[APP][Pro] Tuya Local
One more thing I’ve just tested: DP140 works correctly for start/stop commands from Homey, but the Homey switch does not follow when the charger is started or stopped externally from the Tuya app.
So DP140 appears to work for sending the command, but it doesn’t currently provide/sync the switch state back to Homey.
Since DP109 reliably reports the actual charger state, could the Homey switch state perhaps be synchronized from DP109?
For example:
  • WORKING → On
  • PAUSE → Off
  • IDLEINS → probably On/available, since the charger is enabled and the vehicle is plugged in but not requesting power.
That way the Homey switch would also update correctly when start/stop is performed from the Tuya app.
Hi Dietrich,
That screen is the pairing dialog, and it’s showing exactly what it should — the Bridge’s own two data points. The sub-device list isn’t there; it lives in DP Debug, which only exists once a device has been added.
Also: you didn’t need to pair it again. If you now have two Bridge entries pointing at 192.168.5.10, please delete one. These devices accept exactly one local connection, and two entries for the same address fight each other for it — that alone can stop anything from arriving.
Where to look: app settings → DP Debug → pick Bridge in the dropdown → scroll past its own data points. If a sub-device has reported, there’s a section headed Sub-devices behind this gateway.
It probably won’t be there immediately. The gateway only forwards a sub-device’s values when that sub-device actually sends something, and a radiator thermostat is quiet by nature — it may report once every half hour. So give it a nudge: turn the dial on one thermostat, or change its target temperature in the Tuya app, then switch on Auto-refresh in DP Debug and watch for a minute.
If something appears — an id with DP 2 and DP 3 under it — that’s the answer and we’re most of the way there. If nothing appears after a few deliberate changes, that’s also an answer: your Bridge keeps its sub-devices to itself and relays them only to the cloud. Either way we’ll know, which we couldn’t before.
Kind regards,
Andi
Hi Sebastian,
That settles it, and your own older data confirms it without being asked. d=12350 against DP153’s t=1225s is a ten-second gap — your polling interval — so d is the running session’s duration in tenths of a second, exactly as you read it.
The nice part: two readings you sent days ago prove the same thing independently. They’re 240 seconds and 0.7 kWh apart, which works out to 10.5 kW — the power both of them reported at the time. Energy over time meeting the power checks both units at once.
So the block is uniform after all, which I should have seen much earlier: every field counts in tenths of its unit. 2320 → 232.0 V, 55 → 5.5 A, 370 → 37.0 °C, 39 → 3.9 kW, 113 → 11.3 kWh, 12350 → 1235.0 s. d goes to the log rather than a tile, since there’s nothing to show a charging duration on, but the log now says what it is instead of calling it a mystery.
The switch: yes, and it’s built. Slightly differently from your proposal, though — no new setting. The switch follows the reported state only while the switch data point has never said anything of its own. The app already remembers every data point a device has ever sent, so the moment DP 140 reports a value, this stops and that value governs again. It fixes your charger without changing behaviour for the hundreds where the switch point works normally.
Your mapping is what I used: WORKING → on, PAUSE → off, IDLEINS → on. Unplugged leaves the switch alone, since it says nothing about whether the charger is enabled.
Good to hear DP 140 works. The short delay before power reappears is expected — the measurement block only arrives when the charger sends it, so the first one after a start is whenever it feels like it.
Kind regards,
Andi
Hello Andi,
after playing a liitle bit with the Thermostats I get the following as DP debug:
Bridge
Sub devices
Bluetooth Thermostat
Zigbee Thermostat
Thanks so much for a great app!
I recently added my Air Condition to the app but numeric mode/fan speed enums are not read or written (v1.0.237)
My AC runs on protocol 3.5 and has a stable connection with Homey and Tuya IOS app. It doesn’t answer status requests but receives all data. “Temperature” changes and “Power” toggle works via Homey.
DP 4 “mode”: Auto=“0”, Cool=“1”, Dry=“2”, Fan=“3”, Heat=“4”.
DP Debug shows DP 4 change when I switch modes in the Tuya app, but the Homey mode picker doesn’t follow. Changing the mode in Homey sends nothing to the AC, and there’s no log entry at all.
Entering 1,4,0,2,3 in Mode under device settings gives “cannot restrict options… current value ‘auto’ is not in that list”.
Could the AC driver support a value mapping for mode (e.g. cool=1,heat=4,auto=0,dry=2,fan=3)? The same probably applies to fan speed (DP 5 is also a numeric enum). Support bundle and cloud lookup output attached.
Air Conditioner
DP 1	switch	Boolean	false	{}
DP 2	temp_set	Integer	2300	1600–3100 step 50 ℃
DP 3	temp_current	value	2470	-10000–10000 step 50 ℃
DP 4	mode	enum	0
DP 5	fan_speed_enum	enum	0
DP 7	auto	bool	true
DP 8	eco	bool	false
DP 9	drying	bool	false
DP 12	heat	Boolean	false	{}
DP 13	light	Boolean	true	{}
DP 16	beep	Boolean	true	{}
DP 24	temp_set_f	Integer	73	61–88 step 1 ℉
DP 26	health	Boolean	false	{}
DP 27	cleaning	Boolean	false	{}
DP 31	gear_vertical	enum	8
DP 34	gear_horizontal	enum	8
DP 39	fresh_air_valve	bool	false	{}
DP 40	supply_fan_speed	enum	0
DP 101	temperature_type	bool	false
DP 102	eight_add_hot	bool	false
DP 103	heat_status	bool	false
DP 104	high_temperature_wind	bool	false
DP 105	cool_feel_wind	bool	false
DP 106	new_wind_auto_switch	bool	false
DP 107	weektimer1	string
DP 108	freshair_status	bool	false
DP 109	weektimer2	string
DP 110	filter_block_status	bool	false
DP 111	ai_eco_switch	bool	false
DP 112	access_card_insert	bool	false
DP 113	upper_tem_limit	value	3100
DP 114	lower_tem_limit	value	1600
DP 115	wind_speed_percentage	value	0
DP 116	ure	value	1400
DP 117	external_unit_fanspeed	value	720
DP 118	outdoor_fan_tarspeed	value	0
DP 119	compressor_frequency	value	42
DP 120	outdoor_comptar_freqrun	value	42
DP 121	outdoor_comptar_freqset	value	0
DP 122	outdoor_eevtar_opendegree	value	0
DP 123	soft_wind	enum	0
DP 124	ai_eco_status	enum	0
DP 125	regular_reporting	enum	1
DP 126	sleep_enum	enum	0
DP 127	electricity	value	0
DP 128	electricity_starttime	value	1790253854
DP 129	electricity_endtime	value	1790253974
DP 130	clearele_starttime	value	0
DP 131	clearele_endtime	value	0
DP 132	generator_mode	enum	0
DP 133	capabilities	raw	FAMHCAkLDA0VFxwfISIjJCcoKSox
DP 134	error_code	raw	AA==
DP 135	light_sense	bool	false
DP 136	specialtimer	string
DP 137	vertical_wind	enum	0
DP 138	horizontal_wind	enum	0
DP 139	wakeup_word	enum	0
DP 140	wakeup_status	enum	0
DP 141	volume	value	10
DP 142	voice_switch	bool	false
DP 143	voice_status	enum	0
DP 144	examine_mode	bool	false
DP 145	stores_mode	bool	false
DP 146	sound_location	enum	0
DP 147	smart_windmode	enum	0
DP 148	mic_distance	value	0
DP 149	filter_blocknotify	bool	false
DP 150	max_volume	value	1
DP 151	auto_gen_mode	enum	0
DP 152	power_source	enum	0
DP 153	ble_module_status	enum	0
DP 154	ble_module_mac	string
DP 155	newwind_super	bool	false
DP 156	light_senser_status	bool	false
DP 157	anti_directblow	bool	false
DP 158	widearea_wind	bool	false
DP 159	encircle_wind	bool	false
DP 160	zone_wind	bool	false
DP 161	left_ht_direction	enum	0
DP 162	right_ht_direction	enum	0
DP 163	wind3d_switch	bool	false
DP 164	wind3d_type	enum	0
DP 165	solar_power	value	0
DP 166	grid_power	value	0
DP 167	solar_electricity	value	0
DP 168	solar_state	enum	0
DP 169	openadr_eventlist	string
DP 170	openadr_switch	bool	false
DP 171	openadr_status	bool	false
DP 172	openadr_request	enum	0
DP 173	fireplace_sw	bool	false
DP 174	lowheat_sw	bool	false
DP 175	lowheat_tempc	value	800
DP 176	lowheat_tempf	value	46
DP 194	voice_welcome_play_switch	bool	false
DP 195	virtual_ai_time	value	0
DP 196	virtual_ai_save	value	0
DP 197	voice_language	string
DP 198	virtual_period	value	120
DP 199	virtual_electricity	value	0
DP —	mode_auto	Boolean	true	{}
DP —	mode_eco	Boolean	false	{}
DP —	mode_dry	Boolean	false	{}
Tuya Local 1.0.237 — support bundle (1 device)
Support bundle
Tuya Local v1.0.237 — support bundle
Generated: 2026-09-24T12:40:21.260Z
App started: 2026-09-24T06:16:49.896Z (running 6h 23m)
Homey: 13.5.0
Cloud lookup: configured (eu) — account listing not attempted since the app started
DEVICE  Air Conditioner
  driver     air_conditioner
  model      T-plus-Audio  (product nn2ooaacswz6uyi0)
  device id  bf7712…
  available  yes
  protocol   configured 3.5, connected 3.5  ip 192.168.0.181
  status     Connected · last seen 9/24/26, 2:40:18 PM · poll 30s
  history    2 connections since app start · up 6h 23m total · avg 3h 11m · longest 6h 20m
  packets    1195 received · 0.05/s while connected · data ever received: yes
  DP mapping
    dp_anion                   0
    dp_child_lock              7
    dp_countdown_left          0
    dp_countdown_timer         0
    dp_current_temp            3
    dp_eco                     8
    dp_fan_speed               5
    dp_fault                   20
    dp_mode                    4
    dp_onoff                   1
    dp_sleep                   9
    dp_swing                   8
    dp_swing_h                 0
    dp_target_temp             2
  other settings
    alarm_grace_seconds        30
    command_gap_ms             100
    fan_speed_values           "2,auto,low,medium,high,turbo"
    fire_and_forget            true
    lock_protocol              true
    mode_values                "cool,heat,auto,dry,fan"
    offline_grace_seconds      60
    reconnect_interval         0
    swing_values               "off,on"
    temp_divisor               100
    temp_max                   31
    temp_min                   16
    temp_step                  1
  live DPs   (updated 2026-09-24T12:40:17.251Z)
    DP 1     false                        boolean
    DP 2     2300                         number
    DP 3     2470                         number
    DP 4     "0"                          string
    DP 5     "0"                          string
    DP 7     true                         boolean
    DP 8     false                        boolean
    DP 9     false                        boolean
    DP 13    true                         boolean
    DP 16    true                         boolean
    DP 24    73                           number
    DP 26    false                        boolean
    DP 27    false                        boolean
    DP 31    "8"                          string
    DP 34    "8"                          string
    DP 101   false                        boolean
    DP 102   false                        boolean
    DP 103   false                        boolean
    DP 104   false                        boolean
    DP 105   false                        boolean
    DP 111   false                        boolean
    DP 113   3100                         number
    DP 114   1600                         number
    DP 116   1400                         number
    DP 117   720                          number
    DP 118   0                            number
    DP 119   42                           number
    DP 120   42                           number
    DP 121   0                            number
    DP 122   0                            number
    DP 123   "0"                          string
    DP 124   "0"                          string
    DP 125   "1"                          string
    DP 126   "0"                          string
    DP 127   0                            number
    DP 128   1790253494                   number
    DP 129   1790253614                   number
    DP 132   "0"                          string
    DP 137   "0"                          string
    DP 138   "0"                          string
  cloud spec  code / dp / type / value / range
    switch                     1     Boolean   null
    temp_set                   2     Integer   null             1600-3100 ℃
    temp_current               3     value     null             -10000-10000 ℃
    mode                       4     enum      null
    fan_speed_enum             5     enum      null
    auto                       7     bool      null
    eco                        8     bool      null
    drying                     9     bool      null
    heat                       12    Boolean   null
    light                      13    Boolean   null
    beep                       16    Boolean   null
    temp_set_f                 24    Integer   null             61-88 ℉
    health                     26    Boolean   null
    cleaning                   27    Boolean   null
    gear_vertical              31    enum      null
    gear_horizontal            34    enum      null
    fresh_air_valve            39    bool      null
    supply_fan_speed           40    enum      null
    temperature_type           101   bool      null
    eight_add_hot              102   bool      null
    heat_status                103   bool      null
    high_temperature_wind      104   bool      null
    cool_feel_wind             105   bool      null
    new_wind_auto_switch       106   bool      null
    weektimer1                 107   string    null
    freshair_status            108   bool      null
    weektimer2                 109   string    null
    filter_block_status        110   bool      null
    ai_eco_switch              111   bool      null
    access_card_insert         112   bool      null
    upper_tem_limit            113   value     null
    lower_tem_limit            114   value     null
    wind_speed_percentage      115   value     null
    ure                        116   value     null
    external_unit_fanspeed     117   value     null
    outdoor_fan_tarspeed       118   value     null
    compressor_frequency       119   value     null
    outdoor_comptar_freqrun    120   value     null
    outdoor_comptar_freqset    121   value     null
    outdoor_eevtar_opendegree  122   value     null
    soft_wind                  123   enum      null
    ai_eco_status              124   enum      null
    regular_reporting          125   enum      null
    sleep_enum                 126   enum      null
    electricity                127   value     null
    electricity_starttime      128   value     null
    electricity_endtime        129   value     null
    clearele_starttime         130   value     null
    clearele_endtime           131   value     null
    generator_mode             132   enum      null
    capabilities               133   raw       null
    error_code                 134   raw       null
    light_sense                135   bool      null
    specialtimer               136   string    null
    vertical_wind              137   enum      null
    horizontal_wind            138   enum      null
    wakeup_word                139   enum      null
    wakeup_status              140   enum      null
    volume                     141   value     null
    voice_switch               142   bool      null
    voice_status               143   enum      null
    examine_mode               144   bool      null
    stores_mode                145   bool      null
    sound_location             146   enum      null
    smart_windmode             147   enum      null
    mic_distance               148   value     null
    filter_blocknotify         149   bool      null
    max_volume                 150   value     null
    auto_gen_mode              151   enum      null
    power_source               152   enum      null
    ble_module_status          153   enum      null
    ble_module_mac             154   string    null
    newwind_super              155   bool      null
    light_senser_status        156   bool      null
    anti_directblow            157   bool      null
    widearea_wind              158   bool      null
    encircle_wind              159   bool      null
    zone_wind                  160   bool      null
    left_ht_direction          161   enum      null
    right_ht_direction         162   enum      null
    wind3d_switch              163   bool      null
    wind3d_type                164   enum      null
    solar_power                165   value     null
    grid_power                 166   value     null
    solar_electricity          167   value     null
    solar_state                168   enum      null
    openadr_eventlist          169   string    null
    openadr_switch             170   bool      null
    openadr_status             171   bool      null
    openadr_request            172   enum      null
    fireplace_sw               173   bool      null
    lowheat_sw                 174   bool      null
    lowheat_tempc              175   value     null
    lowheat_tempf              176   value     null
    voice_welcome_play_switch  194   bool      null
    virtual_ai_time            195   value     null
    virtual_ai_save            196   value     null
    voice_language             197   string    null
    virtual_period             198   value     null
    virtual_electricity        199   value     null
    mode_auto                  undefined Boolean   null
    mode_eco                   undefined Boolean   null
    mode_dry                   undefined Boolean   null
LOG — warnings, errors and connection events, newest first
  35 of 35 distinct messages from 123 of 500 entries. Repeats are folded into one line. The device sections above carry the DP mapping and the live values — please include them when quoting this report.
  2026-09-24T12:37:13.134Z  [WARN]  [Air Conditioner]  Disconnected: socket closed (up 6h 20m, 1182 packets)
  2026-09-24T12:37:11.133Z  [WARN]  [Air Conditioner]  Ignoring malformed packet from device: The value of "offset" is out of range. It must be >= 0 and <= 6. Received 8
  2026-09-23T20:20:48.734Z  [WARN]  [Air Conditioner]  5 failures — trying protocol 3.3 (configured: 3.4)
  2026-09-23T20:17:35.426Z  [WARN]  [Air Conditioner]  Disconnected: socket closed (up 1s, no data received)
  2026-09-23T20:17:56.118Z  [WARN]  [Air Conditioner]  Status request failed: Timeout waiting for status response from device id: bf7712e---------  ×5 — 20:17:29, 20:17:34, 20:17:41, 20:17:44, 20:17:56
  2026-09-23T20:17:00.058Z  [WARN]  [Air Conditioner]  Connected and answering keep-alives, but 2 status requests in a row went unanswered and no data has ever arrived on this connection. That combination points at the Local Key or the Device ID, not at the protocol: a keep-alive needs neither, a status request needs both, so a device that answers the first and drops the second is receiving something it cannot decrypt. Re-copy both from the Tuya IoT platform — the Local Key changes every time the device is re-added in the Smart Life app. With cloud credentials saved, Settings → Fix It → Check local keys makes that comparison for every device in one press.
  2026-09-23T20:16:43.558Z  [WARN]  [Air Conditioner]  Disconnected: Error from socket: read ECONNRESET (up 748ms, no data received)
  2026-09-23T20:16:43.557Z  [ERROR]  [Air Conditioner]  Error from socket: read ECONNRESET — the device closed the connection without us having sent it anything, so the protocol version cannot be the cause on 3.3: nothing is written on connect below 3.4. A device that drops an idle connection this fast usually has its single local connection slot taken — these accept exactly one. Check the Tuya or Smart Life app, another integration, and whether a second device in this app points at the same address.
  2026-09-23T20:21:53.830Z  [WARN]  [Air Conditioner]  Disconnected: socket closed (up 2s, no data received)  ×11 since 2026-09-23T20:16:39.370Z
  2026-09-23T20:19:52.338Z  [WARN]  [Air Conditioner]  Connection failed: Handshake timed out after 15s — the device accepted the connection but never completed the key exchange, which usually means it does not speak the protocol version being tried. The app rotates through the others on its own; if it settles on one that works, the log says so and that version belongs in the device settings.  ×7 since 2026-09-23T20:16:03.128Z
  2026-09-23T19:49:25.984Z  [WARN]  [Air Conditioner]  ac_mode: cannot restrict options to [1, 4, 0, 2, 3] — current value "auto" is not in that list. Update the device to a supported value first, or include "auto" in the setting.
  2026-09-23T19:45:43.617Z  [WARN]  [Air Conditioner]  ac_mode: cannot restrict options to [1, 4, 0, 2, 3] — current value "cool" is not in that list. Update the device to a supported value first, or include "cool" in the setting.
  2026-09-23T13:32:48.825Z  [WARN]  [Air Conditioner]  Disconnected: socket closed (up 50s, 7 packets)
  2026-09-23T13:31:55.453Z  [WARN]  [Air Conditioner]  Disconnected: socket closed (up 2m 42s, 18 packets)
  2026-09-24T12:37:15.710Z  [INFO]  [Air Conditioner]  Connected  ×27 since 2026-09-23T13:29:12.986Z
  2026-09-23T12:39:03.036Z  [ERROR]  [Cloud]  Device list failed: No devices found (assoc: No permission. The data center is suspended.Please go to the cloud development platform to enable the data center. ; S2/uid=bay17901: No permission. The data center is suspended.Please go to the cloud development platform to enable the data center. ; S3/smartlife: No permission. The data center is suspended.Please go to the cloud development platform to enable the data center. ; S3/tuyaSmart: No permission. The data center is suspended.Please go to the cloud development platform to enable the data center. ; schema: No permission. The data center is suspended.Please go to the cloud development platform to enable the data center. ; v2: No permission. The data center is suspended.Please go to the cloud development platform to enable the data center. ; s6: No permission. The data center is suspended.Please go to the cloud development platform to enable the data center. ; s7: uri path invalid)  ×3 — 12:13:16, 12:15:07, 12:39:03
  2026-09-23T12:39:03.036Z  [ERROR]  [Cloud]  All strategies failed — assoc: No permission. The data center is suspended.Please go to the cloud development platform to enable the data center. ; S2/uid=bay17901: No permission. The data center is suspended.Please go to the cloud development platform to enable the data center. ; S3/smartlife: No permission. The data center is suspended.Please go to the cloud development platform to enable the data center. ; S3/tuyaSmart: No permission. The data center is suspended.Please go to the cloud development platform to enable the data center. ; schema: No permission. The data center is suspended.Please go to the cloud development platform to enable the data center. ; v2: No permission. The data center is suspended.Please go to the cloud development platform to enable the data center. ; s6: No permission. The data center is suspended.Please go to the cloud development platform to enable the data center. ; s7: uri path invalid  ×3 — 12:13:16, 12:15:07, 12:39:03
  2026-09-23T12:39:03.005Z  [WARN]  [Cloud]  S6: p1 failed — code=28841107 msg=No permission. The data center is suspended.Please go to the cloud development platform to enable the data center.   ×3 — 12:13:16, 12:15:07, 12:39:03
  2026-09-23T12:39:02.957Z  [WARN]  [Cloud]  S5: p1 failed — code=28841107 msg=No permission. The data center is suspended.Please go to the cloud development platform to enable the data center.   ×3 — 12:13:16, 12:15:07, 12:39:02
  2026-09-23T12:39:02.911Z  [WARN]  [Cloud]  S4: /v1.0/devices failed — code=28841107 msg=No permission. The data center is suspended.Please go to the cloud development platform to enable the data center.   ×3 — 12:13:16, 12:15:07, 12:39:02
  2026-09-23T12:39:02.864Z  [WARN]  [Cloud]  S3 legacy: /users/bay17901/devices failed — code=28841107 msg=No permission. The data center is suspended.Please go to the cloud development platform to enable the data center.   ×3 — 12:13:16, 12:15:07, 12:39:02
  2026-09-23T12:39:02.738Z  [WARN]  [Cloud]  S3/tuyaSmart: failed — code=28841107 msg=No permission. The data center is suspended.Please go to the cloud development platform to enable the data center.   ×3 — 12:13:16, 12:15:07, 12:39:02
  2026-09-23T12:39:02.681Z  [WARN]  [Cloud]  S3/smartlife: failed — code=28841107 msg=No permission. The data center is suspended.Please go to the cloud development platform to enable the data center.   ×3 — 12:13:16, 12:15:07, 12:39:02
  2026-09-23T12:39:02.368Z  [WARN]  [Cloud]  S2/uid=bay17901: failed — code=28841107 msg=No permission. The data center is suspended.Please go to the cloud development platform to enable the data center.   ×3 — 12:13:16, 12:15:06, 12:39:02
  2026-09-23T12:39:02.316Z  [WARN]  [Cloud]  S1: iot-01/associated-users failed — code=28841107 msg=No permission. The data center is suspended.Please go to the cloud development platform to enable the data center.   ×3 — 12:13:16, 12:15:06, 12:39:02
  2026-09-23T12:51:23.978Z  [ERROR]  [Cloud]  Device list failed: No devices found (S2/uid=bay17901: permission deny; S3/smartlife: permission deny; S3/tuyaSmart: permission deny; schema: permission deny; s6: device_ids param is illegal, please check it; s7: uri path invalid)  ×3 — 11:33:00, 11:37:06, 12:51:23
  2026-09-23T12:51:23.978Z  [ERROR]  [Cloud]  All strategies failed — S2/uid=bay17901: permission deny; S3/smartlife: permission deny; S3/tuyaSmart: permission deny; schema: permission deny; s6: device_ids param is illegal, please check it; s7: uri path invalid  ×3 — 11:33:00, 11:37:06, 12:51:23
  2026-09-23T12:51:23.978Z  [WARN]  [Cloud]  S7: p1 failed — code=1108 msg=uri path invalid  ×6 — 11:33:00, 11:37:06, 12:13:16, 12:15:07, 12:39:03, 12:51:23
  2026-09-23T12:51:23.944Z  [WARN]  [Cloud]  S6: p1 failed — code=1109 msg=device_ids param is illegal, please check it  ×3 — 11:33:00, 11:37:06, 12:51:23
  2026-09-23T12:51:23.587Z  [WARN]  [Cloud]  S4: /v1.0/devices failed — code=1106 msg=permission deny  ×3 — 11:33:00, 11:37:06, 12:51:23
  2026-09-23T12:51:23.518Z  [WARN]  [Cloud]  S3 legacy: /users/bay17901/devices failed — code=1106 msg=permission deny  ×3 — 11:33:00, 11:37:06, 12:51:23
  2026-09-23T12:51:22.470Z  [WARN]  [Cloud]  S3/tuyaSmart: failed — code=1106 msg=permission deny  ×3 — 11:32:59, 11:37:05, 12:51:22
  2026-09-23T12:51:22.343Z  [WARN]  [Cloud]  S3/smartlife: failed — code=1106 msg=permission deny  ×3 — 11:32:59, 11:37:05, 12:51:22
  2026-09-23T12:51:22.088Z  [WARN]  [Cloud]  S2/uid=bay17901: failed — code=1106 msg=permission deny  ×3 — 11:32:59, 11:37:05, 12:51:22
  2026-09-23T11:32:30.263Z  [ERROR]  [Cloud]  Token failed: sign invalid  ×2 — 11:31:28, 11:32:30
Hi Dietrich,
First, update to 1.0.241 (Tuya Local | Homey). Until then the Bridge’s own list still shows the thermostats’ data points mixed into its own, which makes the picture confusing to read.
Then one experiment, and it’s the only thing I need from you right now. Take one thermostat at a time, change its target temperature by two or three degrees, wait a moment, then open DP Debug → Bridge with Auto-refresh on and look at that sub-device’s section. Tell me which number moved and to what.
  • On the Zigbee one I expect DP 2 to follow (it reads 60 now, so 6.0 °C — set it to 8 and it should read 80).
  • On the Bluetooth one my guess is DP 16 (it reads 220, which would be 22.0 °C). That one really is a guess from a single reading, which is exactly the kind of thing that has misled me twice recently — so it’s worth two minutes to check rather than assume.
    That gives me both layouts, and it also confirms which identifier belongs to which thermostat.
What happens after that is on my side, and it’s the harder half. Reading them is solved. Sending a command to a sub-device is a different matter: the library I use can address one, but its request looks different from the implementation that’s known to work elsewhere, and I have no such gateway here to test against. So that part will take a while and I won’t promise a date.
Nothing else needed in the meantime — the map is the useful thing right now.
Kind regards,
Andi
Hi Jeppe,
You diagnosed it exactly right, and your error message names the cause better than I could have. That one list had to be two things at once — the choices Homey shows and the values sent to the device. On a unit that names its modes you never notice. On yours, which numbers them, the two can’t be the same list.
In 1.0.242 it can carry both, written the way you proposed: Tuya Local | Homey
auto=0,cool=1,dry=2,fan=3,heat=4
Left is what Homey shows and what flows see, right is what goes to the AC and what it sends back. Same for Fan speed — yours looks like DP 5 with the same numbering, so something like auto=0,low=1,medium=2,high=3 once you’ve checked which number is which. A list without equals signs behaves exactly as before, so nothing else changes.
Three other things in your bundle that you didn’t ask about but are worth fixing, because pairing guessed wrong:
Child lock DP is 7. On your unit DP 7 is auto, not a child lock. Set it to 0.
Swing DP is 8 — and so is Eco. Both point at DP 8, which is eco. Your real swing is gear_vertical on DP 31 (currently “8”), with gear_horizontal on DP 34 if you want the second axis. Those are numbered enums too, so the same name=value form applies.
Fault DP is 20, which doesn’t exist on your device. Harmless, but set it to 0. Your actual error_code is DP 134, raw-encoded, which the driver can’t read yet.
Unrelated: your Cloud Lookup is failing with “The data center is suspended” — that’s your Tuya IoT trial having expired, not the app. Extending it is free but takes a day or two: Cloud → Cloud Services → IoT Core → View Details → Extend Trial Period.
If the mode picker follows your unit after the update, I’d be glad to hear it — and if the fan speed numbering turns out different from my guess, tell me what DP 5 actually shows.
Kind regards,
Andi
Hi Andi,
I’ve installed the new version and tested the switch-state fallback.
I stopped the charger externally. Homey correctly reports the charger state as plugged_in_paused / PAUSE, with 0 W and 0 A, but the Homey on/off switch still remains ON.
So DP109 → PAUSE is definitely reaching Homey correctly, but it doesn’t seem to update the switch state to OFF yet.
Current Homey state after stopping:
evcharger_charging: true
evcharger_charging_state: plugged_in_paused
measure_power: 0 W
measure_current: 0 A
The charger itself is stopped correctly; only the Homey switch remains active.
Hi Sebastian,
You found a bug in the fix, and a clean one — thank you for testing it properly rather than assuming it worked.
The fallback was meant to stand down once the switch data point starts reporting itself. But I checked whether that number had ever arrived in a packet — and a device echoing back the command Homey just sent is a packet. So the first time you pressed the switch in Homey, you switched the fallback off permanently. Exactly the case it was built for.
That’s why everything else looked right: DP 109 reaching Homey, the state going to plugged_in_paused, 0 W and 0 A. All of that was working. Only the one check in the middle was asking the wrong question.
It now stands down when the switch point reports a value of its own, which the app can already tell apart — an echo of our own command is filtered out before that point in the code, so anything that gets through is a genuine report.
My test had the same blind spot, which is why it went out broken: it started from a device that had never been switched from Homey. It now starts from yours — the number already seen — and requires the fallback to work anyway.
In 1.0.243. Please try the same test again: stop the charger externally, and the switch should follow within a second or two. If it doesn’t, tell me and I’ll stop guessing and ask for a support bundle instead.
Kind regards,
Andi
Hello Andi,
Zigbee:
DP2 = 225 → temperatur set to 22.5°C
DP3 = 230 → actual temperatur is 23°C
DP4 = manual / auto / freeze → modus
DP20 = true / false → automatic test valve
DP7 = true / false → child lock
DP18 = true / false → window open recognition
DP17 = open / close → window state
Bluetooth:
I don’t get any values for the second device anymore.
Hi Dietrich,
The Zigbee map is confirmed exactly as you read it — DP 2 target and DP 3 measured, both in tenths, DP 4 the mode, 7 child lock, 17 and 18 the window, 20 the valve test. One thing your device told us that its own Tuya specification does not: the mode has a third value, freeze. The specification lists only auto and manual. That’s the kind of thing only an actual device can settle.
The Bluetooth one didn’t stop — I lost it. The sub-device list was only held in memory, so updating the app emptied it, and it refills only as each sub-device speaks up again. A radiator thermostat can stay quiet for half an hour.
Worse, I had told you that an empty section means the gateway keeps its sub-devices to itself. That’s only true if nothing else can empty the list — and something could: me. Sorry for sending you down that path.
Fixed in 1.0.244. The list is kept across restarts now, and each entry shows a date rather than just a clock time once its last report isn’t from today, so a sleeping device no longer reads like a waking one. After the update your Bluetooth thermostat should simply be back, with nothing to do on your side.
If it’s still missing an hour or two after that, then it really has gone quiet — and that’s a separate question worth looking at, since it was reporting fine before.
Kind regards,
Andi
Hi Andi,
I updated the app. But since then the DP debug shows a change of the zigbee temperatur setting emidiatly but not the actual temperatur. Ok, a bit later the actual temperatur is there.
It shows no values for the Bluetooth device.
Ok, it took a long time until it shows values for the Bluetooth device. But now I have some:
DP2 = auto / manual / holidayready → modus
DP16 = 230 → temperatur set to 23°C
DP24 = 225 → actual temperatur is 22.5°C
DP101 = 300 / 0 → fast heating on / off
Fixed properly in the next version: what has once been seen stays, and a later report only updates its own entry.
Hi Andi,
I tested it again with v1.0.244, and unfortunately the switch still does not follow the actual charger state.
The car finished charging while it was still plugged in. At that point Homey showed:
  • evcharger_charging: true
  • evcharger_charging_state: plugged_in
  • Power: 0 W
  • Current: 0 A
  • Session energy: 8.5 kWh
So the charging switch remained ON even though charging had already finished.
This morning the car was physically unplugged from the wallbox. I checked Homey again immediately afterwards and got:
  • evcharger_charging_state: plugged_out
  • Power: 0 W
  • Current: 0 A
  • Voltage: 234 V
So Homey correctly detects that the vehicle is now unplugged (plugged_out), but the charging switch still remains ON (evcharger_charging: true).
This seems to be a very clear case: the charger state itself is reaching Homey correctly, but the switch capability is not being updated to false.
I can send you a support bundle from this state if that helps.
Kind regards,
Sebastian
Hi @Andi
Thanks so much for the suggestions. I’ve installed 1.0.245 and made the corrections you suggested (thanks) I have Homey working in Sync with Tuya and vice versa.
I’m still seeing the DP-numbers for “Mode” and “Fan speed” not the text strings. Am setting it up wrong?
Device settings
Device modes/fan speed
Also I did some messing about in DP debug and noted the following if that helps you. Happy to do some more testing if you need any help. Names noted in parenthesis are the actual titel/label in the Tuya IOS app:
Modes (DP4)
auto=0
cool=1
dry=2
fan=3
heat=4
Fan speed (DP5)
auto=0 (auto) note: dp=7 changes to true when auto is selected. False in any other fan speed setting
mute=1 (mute)
low=2 (low wind)
medium=3 (mid low wind)
normal=4 (mid wind)
strong=5 (mid high wind)
high=6 (high wind)
turbo=7 (strong wind)
Misc
dp=13 (Light) note: turns on/off the number display on the indoor A/C unit. False = off
dp=16 (Beep) note: turns on/off the beep when changing settings on the indoor A/C unit. False = off
dp=111 (Eco mode) note: false = off
Sleep (DP126)
standard=1 (Standard)
elderly=2 (The aged)
child=3 (Child)
Hi Andi,
I noticed another issue with the energy values and compared Homey directly with the original Tuya charger app.
The current live/session value actually seems to be correct:
Tuya app currently shows:
  • Duration: 02:37:03
  • Charged: 8.7 kWh
  • Current: 0.0 A
  • Power: 0.0 kW
  • Status: Ready to charge
Homey also shows:
  • charge_session_energy: 8.7 kWh
So Homey appears to be receiving the current 8.7 kWh session value correctly.
However, there are two things that don’t match:
  1. The Tuya charging history shows the completed charge from 24 September as:
  • 17:34–20:04
  • 2h30m
  • 8.0 kWh
But the charger’s live screen still shows 02:37:03 and 8.7 kWh. So it looks like the charger exposes a live/session counter separately from the final charge-history record.
  1. More importantly, Homey’s meter_power.charged currently shows 148.901 kWh.
The original Tuya charging history shows:
  • 110 charging sessions
  • 1391.1 kWh total
So 148.901 kWh clearly does not appear to represent the charger’s actual lifetime/total charged energy.
Could meter_power.charged currently be mapped to the wrong DP or have the wrong scaling?
I have screenshots from the original Tuya app showing both the 1391.1 kWh total history and the 8.7 kWh live/session value if you need them.
Kind regards,
Sebastian
Was testing a bit further and found this:
v1.0.245: value mapping only works outgoing
With auto=0,cool=1,dry=2,fan=3,heat=4, setting the mode from Homey works, but incoming changes (Tuya app, IR remote) are dropped. DP Debug shows DP 4 updating, but the capability doesn’t. With plain values 0,1,2,3,4, both directions work. Suspect the reverse lookup compares the device’s string "4" against a numeric 4. Same for fan speed (DP 5).
Hi Sebastian,
The switch: not a malfunction, but my design — and you’ve shown it’s the wrong one. “Plugged in, idle” counted as on because the charger does stand ready, and unplugged left the switch alone because that says nothing about whether the charger is enabled. Both defensible on paper, both wrong on your device.
The premise was unsound anyway: on a charger whose switch data point only takes commands, there is no source at all for “is it enabled”. I had the switch showing something the app cannot know. Whether it’s charging, it can know — so that’s what it shows now. WORKING on; PAUSE, IDLEINS, IDLE and SLEEP all off. Both of your cases come out right.
meter_power.charged is not mis-mapped. It is the app’s own counter, accumulated since you paired the device — 148.9 kWh is simply how much it has watched go through. Your charger’s real lifetime figure of 1391.1 kWh over 110 sessions exists only in Tuya’s cloud; there is no local data point carrying it. We established that back when the support bundle first came in, and nothing since has turned one up. So the two numbers are not supposed to agree, and no scaling change will make them.
If that’s not the number you want on the tile, the honest options are to leave it as “since Homey started counting” or to ignore it. I’d rather not fabricate a total by seeding it from a screenshot.
Your point about the live counter is a useful confirmation, by the way: 8.7 kWh and 02:37:03 on the live screen against 8.0 kWh and 2h30m in the history for the same charge. Those really are two different things in the firmware, which is exactly why the app reads them from two separate settings.
Hi Jeppe,
Both of your symptoms have one cause, and it’s mine.
You had the device’s own values in the setting before, so the mode capability was sitting on a raw “4”. When you switched to auto=0,…,heat=4, “4” is no longer in the list — the list now holds names — so the guard that stops a list from excluding the current value refused the change, and the old picker stayed.
Everything else follows from that. The picker kept showing numbers because its options were never replaced. And incoming changes were dropped because the driver was now correctly translating “4” to “heat” and writing it into a picker that had never heard of heat.
Your string-versus-number theory was a reasonable guess but lands next to it — the comparison was fine; the list of allowed values wasn’t. A current value that turns out to be a device value is now carried across to its name, with a line in the log saying so, and both directions work from the moment you save.
Your data point table is genuinely valuable — thank you. The fan speed names in particular (auto=0,mute=1,low=2,medium=3,normal=4,strong=5,high=6,turbo=7) are exactly what someone with the same unit will need, and I’d rather have your labels than invent my own.
Two notes on the others:
Eco: set Eco DP to 111. That one works today.
Sleep: the driver expects a boolean there, and yours is a three-value enum (standard / elderly / child). Setting Sleep DP to 126 would leave it permanently on. Better left at 0 until I give it proper values.
Light (13) and Beep (16) have no settings in this driver yet. Worth adding — they’re simple booleans, and I’ll note them.
If you’re still up for testing: after the update, confirm that changing the mode on the IR remote moves the Homey tile. That’s the direction that was broken.
Hi Andi,
Perfect! Thanks so much for the fix and suggestions once again! I can confirm that bi-directional mode/fan speed is working as expected in v1.0.246. Homey input and remote input stays in sync and names for mode/fan setting are shown. Let me know if there is anything else you need.
Just a note: (and I completely understand if this is out of the scope of your app!)
When bridging the Air Condition with Homekitty to Apple Home. Mode is “stuck” at Auto and only temp change seems to work. If you want I’m happy to do some testing on that side. Here’s a short screen capture: ScreenRecording_09-26-2026 13-03-17_1
For now I have set up the AC as an Advanced Virtual Device to bridge to Apple Home which is working fine. I would be nice however to just bridge your Tuya Local device. Any way thanks again for you suggestion and work, let me know if you need anything.
