Hi Andi,
here is the complete support bundle as requested.
One additional observation regarding DP102: the latest value is:
{“L1”:[2350,0,0],“L2”:[2350,0,0],“L3”:[2350,0,0],“t”:220,“p”:0,“d”:16800,“e”:37}
As mentioned in my previous post, the charger’s own app shows 1332.1 kWh lifetime energy, so d clearly does not appear to represent the lifetime counter.
The latest completed charging session in the charger app was 12.1 kWh, and during that session we observed d:11410, which would fit very well with 11.410 kWh at that point during the ongoing session.
Tuya Local 1.0.236 is otherwise working correctly now. Homey successfully showed the live phase measurements and Session Energy, which reached 3.1 kWh during our test.
I have attached/pasted the complete support bundle below.
Thank you!
Tuya Local v1.0.236 — support bundle
Generated: 2026-09-20T20:49:54.630Z
App started: 2026-09-20T20:37:14.228Z (running 12m 40s)
Homey: 13.5.0
Cloud lookup: configured (eu) — account listing not attempted since the app started
DEVICE Wallbox
driver ev_charger
model dé EV Charger gd version (product gxrtu5vljdthtd3g)
device id bf2272…
available yes
protocol configured 3.5, connected 3.5 ip
status Connected · last seen 20.09.26, 22:49:47 · poll 10s
history 1 connection since app start · up 12m 39s total · avg 12m 39s · longest 12m 39s
packets 91 received · 0.12/s while connected · data ever received: yes
DP mapping
dp_charge_current 150
dp_clear_energy 0
dp_connection_state 0
dp_current_a 0
dp_current_b 0
dp_current_c 0
dp_energy_total 0
dp_fault 0
dp_live_updates 0
dp_phase_a 0
dp_phase_b 0
dp_phase_c 0
dp_phase_json 102
dp_power_total 0
dp_session_energy 0
dp_switch 18
dp_temperature 0
dp_timer_on 0
dp_voltage_a 0
dp_voltage_b 0
dp_voltage_c 0
dp_work_mode 0
dp_work_state 109
other settings
amp_scale “1”
command_gap_ms 100
current_max 16
current_min 6
current_scale “1”
estimate_power true
fire_and_forget true
json_current_divisor 10
json_energy_divisor 10
json_power_factor 100
json_temp_divisor 10
json_voltage_divisor 10
lock_protocol false
nominal_voltage 230
offline_grace_seconds 60
phase_count “3”
power_scale “1”
reconnect_interval 0
session_energy_scale “0.1”
temp_scale “1”
total_energy_scale “0.1”
total_energy_source “estimate”
voltage_scale “1”
live DPs (updated 2026-09-20T20:44:03.767Z)
DP 101 200 number
DP 102 “{“L1”:[2350,0,0],“L2”:[2350,0,0],“L3”:[2350,0,0],“t”:220,“p”:0,“d”:16800,“e”:37}” string
DP 105 “{“t”:“2026-09-20 15:09:32”, “s”:“15:09”,“e”:“17:42”,“d”:9159,“c”:121}” string
DP 106 “{“r”:“Type B, AC 30mA + DC 6mA”,“fv”:“2.9.13”,“cp”:“9.2”,“t”:“280”,“e”:“2621”}” string
DP 107 “[6, 8, 10, 13, 16]” string
DP 109 “IDLEINS” string
DP 150 16 number
DP 151 “{“m”:0,“dt”:0,“ss”:“00:00”,“se”:“08:00”}” string
DP 152 16 number
DP 153 “state: WORKING → IDLEINS” string
DP 188 false boolean
DP 189 598 number
cloud spec code / dp / type / value / range
x_work_state 101 value null
x_metrics 102 string null
x_selftest 103 string null
x_alarm 104 string null
x_charge_history 105 string null
x_charger_info 106 string null
x_adjust_current 107 string null
x_downcounter 108 value null
x_work_st_debug 109 enum null
x_do_charge 140 bool null
x_do_reset 141 bool null
x_do_reboot 142 bool null
x_charge_current 150 value null
x_charge_mode 151 string null
x_max_current_cfg 152 value null
x_lang_cfg 153 string null
x_socket_cfg 154 value null
x_nfc_cfg 155 bool null
x_earch_free_cfg 156 bool null
x_product_varient 157 value null
x_heartbeat 188 bool null
dp_num 189 value null
LOG — warnings, errors and connection events, newest first
29 of 29 distinct messages from 98 of 436 entries. Repeats are folded into one line. The device sections above carry the DP mapping and the live values — please include them when quoting this report.
2026-09-20T20:37:16.076Z [INFO] [Wallbox] The phase JSON carries d=13800, which this driver does not map: it is either 13.80 kWh counted in watt-hours or 138.00 kWh counted in hundredths, and two readings cannot tell which. Compare it against your charger’s own lifetime counter and report it, and it can be mapped properly.
2026-09-20T20:05:39.661Z [WARN] [Wallbox] DP 189 is counting up (477 → 598) but is not mapped to anything. If the charged-energy total stays at zero, set “Session Energy DP” to 189 in the device settings — on most of these chargers the rising counter is DP 1, while DP 25 holds the previous session and does not move during a charge.
2026-09-20T19:41:45.448Z [WARN] [Wallbox] DP 101 is counting up (100 → 300) but is not mapped to anything. If the charged-energy total stays at zero, set “Session Energy DP” to 101 in the device settings — on most of these chargers the rising counter is DP 1, while DP 25 holds the previous session and does not move during a charge.
2026-09-20T19:41:36.165Z [WARN] [Wallbox] Connection failed: connection timed out — nothing answered in time. The device is asleep, still starting up after a power cut, or busy with another connection; these devices accept exactly one. The app keeps retrying on its own.
2026-09-20T19:41:36.164Z [WARN] [Wallbox] connection timed out — nothing answered in time. The device is asleep, still starting up after a power cut, or busy with another connection; these devices accept exactly one. The app keeps retrying on its own.
2026-09-20T19:41:27.632Z [WARN] [Wallbox] Disconnected: socket closed (up 16m 3s, 86 packets)
2026-09-20T19:27:04.674Z [INFO] [Wallbox] The phase JSON carries d=4240, which this driver does not map: it is either 4.24 kWh counted in watt-hours or 42.40 kWh counted in hundredths, and two readings cannot tell which. Compare it against your charger’s own lifetime counter and report it, and it can be mapped properly.
2026-09-20T17:48:14.160Z [WARN] [Wallbox] Disconnected: socket closed (up 1h 37m, 316 packets)
2026-09-20T17:48:14.159Z [WARN] [Wallbox] Disconnected: socket closed (up 1h 37m, 317 packets)
2026-09-20T17:48:14.158Z [WARN] [Wallbox] Disconnected: socket closed (up 1h 37m, 154 packets)
2026-09-20T17:53:16.467Z [WARN] [Wallbox] work_state: unknown value “SLEEP” — expected one of charger_free, charger_insert, charger_free_fault, charger_wait, charger_charging, charger_pause, charger_end, charger_fault, charger_start_wait, charger_stop_wait ×12 since 2026-09-20T16:17:06.283Z
2026-09-20T17:48:18.901Z [WARN] [Wallbox] work_state: unknown value “IDLE” — expected one of charger_free, charger_insert, charger_free_fault, charger_wait, charger_charging, charger_pause, charger_end, charger_fault, charger_start_wait, charger_stop_wait ×9 since 2026-09-20T16:12:08.923Z
2026-09-20T16:11:14.620Z [WARN] [Wallbox] Disconnected: socket closed (up 12s, 1 packet)
2026-09-20T16:11:07.607Z [WARN] [Wallbox] Disconnected: socket closed (up 3h 9m, 651 packets)
2026-09-20T16:11:01.203Z [WARN] [Wallbox] Disconnected: socket closed (up 22s, 2 packets)
2026-09-20T16:10:57.607Z [WARN] [Wallbox] Disconnected: socket closed (up 1h 20m, 413 packets)
2026-09-20T16:10:35.612Z [WARN] [Wallbox] Disconnected: socket closed (up 1h 10m, 255 packets)
2026-09-20T20:38:59.031Z [WARN] [Wallbox] DP 101 is counting up (200 → 300) but is not mapped to anything. If the charged-energy total stays at zero, set “Session Energy DP” to 101 in the device settings — on most of these chargers the rising counter is DP 1, while DP 25 holds the previous session and does not move during a charge. ×3 — 15:19:12, 15:19:12, 20:38:59
2026-09-20T15:08:10.146Z [WARN] [Wallbox] DP 189 is counting up (135 → 229) but is not mapped to anything. If the charged-energy total stays at zero, set “Session Energy DP” to 189 in the device settings — on most of these chargers the rising counter is DP 1, while DP 25 holds the previous session and does not move during a charge. ×2 — 15:08:10, 15:08:10
2026-09-20T14:50:40.734Z [WARN] [Wallbox] Disconnected: socket closed (up 14m 29s, 48 packets)
2026-09-20T14:08:41.759Z [WARN] [Wallbox] DP 189 is counting up (49 → 135) but is not mapped to anything. If the charged-energy total stays at zero, set “Session Energy DP” to 189 in the device settings — on most of these chargers the rising counter is DP 1, while DP 25 holds the previous session and does not move during a charge.
2026-09-20T20:43:56.353Z [WARN] [Wallbox] work_state: unknown value “IDLEINS” — expected one of charger_free, charger_insert, charger_free_fault, charger_wait, charger_charging, charger_pause, charger_end, charger_fault, charger_start_wait, charger_stop_wait ×17 since 2026-09-20T13:08:29.094Z
2026-09-20T13:08:29.076Z [WARN] [Wallbox] DP 101 is counting up (204 → 300) but is not mapped to anything. If the charged-energy total stays at zero, set “Session Energy DP” to 101 in the device settings — on most of these chargers the rising counter is DP 1, while DP 25 holds the previous session and does not move during a charge.
2026-09-20T13:02:07.632Z [WARN] [Wallbox] work_state: unknown value “PAUSE” — expected one of charger_free, charger_insert, charger_free_fault, charger_wait, charger_charging, charger_pause, charger_end, charger_fault, charger_start_wait, charger_stop_wait
2026-09-20T17:48:17.203Z [WARN] [Wallbox] work_mode: could not set “{“m”:0,“dt”:0,“ss”:“00:00”,“se”:“08:00”}”. Many chargers report modes they don’t implement — check DP 33 (mode_set) for the real list. ×3 — 13:01:46, 16:11:17, 17:48:17
2026-09-20T20:38:58.728Z [WARN] [Wallbox] work_state: unknown value “WORKING” — expected one of charger_free, charger_insert, charger_free_fault, charger_wait, charger_charging, charger_pause, charger_end, charger_fault, charger_start_wait, charger_stop_wait ×15 since 2026-09-20T13:01:46.133Z
2026-09-20T12:39:43.956Z [WARN] [Wallbox] DP 150 is counting up (11 → 16) but is not mapped to anything. If the charged-energy total stays at zero, set “Session Energy DP” to 150 in the device settings — on most of these chargers the rising counter is DP 1, while DP 25 holds the previous session and does not move during a charge.
2026-09-20T12:32:34.921Z [WARN] [Wallbox] DP 101 is counting up (101 → 200) but is not mapped to anything. If the charged-energy total stays at zero, set “Session Energy DP” to 101 in the device settings — on most of these chargers the rising counter is DP 1, while DP 25 holds the previous session and does not move during a charge.
2026-09-20T20:37:15.437Z [INFO] [Wallbox] Connected ×16 since 2026-09-20T12:28:10.596Z
