App is working again with the Test version. Thx!
Please check the latest test version - not sure if it will work though, as I donât have those devices myself.
Also the latest error, which was popping up, shall be fixed (getDriverName) - but given the review process, itâs waiting for Athom review
It works great, many thanks, this is brilliant, so quick to implement
I had to re-publish TEST, which will be the main branch having the recently reported issues fixed, due to the name change (used too many words when I checked SDK).
so current LIVE version - TP-Link Smart Devices App for Homey | Homey - broken for plugs
current TEST 0.2.0 - TP-Link KASA LAN | Homey - having fixes and support of two new plugs
0.2.0 will be LIVE / stable, shall be working for everyone - hopefully Monday (waiting for Athom).
0.2.1 will be new TEST / experimental - not yet published
When Athom will perform review, that new âexperimentalâ version 0.2.1 will be based on new API and needs to be tested. I just must verify that this version will remain as TEST and not live
LIVE version
0.2.0 - 28. 1. 2024
Adding KP105, KP115,Fix getdrivername is not defined, Flow title fix, New name
TEST version
0.2.2 - 28. 1. 2024
Added support for HS210 - 3way
0.2.1 - 28. 1. 2024
Experimental - compatibility updates due to the plink-smarthome-api v5
Please - try the TEST version, if it will not work, submit DIAGNOSTIC REPORT and go back to LIVE version
Hi Sharkys,
Do you plan on adding support for the HS220? I have 7 of these dimmers set up in my home.
Jonathan
On/Off possibly yes, that should be very quick, not sure about dimming capabilities as this require new classâŚlet me check, no promisses though and will be probably broken on several attempts as I do not own this device.
LIVE version
0.2.0 - 28. 1. 2024
TEST version
0.2.4 - 31. 1. 2024
Attempt do add KS230 3-way dimmer + handle more errors during pairing
0.2.3 - 31. 1. 2024
Attempt to add HS220 Dimmer
0.2.2 - 28. 1. 2024
0.2.1 - 28. 1. 2024
Just tried to add my HS100. Process was simple and is working well.
Excellent.
Thank you,
Andy
FYI, I have requested Athom to publish TEST to LIVE version (usually take a day), so all the latest updates will be deployed.
In case of any significant issues, please let me know by sending diag. report (I hope there will be none as some of you are using TEST already)
0.2.4 - 31. 1. 2024
0.2.3 - 31. 1. 2024
0.2.2 - 28. 1. 2024
0.2.1 - 28. 1. 2024
Hi @Sharkys! Saw that youâre doing some ongoing dev work on this app. I had submitted a ticket via Athom regarding my TP-Link Kasa devices becoming unavailable with a message âDevice Unavailable Rate Limitedâ
I did a search on the thread and donât see anyone else mentioning âRate Limitedâ so I donât know if itâs an issue youâre aware of or could address.
I do have a bunch of TP-Link Kasa devices, many of which do Energy Monitoring. Iâd be willing to adjust polling rates to regain control of my devices, but suspect that thereâs an API-based fix for the issue. Hereâs my inventory in case it points to something specific:
3xHS300 - Surge strip w/ 6 addressable outlets
2xKP405 - Outdoor dimmer plug
4xHS103 - Smart Plug
1xHS105 - Smart Plug
4xKP125M - Matter Smart Plug
8xEP25 - Smart Plug
Happy to share any additional details youâd require if youâre interested.
I call it rather maintenance, Iâm not really a dev
But arenât those all related to the Athom CLOUD based integration ? So Rate limit error is related to the Cloud API restrictions of TP-LINK. This app in this thread is for devices with enabled LAN control - have you tried to add those devices after installing this app with their IP and enabled LAN control (if available) ?
From the list, those could work (my assumption as I do not have those devices) :
2xKP405 , 4xHS103 , 1xHS105 - you can try to add them just by selecting HS100/110 (depending if those have power measurement or not)
3xHS300 - might require much more work due to the subdevices
ButâŚ
4xKP125M - of those are Matter Plugs, why not to add them as Matter devices ?
8xEP25 - not sure, seems those devices require additional authentication, you may try to ask in the TAPO thread - [APP][Pro] Tapo - #19 by Jos_van_Vliet
TEST version TP-Link KASA LAN | Homey submitted for Athom review, will be next LIVE, fixing some issues which seems existed since SDK3 migration.
Version 0.2.5
- Re-Added registerRunListener (error since SDK3 migration), fixes for Reset meter/Undo reset meter functionality, cleanups
Hi, My Kasa KL50 bulb is not accessible through Homey anymore. I suspect since Homeyâs upgrade to 10.0.6. The bulb has always worked and is still manageable through Kasaâs original app. The bulb has also still the same fixed IP-address it has always had. Pinging gives reply. So that all seems OK.
When I remove the bulb in Homey and re-add it, it is found and added. But when I try to switch it on/off I get the error âcould not get device by idâ.
I tried re-installing the app within Homey, rebooted Homey via software and also via powercycling, nothing seems to help.
Is there something else I can do?
Try to send diag⌠stating KL50 in the details.
FYI, fixed
0.2.7 - 11. 2. 2024
Fixes for bulbs
0.2.6 - 10. 2. 2024
drivers sync, attempt to fix some crashes
Hi @Sharkys , thanks a lot for the great work and support. Do you have any plan to support HS300 like devices which has multiple energy monitoring plugs on a power strip. I am happy to donate if you need.
Might be possible, API supports itâŚbut will take time, as this require to write new driver from scratch.
Just donated some coffee money in case youâre looking for some motivaton for an HS300 driverâŚor if youâre not. Thanks for the app either way! Glad to regain control of my TP Link devices locally w/o Athomâs appâs issues!!
Thank you @chaosrain
@subho @chaosrain , first experimental test for HS300. My tests are based on simulator, so please take it really as first alpha.
I have rewritten also the discovery process, it never worked the way it was set, mostly for multiple devices - it only counted with one device per pairing. Anyone feel free to test and report back your experience.
Version 0.2.8
Rework of discovery mechanism, pairing view, allow addition of multiple devices and added HS300(US) multisocket
Version 0.2.9
Added KP405
