Yes now its working, i managed to add may Tesla.
Excellent, now it works!
Yes it works now again
Maybe TeslaFI wakes the car?
As I said, when I disable the app it falls a sleep. I have no problems with Teslafi waking the car.
It seems like it let the car sleep for 37-38 minutes and then wakes it up.
@Christer_Sjostrom So have you unchecked the “Data fetch enabled” ?
Sorry, I should have read your instruction more carefully. When I unchecked the “Data fetch enabled” the car fall a sleep.
BTW, why would someone want to have the care wake up every 60 minutes (as an example)?
Which data fetch interval (minutes) would you advise me? I want the car to be kept awake at a minimum. But what I do want when the car starts moving or stops (I use the shift state for this) because this is known in the app as soon as possible so that I can do something with it with a flow.
You can disable the data fetching if you want, but then the app won’t discover all changes.
You can use flows to set the data fetch interval, eg. 1 minute in the morning when you leave for work, and then set it to a higher value when you enter the geofence for work. There are lots of possibilities.
I can’t find the option to disengage the charger cable from the charger port. You suggested using a “charge door” action, I tried using a “charging” action myself, but none of those are working. The charging port door closes by itself anyway.
What I want is to disengage the charger cable so I can just pull it out of the car when I switch of a dedicated light in my house by pushing a button (Philips hue dimmer). Any suggestions?
This is ist, stopps charging and unlocks the cable
Great! That was the one.
May I say the description is not completely clear?
Have a nice day, thanks
Thom
but 90 % clear ? ![]()
It suggests it controls te door that covers the charger. Hence the “not completely clear”
But maybe it is due to translation differences
Thom
OK, I think I copied the name from the Tesla API:
So, you think “Open charge port” and “Close charge port” is better ?
In my humble opinion “lock charger” and “unlock charger” would be more clear.
Thom
Can it be that locations can no longer be deleted via flows?
Adding locations works, only deleting them doesn’t. I have now tried it via the app and via the web browser.
Yes. Thanks for reporting.
Fixed in v. 1.2.8:
