerName": "_TZE200_jthf7vb6"
  "endpoints": {
        "endpointId": 1,
        "applicationDeviceId": 81,
        "_reserved1": 1,
        "inputClusters": [
          0,
          4,
          5,
          61184
        "outputClusters": [
          25,
          10
    "endpoints": {
      "1": {
        "clusters": {
          "basic": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "value": 3
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "value": 70
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "value": 0
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "value": 1
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "value": "_TZE200_jthf7vb6"
                "acl": [
                  "readable",
                  "reportable"
                "id": 5,
                "name": "modelId",
                "value": "TS0601"
                "acl": [
                  "readable",
                  "reportable"
                "id": 6,
                "name": "dateCode",
                "value": ""
                "acl": [
                  "readable",
                  "reportable"
                "id": 7,
                "value": "battery"
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 65502
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2
                "acl": [
                  "readable",
                  "reportable"
                "id": 65534,
                "value": "PENDING"
                "acl": [
                  "readable",
                  "reportable"
                "id": 65504
                "acl": [
                  "readable",
                  "reportable"
                "id": 65505
                "acl": [
                  "readable",
                  "reportable"
                "id": 65506
                "acl": [
                  "readable",
                  "reportable"
                "id": 65507
          "groups": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "nameSupport"
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
          "scenes": {
        "bindings": {
          "ota": {
          "time": {
            "attributes": [],
Neo Coolcam Siren:
  "ids": {
    "manufacturerName": "_TZE200_d0yu2xgi"
  "endpoints": {
        "endpointId": 1,
        "_reserved1": 1,
        "inputClusters": [
          0,
          4,
          5,
          61184
        "outputClusters": [
          25,
          10
    "endpoints": {
      "1": {
        "clusters": {
          "basic": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "value": 3
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "value": 83
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "value": 0
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "value": 1
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "value": "_TZE200_d0yu2xgi"
                "acl": [
                  "readable",
                  "reportable"
                "id": 5,
                "name": "modelId",
                "value": "TS0601"
                "acl": [
                  "readable",
                  "reportable"
                "id": 6,
                "name": "dateCode",
                "value": ""
                "acl": [
                  "readable",
                  "reportable"
                "id": 7,
                "value": "battery"
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 65502
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2
                "acl": [
                  "readable",
                  "reportable"
                "id": 65534,
                "value": "PENDING"
                "acl": [
                  "readable",
                  "reportable"
                "id": 65504
                "acl": [
                  "readable",
                  "reportable"
                "id": 65505
                "acl": [
                  "readable",
                  "reportable"
                "id": 65506
                "acl": [
                  "readable",
                  "reportable"
                "id": 65507
          "groups": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "nameSupport",
                "value": {
                  "type": "Buffer",
                  "data": [
                    0
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2
          "scenes": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0
                "acl": [
                  "readable",
                  "reportable"
                "id": 1
                "acl": [
                  "readable",
                  "reportable"
                "id": 2
                "acl": [
                  "readable",
                  "reportable"
                "id": 3
                "acl": [
                  "readable",
                  "reportable"
                "id": 4
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2
        "bindings": {
          "ota": {
            "attributes": [],
          "time": {
            "attributes": [],
Pairing:
  1. Hold Pairing button for 5sek
  2. Click pairing button one more time
To wake up to get interviewed i had to click pairing one time.
Hi Johan!
Even more work for you. Tuya plug from aliexpress.
Thanks in advance
  "ids": {
    "modelId": "SA-003-Zigbee",
    "manufacturerName": "eWeLink"
  "endpoints": {
        "endpointId": 1,
        "applicationProfileId": 49246,
        "applicationDeviceId": 16,
        "_reserved1": 1,
        "inputClusters": [
          0,
          3,
          4,
          5,
          6
        "outputClusters": [
          0
    "endpoints": {
      "1": {
        "clusters": {
          "basic": {
            "attributes": "UNSUP_GENERAL_COMMAND",
          "identify": {
          "groups": {
          "scenes": {
          "onOff": {
        "bindings": {
          "basic": {
Hi Johan,
I hope you’re doing well and coping with the load of requests? :wink:
Would you be able to add the below 16A Power plug with metering?
https://nl.aliexpress.com/item/1005002112376679.html?spm=a2g0s.9042311.0.0.4cf84c4dhsYGzd
This would be great,
Thanks again,
Rik
  "ids": {
    "modelId": "TS011F",
    "manufacturerName": "_TZ3000_cphmq0q7"
  "endpoints": {
        "endpointId": 1,
        "applicationDeviceId": 266,
        "_reserved1": 1,
        "inputClusters": [
          0,
          3,
          4,
          5,
          6,
          1794,
          2820,
          57344,
          57345
        "outputClusters": [
          25,
          10
        "endpointId": 242,
        "applicationProfileId": 41440,
        "applicationDeviceId": 97,
        "_reserved1": 0,
        "inputClusters": [],
        "outputClusters": [
          33
    "endpoints": {
      "1": {
        "clusters": {
          "basic": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "value": 3,
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "value": 67,
                  "minInterval": 1,
                  "maxInterval": 160,
                  "minChange": 0,
                  "status": "SUCCESS"
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "value": 0,
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "value": 1,
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "value": "_TZ3000_cphmq0q7",
                "acl": [
                  "readable",
                  "reportable"
                "id": 5,
                "name": "modelId",
                "value": "TS011F",
                "acl": [
                  "readable",
                  "reportable"
                "id": 6,
                "name": "dateCode",
                "value": "",
                "acl": [
                  "readable",
                  "reportable"
                "id": 7,
                "value": "mains",
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 65502,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65534,
                "value": "PENDING",
                "acl": [
                  "readable",
                  "reportable"
                "id": 65504,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65505,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65506,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65507,
          "identify": {
            "attributes": [
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 0,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 1,
          "groups": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "value": {
                  "type": "Buffer",
                  "data": [
                    0
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
          "scenes": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
          "onOff": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "onOff",
                "value": false,
                  "attributeDataType": 16,
                  "minInterval": 1,
                  "status": "SUCCESS"
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 16385,
                "name": "onTime",
                "value": 0,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 16386,
                "name": "offWaitTime",
                "value": 0,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 32769,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 32770,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 32768,
                "acl": [
                  "readable",
                  "reportable"
                "id": 32771,
          "metering": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "currentSummationDelivered",
                "value": 0,
                  "attributeDataType": 37,
                  "minInterval": 65534,
                  "maxInterval": 150,
                  "minChange": 1,
                  "status": "SUCCESS"
                "acl": [
                  "readable",
                  "reportable"
                "id": 512,
                "acl": [
                  "readable",
                  "reportable"
                "id": 768,
                "acl": [
                  "readable",
                  "reportable"
                "id": 771,
                "acl": [
                  "readable",
                  "reportable"
                "id": 774,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 1,
          "electricalMeasurement": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 1285,
                "name": "rmsVoltage",
                "value": 237,
                  "attributeDataType": 33,
                  "maxInterval": 151,
                  "minChange": 1,
                  "status": "SUCCESS"
                "acl": [
                  "readable",
                  "reportable"
                "id": 1288,
                "name": "rmsCurrent",
                "value": 0,
                  "maxInterval": 152,
                  "minChange": 1,
                  "status": "SUCCESS"
                "acl": [
                  "readable",
                  "reportable"
                "id": 1291,
                "name": "activePower",
                "value": 0,
                  "attributeDataType": 41,
                  "maxInterval": 153,
                  "minChange": 1,
                  "status": "SUCCESS"
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 1,
        "bindings": {
          "ota": {
            "attributes": [],
          "time": {
            "attributes": [],
      "242": {
        "clusters": {},
        "bindings": {}
Hi Johan, i have another version of the 1-gang switch module. Could you add it to your list? Thank you!
  "ids": {
    "modelId": "TS000F",
    "manufacturerName": "_TZ3000_m9af2l6g"
  "endpoints": {
        "endpointId": 1,
        "applicationDeviceId": 256,
        "_reserved1": 1,
        "inputClusters": [
          0,
          3,
          4,
          5,
          6,
          4096
        "outputClusters": [
          25,
          4096
    "endpoints": {
      "1": {
        "clusters": {
          "basic": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 0,
                "acl": [
                  "readable"
                "id": 1,
                "acl": [
                  "readable"
                "id": 2,
                "acl": [
                  "readable"
                "id": 3,
                "name": "hwVersion"
                "acl": [
                  "readable"
                "id": 4,
                "acl": [
                  "readable"
                "id": 5,
                "name": "modelId"
                "acl": [
                  "readable"
                "id": 7,
                "acl": [
                  "readable",
                  "writable"
                "id": 18,
                "acl": [
                  "readable"
                "id": 16384,
                "name": "swBuildId"
                "acl": [
                  "readable"
                "id": 65533,
          "identify": {
            "attributes": [
                "acl": [
                  "readable",
                  "writable"
                "id": 0
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
          "groups": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 0,
                "value": {
                  "type": "Buffer",
                  "data": [
                    0
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
          "scenes": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 0
                "acl": [
                  "readable"
                "id": 1
                "acl": [
                  "readable"
                "id": 2
                "acl": [
                  "readable"
                "id": 3
                "acl": [
                  "readable"
                "id": 4
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
          "onOff": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "onOff",
                "value": false,
                  "minInterval": 0,
                  "maxInterval": 300,
                  "status": "SUCCESS"
                "acl": [
                  "readable"
                "id": 16384
                "acl": [
                  "readable",
                  "writable"
                "id": 16385,
                "name": "onTime",
                "value": 0
                "acl": [
                  "readable",
                  "writable"
                "id": 16386,
                "value": 0
                "acl": [
                  "readable",
                  "writable"
                "id": 16387
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
          "touchlink": {
            "attributes": []
        "bindings": {
          "touchlink": {
            "attributes": []
          "ota": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 0
                "acl": [
                  "readable"
                "id": 1
                "acl": [
                  "readable"
                "id": 2
                "acl": [
                  "readable"
                "id": 3
                "acl": [
                  "readable"
                "id": 4
                "acl": [
                  "readable"
                "id": 5
                "acl": [
                  "readable"
                "id": 6
                "acl": [
                  "readable"
                "id": 7
                "acl": [
                  "readable"
                "id": 8
                "acl": [
                  "readable"
                "id": 9
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
  "ids": {    "modelId": "TS004F",    "manufacturerName": "_TZ3000_xabckq1v"  },  "endpoints": {    "endpointDescriptors": [      {        "endpointId": 1,        "applicationProfileId": 260,        "applicationDeviceId": 260,        "applicationDeviceVersion": 0,        "_reserved1": 1,        "inputClusters": [          0,          1,          3,          4,          6,          4096        ],        "outputClusters": [          25,          10,          3,          4,          5,          6,          8,          4096        ]      }    ],    "endpoints": {      "1": {        "clusters": {          "basic": {            "attributes": [              {                "acl": [                  "readable",                  "reportable"                ],                "id": 0,                "name": "zclVersion",                "value": 3,                "reportingConfiguration": {                  "status": "NOT_FOUND",                  "direction": "reported"                }              },              {                "acl": [                  "readable",                  "reportable"                ],                "id": 1,                "name": "appVersion",                "value": 65,                "reportingConfiguration": {                  "direction": "reported",                  "attributeDataType": 32,                  "minInterval": 1,                  "maxInterval": 65534,                  "minChange": 0,                  "status": "SUCCESS"                }              },              {                "acl": [                  "readable",                  "reportable"                ],                "id": 2,                "name": "stackVersion",                "value": 0,                "reportingConfiguration": {                  "status": "NOT_FOUND",                  "direction": "reported"                }              },              {                "acl": [                  "readable",                  "reportable"                ],                "id": 3,                "name": "hwVersion",                "value": 1,                "reportingConfiguration": {                  "status": "NOT_FOUND",                  "direction": "reported"                }              },              {                "acl": [                  "readable",                  "reportable"                ],                "id": 4,                "name": "manufacturerName",                "value": "_TZ3000_xabckq1v",                "reportingConfiguration": {                  "status": "NOT_FOUND",                  "direction": "reported"                }              },              {                "acl": [                  "readable",                  "reportable"                ],                "id": 5,                "name": "modelId",                "value": "TS004F",                "reportingConfiguration": {                  "status": "NOT_FOUND",                  "direction": "reported"                }              },              {                "acl": [                  "readable",                  "reportable"                ],                "id": 6,                "name": "dateCode",                "value": "",                "reportingConfiguration": {                  "status": "NOT_FOUND",                  "direction": "reported"                }              },              {                "acl": [                  "readable",                  "reportable"                ],                "id": 7,                "name": "powerSource",                "value": "battery",                "reportingConfiguration": {                  "status": "NOT_FOUND",                  "direction": "reported"                }              },              {                "acl": [                  "readable",                  "writable",                  "reportable"                ],                "id": 65502,                "reportingConfiguration": {                  "status": "NOT_FOUND",                  "direction": "reported"                }              },              {                "acl": [                  "readable",                  "reportable"                ],                "id": 65533,                "name": "clusterRevision",                "value": 2,                "reportingConfiguration": {                  "status": "NOT_FOUND",                  "direction": "reported"                }              },              {                "acl": [                  "readable",                  "reportable"                ],                "id": 65534,                "name": "attributeReportingStatus",                "value": "PENDING",                "reportingConfiguration": {                  "status": "NOT_FOUND",                  "direction": "reported"                }              },              {                "acl": [                  "readable",                  "reportable"                ],                "id": 65504,                "reportingConfiguration": {                  "status": "NOT_FOUND",                  "direction": "reported"                }              },              {                "acl": [                  "readable",                  "reportable"                ],                "id": 65505,                "reportingConfiguration": {                  "status": "NOT_FOUND",                  "direction": "reported"                }              },              {                "acl": [                  "readable",                  "reportable"                ],                "id": 65506,                "reportingConfiguration": {                  "status": "NOT_FOUND",                  "direction": "reported"                }              },              {                "acl": [                  "readable",                  "reportable"                ],                "id": 65507,                "reportingConfiguration": {                  "status": "NOT_FOUND",                  "direction": "reported"                }              }            ],            "commandsGenerated": "UNSUP_GENERAL_COMMAND",            "commandsReceived": "UNSUP_GENERAL_COMMAND"          },          "powerConfiguration": {            "attributes": [              {                "acl": [                  "readable",                  "reportable"                ],                "id": 0              },              {                "acl": [                  "readable",                  "reportable"                ],                "id": 32,                "name": "batteryVoltage",                "value": 30              },              {                "acl": [                  "readable",                  "reportable"                ],                "id": 33,                "name": "batteryPercentageRemaining",                "value": 200              },              {                "acl": [                  "readable",                  "reportable"                ],                "id": 65533,                "name": "clusterRevision",                "value": 1              }            ],            "commandsReceived": "UNSUP_GENERAL_COMMAND"          },          "identify": {            "attributes": [              {                "acl": [                  "readable",                  "writable",                  "reportable"                ],                "id": 0,                "reportingConfiguration": {                  "status": "NOT_FOUND",                  "direction": "reported"                }              },              {                "acl": [                  "readable",                  "reportable"                ],                "id": 65533,                "name": "clusterRevision",                "value": 1,                "reportingConfiguration": {                  "status": "NOT_FOUND",                  "direction": "reported"                }              }            ],            "commandsGenerated": "UNSUP_GENERAL_COMMAND",            "commandsReceived": "UNSUP_GENERAL_COMMAND"          },          "groups": {            "attributes": [              {                "acl": [                  "readable",                  "reportable"                ],                "id": 0,                "name": "nameSupport",                "value": {                  "type": "Buffer",                  "data": [                    0                  ]                },                "reportingConfiguration": {                  "status": "NOT_FOUND",                  "direction": "reported"                }              },              {                "acl": [                  "readable",                  "reportable"                ],                "id": 65533,                "name": "clusterRevision",                "value": 1,                "reportingConfiguration": {                  "status": "NOT_FOUND",                  "direction": "reported"                }              }            ],            "commandsGenerated": "UNSUP_GENERAL_COMMAND",            "commandsReceived": "UNSUP_GENERAL_COMMAND"          },          "onOff": {            "attributes": [              {                "acl": [                  "readable",                  "writable",                  "reportable"                ],                "id": 32772,                "reportingConfiguration": {                  "status": "NOT_FOUND",                  "direction": "reported"                }              }            ],            "commandsGenerated": "UNSUP_GENERAL_COMMAND"          },          "touchlink": {}        },        "bindings": {          "identify": {            "attributes": [              {                "acl": [                  "readable",                  "writable",                  "reportable"                ],                "id": 0,                "reportingConfiguration": {                  "status": "NOT_FOUND",                  "direction": "reported"                }              },              {                "acl": [                  "readable",                  "reportable"                ],                "id": 65533,                "name": "clusterRevision",                "value": 1,                "reportingConfiguration": {                  "status": "NOT_FOUND",                  "direction": "reported"                }              }            ],            "commandsGenerated": "UNSUP_GENERAL_COMMAND",            "commandsReceived": "UNSUP_GENERAL_COMMAND"          },          "groups": {            "attributes": [              {                "acl": [                  "readable",                  "reportable"                ],                "id": 0,                "name": "nameSupport",                "value": {                  "type": "Buffer",                  "data": [                    0                  ]                },                "reportingConfiguration": {                  "status": "NOT_FOUND",                  "direction": "reported"                }              },              {                "acl": [                  "readable",                  "reportable"                ],                "id": 65533,                "name": "clusterRevision",                "value": 1,                "reportingConfiguration": {                  "status": "NOT_FOUND",                  "direction": "reported"                }              }            ],            "commandsGenerated": "UNSUP_GENERAL_COMMAND",            "commandsReceived": "UNSUP_GENERAL_COMMAND"          },          "onOff": {            "attributes": [              {                "acl": [                  "readable",                  "writable",                  "reportable"                ],                "id": 32772,                "reportingConfiguration": {                  "status": "NOT_FOUND",                  "direction": "reported"                }              }            ],            "commandsGenerated": "UNSUP_GENERAL_COMMAND"          },          "touchlink": {},          "ota": {            "attributes": []          },          "time": {},          "scenes": {},          "levelControl": {}        }      }    }  }
Dear Johan,
When you got some time to add a new device, I would appreciate adding the following Tuya Zigbee Repeater. Thanks for all your hard work.
  "ids": {
    "modelId": "TS0207",
    "manufacturerName": "_TZ3000_5k5vh43t"
  "endpoints": {
        "endpointId": 1,
        "applicationDeviceId": 8,
        "_reserved1": 0,
        "inputClusters": [
          0,
          10,
          3
        "outputClusters": [
          25
    "endpoints": {
      "1": {
        "clusters": {
          "basic": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "value": 3
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "value": 64
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "value": 0
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "value": 1
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "value": "_TZ3000_5k5vh43t"
                "acl": [
                  "readable",
                  "reportable"
                "id": 5,
                "name": "modelId",
                "value": "TS0207"
                "acl": [
                  "readable",
                  "reportable"
                "id": 6,
                "name": "dateCode",
                "value": ""
                "acl": [
                  "readable",
                  "reportable"
                "id": 7,
                "value": "mains"
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 65502
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 1
                "acl": [
                  "readable",
                  "reportable"
                "id": 65534,
                "value": "PENDING"
                "acl": [
                  "readable",
                  "reportable"
                "id": 65504
                "acl": [
                  "readable",
                  "reportable"
                "id": 65505
                "acl": [
                  "readable",
                  "reportable"
                "id": 65506
                "acl": [
                  "readable",
                  "reportable"
                "id": 65507
          "time": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 7
          "identify": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0
                "acl": [
                  "readable",
                  "reportable"
                "id": 1
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 1
        "bindings": {
          "ota": {
            "attributes": [],
Can you add this one too?
Can you add this one too.
"ids": { "modelId": "TS0041", "manufacturerName": "_TZ3000_f97vq5mn" }, "endpoints": { "endpointDescriptors": [ { "endpointId": 1, "applicationProfileId": 260, "applicationDeviceId": 0, "applicationDeviceVersion": 0, "_reserved1": 1, "inputClusters": [ 0, 1, 6 ], "outputClusters": [ 25, 10 ] } ], "endpoints": { "1": { "clusters": { "basic": { "attributes": [ { "acl": [ "readable", "reportable" ], "id": 0, "name": "zclVersion", "value": 3, "reportingConfiguration": { "status": "NOT_FOUND", "direction": "reported" } }, { "acl": [ "readable", "reportable" ], "id": 1, "name": "appVersion", "value": 66, "reportingConfiguration": { "status": "NOT_FOUND", "direction": "reported" } }, { "acl": [ "readable", "reportable" ], "id": 2, "name": "stackVersion", "value": 0, "reportingConfiguration": { "status": "NOT_FOUND", "direction": "reported" } }, { "acl": [ "readable", "reportable" ], "id": 3, "name": "hwVersion", "value": 1, "reportingConfiguration": { "status": "NOT_FOUND", "direction": "reported" } }, { "acl": [ "readable", "reportable" ], "id": 4, "name": "manufacturerName", "value": "_TZ3000_f97vq5mn", "reportingConfiguration": { "status": "NOT_FOUND", "direction": "reported" } }, { "acl": [ "readable", "reportable" ], "id": 5, "name": "modelId", "value": "TS0041", "reportingConfiguration": { "status": "NOT_FOUND", "direction": "reported" } }, { "acl": [ "readable", "reportable" ], "id": 6, "name": "dateCode", "value": "", "reportingConfiguration": { "status": "NOT_FOUND", "direction": "reported" } }, { "acl": [ "readable", "reportable" ], "id": 7, "name": "powerSource", "value": "battery", "reportingConfiguration": { "status": "NOT_FOUND", "direction": "reported" } }, { "acl": [ "readable", "writable", "reportable" ], "id": 65502, "reportingConfiguration": { "status": "NOT_FOUND", "direction": "reported" } }, { "acl": [ "readable", "reportable" ], "id": 65533, "name": "clusterRevision", "value": 2, "reportingConfiguration": { "status": "NOT_FOUND", "direction": "reported" } }, { "acl": [ "readable", "reportable" ], "id": 65534, "name": "attributeReportingStatus", "value": "PENDING", "reportingConfiguration": { "status": "NOT_FOUND", "direction": "reported" } }, { "acl": [ "readable", "reportable" ], "id": 65504, "reportingConfiguration": { "status": "NOT_FOUND", "direction": "reported" } }, { "acl": [ "readable", "reportable" ], "id": 65505, "reportingConfiguration": { "status": "NOT_FOUND", "direction": "reported" } }, { "acl": [ "readable", "reportable" ], "id": 65506, "reportingConfiguration": { "status": "NOT_FOUND", "direction": "reported" } }, { "acl": [ "readable", "reportable" ], "id": 65507, "reportingConfiguration": { "status": "NOT_FOUND", "direction": "reported" } } ], "commandsGenerated": "UNSUP_GENERAL_COMMAND" }, "powerConfiguration": {}, "onOff": {} }, "bindings": { "ota": {}, "time": {} } } } }
a new Tuya Zigbee 3.0 Temperature Humidity Smart Sensor Detector LCD Screen APP Control Works With Zigbee Hub Smart Home Automation _TZ3000_qaaysllp TS0201
  "ids": {
    "modelId": "TS0201",
    "manufacturerName": "_TZ3000_qaaysllp"
  "endpoints": {
        "endpointId": 1,
        "applicationDeviceId": 262,
        "_reserved1": 1,
        "inputClusters": [
          0,
          1,
          1024,
          57346
        "outputClusters": [
          25,
          10
    "endpoints": {
      "1": {
        "clusters": {
          "basic": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "value": 3
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "value": 68
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "value": 0
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "value": 1
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "value": "_TZ3000_qaaysllp"
                "acl": [
                  "readable",
                  "reportable"
                "id": 5,
                "name": "modelId",
                "value": "TS0201"
                "acl": [
                  "readable",
                  "reportable"
                "id": 6,
                "name": "dateCode",
                "value": ""
                "acl": [
                  "readable",
                  "reportable"
                "id": 7,
                "value": "battery"
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 65502
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2
                "acl": [
                  "readable",
                  "reportable"
                "id": 65534,
                "value": "PENDING"
                "acl": [
                  "readable",
                  "reportable"
                "id": 65504
                "acl": [
                  "readable",
                  "reportable"
                "id": 65505
                "acl": [
                  "readable",
                  "reportable"
                "id": 65506
                "acl": [
                  "readable",
                  "reportable"
                "id": 65507
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0
                "acl": [
                  "readable",
                  "reportable"
                "id": 32,
                "value": 29
                "acl": [
                  "readable",
                  "reportable"
                "id": 33,
                "value": 196
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 1
          "illuminanceMeasurement": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "measuredValue",
                "value": 20087
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 61441
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 43521
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 43522
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 43523
        "bindings": {
          "ota": {
            "attributes": [],
          "time": {
            "attributes": [],
Hi Johan,
Could you add the MoesGo _TZE200_amp6tsvy
Product ID TS0601
It only adds as a generic Zigbee device and it doesnt allow me to switch on or off.
It is a single switch (N/L)
  "ids": {
    "manufacturerName": "_TZE200_amp6tsvy"
  "endpoints": {
        "endpointId": 1,
        "_reserved1": 1,
        "inputClusters": [
          0,
          4,
          5,
          61184
        "outputClusters": [
          25,
          10
    "endpoints": {
      "1": {
        "clusters": {
          "basic": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "value": 3,
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "value": 66,
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "value": 0,
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "value": 1,
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "value": "_TZE200_amp6tsvy",
                "acl": [
                  "readable",
                  "reportable"
                "id": 5,
                "name": "modelId",
                "value": "TS0601",
                "acl": [
                  "readable",
                  "reportable"
                "id": 6,
                "name": "dateCode",
                "value": "",
                "acl": [
                  "readable",
                  "reportable"
                "id": 7,
                "value": "battery",
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 65502,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65534,
                "value": "PENDING",
                "acl": [
                  "readable",
                  "reportable"
                "id": 65504,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65505,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65506,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65507,
          "groups": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "value": {
                  "type": "Buffer",
                  "data": [
                    0
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
          "scenes": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
        "bindings": {
          "ota": {
            "attributes": [],
          "time": {
            "attributes": [],
Hi, can you please add the blitzwolf shp15 with this ID for me? It is not recognised when adding it. It’s added as unknown zigbee device. Thanks
  "ids": {
    "manufacturerName": "_TZ3000_mraovvmm"
  "endpoints": {
        "endpointId": 1,
        "_reserved1": 1,
        "inputClusters": [
          0,
          3,
          4,
          5,
          6,
          1794,
          2820,
          57344,
          57345
        "outputClusters": [
          25,
          10
        "endpointId": 242,
        "_reserved1": 0,
        "outputClusters": [
          33
    "endpoints": {
      "1": {
        "clusters": {
          "basic": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "value": 3,
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "value": 67,
                  "minInterval": 1,
                  "maxInterval": 160,
                  "minChange": 0,
                  "status": "SUCCESS"
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "value": 0,
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "value": 1,
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "value": "_TZ3000_mraovvmm",
                "acl": [
                  "readable",
                  "reportable"
                "id": 5,
                "name": "modelId",
                "value": "TS011F",
                "acl": [
                  "readable",
                  "reportable"
                "id": 6,
                "name": "dateCode",
                "value": "",
                "acl": [
                  "readable",
                  "reportable"
                "id": 7,
                "value": "mains",
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 65502,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65534,
                "value": "PENDING",
                "acl": [
                  "readable",
                  "reportable"
                "id": 65504,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65505,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65506,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65507,
          "identify": {
            "attributes": [
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 0,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 1,
          "groups": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "value": {
                  "type": "Buffer",
                  "data": [
                    0
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
          "scenes": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
          "onOff": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "onOff",
                "value": false,
                  "minInterval": 1,
                  "status": "SUCCESS"
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 16385,
                "name": "onTime",
                "value": 0,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 16386,
                "value": 0,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 32769,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 32770,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 32768,
                "acl": [
                  "readable",
                  "reportable"
                "id": 32771,
          "metering": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "value": 0,
                  "maxInterval": 150,
                  "minChange": 1,
                  "status": "SUCCESS"
                "acl": [
                  "readable",
                  "reportable"
                "id": 512,
                "acl": [
                  "readable",
                  "reportable"
                "id": 768,
                "acl": [
                  "readable",
                  "reportable"
                "id": 771,
                "acl": [
                  "readable",
                  "reportable"
                "id": 774,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 1,
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 1285,
                "value": 237,
                  "maxInterval": 151,
                  "minChange": 1,
                  "status": "SUCCESS"
                "acl": [
                  "readable",
                  "reportable"
                "id": 1288,
                "value": 0,
                  "maxInterval": 152,
                  "minChange": 1,
                  "status": "SUCCESS"
                "acl": [
                  "readable",
                  "reportable"
                "id": 1291,
                "value": 0,
                  "maxInterval": 153,
                  "minChange": 1,
                  "status": "SUCCESS"
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 1,
        "bindings": {
          "ota": {
            "attributes": [],
          "time": {
            "attributes": [],
      "242": {
        "clusters": {},
        "bindings": {}
Request @johan_bendz “Tuya Zigbee AM43 Blinds Drive”
  "ids": {
    "manufacturerName": "_TZE200_zah67ekd"
  "endpoints": {
        "endpointId": 1,
        "_reserved1": 1,
        "inputClusters": [
          0,
          4,
          5,
          61184
        "outputClusters": [
          25,
          10
    "endpoints": {
      "1": {
        "clusters": {
          "basic": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "value": 3
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "value": 71
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "value": 0
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "value": 1
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "value": "_TZE200_zah67ekd"
                "acl": [
                  "readable",
                  "reportable"
                "id": 5,
                "name": "modelId",
                "value": "TS0601"
                "acl": [
                  "readable",
                  "reportable"
                "id": 6,
                "name": "dateCode",
                "value": ""
                "acl": [
                  "readable",
                  "reportable"
                "id": 7,
                "value": "battery"
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 65502
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2
                "acl": [
                  "readable",
                  "reportable"
                "id": 65534,
                "value": "PENDING"
                "acl": [
                  "readable",
                  "reportable"
                "id": 65504
                "acl": [
                  "readable",
                  "reportable"
                "id": 65505
                "acl": [
                  "readable",
                  "reportable"
                "id": 65506
                "acl": [
                  "readable",
                  "reportable"
                "id": 65507
          "groups": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "value": {
                  "type": "Buffer",
                  "data": [
                    0
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2
          "scenes": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0
                "acl": [
                  "readable",
                  "reportable"
                "id": 1
                "acl": [
                  "readable",
                  "reportable"
                "id": 2
                "acl": [
                  "readable",
                  "reportable"
                "id": 3
                "acl": [
                  "readable",
                  "reportable"
                "id": 4
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2
        "bindings": {
          "ota": {
            "attributes": [],
          "time": {
            "attributes": [],
@johan_bendz
Hello Johan,
I have a few of the device mentioned below. For some reason dimming the light to a certain value with the “duration” option enabled in the flowcard does not work. It immediatly dimms to the given value without considering the duration-value.
Any ideas?
  "ids": {
    "modelId": "TS110F",
    "manufacturerName": "_TYZB01_qezuin6k"
  "endpoints": {
        "endpointId": 1,
        "applicationDeviceId": 257,
        "_reserved1": 1,
        "inputClusters": [
          0,
          4,
          5,
          6,
          8
        "outputClusters": [
          25,
          10
    "endpoints": {
      "1": {
        "clusters": {
          "basic": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "value": 3
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "value": 65
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "value": 0
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "value": 1
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "value": "_TYZB01_qezuin6k"
                "acl": [
                  "readable",
                  "reportable"
                "id": 5,
                "name": "modelId",
                "value": "TS110F"
                "acl": [
                  "readable",
                  "reportable"
                "id": 6,
                "name": "dateCode",
                "value": ""
                "acl": [
                  "readable",
                  "reportable"
                "id": 7,
                "value": "mains"
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 65502
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2
                "acl": [
                  "readable",
                  "reportable"
                "id": 65534,
                "value": "PENDING"
                "acl": [
                  "readable",
                  "reportable"
                "id": 65504
                "acl": [
                  "readable",
                  "reportable"
                "id": 65505
                "acl": [
                  "readable",
                  "reportable"
                "id": 65506
                "acl": [
                  "readable",
                  "reportable"
                "id": 65507
          "groups": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "value": {
                  "type": "Buffer",
                  "data": [
                    0
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2
          "scenes": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0
                "acl": [
                  "readable",
                  "reportable"
                "id": 1
                "acl": [
                  "readable",
                  "reportable"
                "id": 2
                "acl": [
                  "readable",
                  "reportable"
                "id": 3
                "acl": [
                  "readable",
                  "reportable"
                "id": 4
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2
          "onOff": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "onOff",
                "value": true
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 16385,
                "name": "onTime",
                "value": 0
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 16386,
                "value": 0
          "levelControl": {
            "attributes": [
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 0,
                "name": "currentLevel",
                "value": 254
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 64512
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 1
        "bindings": {
          "ota": {
            "attributes": [],
          "time": {
            "attributes": [],
Regards,
Dennis
Dear Johan,
When you got some time to add a new device, I would appreciate adding the following Tuya Zigbee 2 Gang Wall Switch.
  "ids": {
    "manufacturerName": "_TZE200_g1ib5ldv"
  "endpoints": {
        "endpointId": 1,
        "_reserved1": 1,
        "inputClusters": [
          0,
          4,
          5,
          61184
        "outputClusters": [
          25,
          10
    "endpoints": {
      "1": {
        "clusters": {
          "basic": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "value": 3,
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "value": 66,
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "value": 0,
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "value": 1,
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "value": "_TZE200_g1ib5ldv",
                "acl": [
                  "readable",
                  "reportable"
                "id": 5,
                "name": "modelId",
                "value": "TS0601",
                "acl": [
                  "readable",
                  "reportable"
                "id": 6,
                "name": "dateCode",
                "value": "",
                "acl": [
                  "readable",
                  "reportable"
                "id": 7,
                "value": "battery",
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 65502,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65534,
                "value": "PENDING",
                "acl": [
                  "readable",
                  "reportable"
                "id": 65504,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65505,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65506,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65507,
          "groups": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "value": {
                  "type": "Buffer",
                  "data": [
                    0
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
          "scenes": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
        "bindings": {
          "ota": {
            "attributes": [],
          "time": {
            "attributes": [],
