[APP][Pro] TP-Link Deco
To all a new test relese covering alot is published; TP-Link Deco | Homey
Fixed login failure on X50 and X55 routers running firmware 1.8.0 or newer. These models require a different request format during authentication — the app was sending the wrong format, which caused the router to reject the login with a misleading “Wrong password” error even when the password was correct. Reduced unnecessary background API calls on non-LTE models and X50-5G routers.
@MathiasT Thanks for the update.
I removed the app en reinstalled it. But when I try to a Deco X50 I still get the same error.
71dc58a2-38ba-4b95-8a1e-8269f582d0c9
@MathiasT , thank you! I just tested as well, but are still unable to log in and add my X55. Tried with the beta-version you shared, and my Deco is on v.1.8.0.
Diagnostics code e9e6829f-5016-482a-9085-671d58ab73c8
I think I am having the same problem as Gibstorm here since 5 days…
I have 4 Deco BE65 Pro’s in a mesh. It works well, but i can’t see any clients in a flow.
Am i missing something?
There are more issue’s with the app. Tried to add the deco’s after deleting them, but the this error appears:
The credentials are okay, because it works in the webinterface.
I have published a updated version based on feedback for testing. it also gives a bit more logs TP-Link Deco | Homey
Med vänlig hälsning / Best regards
Hi Mathias,
new version of the app installed, rebooted all deco’s, rebooted Homey, unfortunate I get the following error:
I apperently implemented a regression into the code. Coding late at night might do this :slight_smile: . made some changes and published a ned test version for you to give feedback to.
Installed this new version but still getting this error.
43901c8b-6c5b-4fb3-9c29-c434aa22df00
Yep, same here. Even after reinstall and reboot.
Thanks for the diags, they help. I have made som minor changes to the login fallback. please thest 1.4.41 TP-Link Deco | Homey
provide diags as it helps.
Just tested the latest test version, but unfortunately the same error.
4addc4a5-0ff7-4727-89b0-d33b031ae64c
I hade a PR that did not commit - that was the actual change. must be wimsy. lets try now;
Tested it and now I get this error:
2a525300-a94e-4392-9757-3a28704b146c
This was mote heölp ful, there was a compeeting thread, casuing the login lockup. 1.4.43 hs been relesed to test TP-Link Deco | Homey
Now I get the error: another pairing sessions is active, while I restarted homey and decos
Tested I’m getting the same error: 91065980-a455-4562-99bf-a5f790e0e49f
Same here.
1.4.44 in test TP-Link Deco | Homey
if you ar comfortable, browsing you web UI to the router while having Developer mode and the networking tab open. then export the HAR file that woould also help. please browse around the admin UI and click on all links.
