[APP][Pro] Tesla Smart Charger
Did it work with 2022.8.2?
Yes
/Johan
Actually I don’t know, my previous version was 2022.4.5.18.
With my previous version it worked fine, but I guess Tesla made some changes to their api and it broke something… :thinking:
/Johan
Please check v. 1.5.5 with fixes for authentication errors.
cc: @Volden @awientjes @Seljebobo @proisland @Johan_Persson1 @FEY
Thanks, it’s working now.
Still doesn’t work for me although I do have the new version installed. Error: fetching tokens failed
Hi!
It’s working just fine now! :+1:
Thanks! :grinning:
Weird,I don’t know what is going wrong… the code works for Teslafi but not anymore on homey. I’ll wait for a day and see what happens.
Try re-pairing from the settings → maintenance menu.
In a final attempt I removed the car from homey, but now I can’t add it due to the failing attempt…
Hi!
I would like to charge the car only when it’s home, battery is below the charge limit and prices are below a certain price (as defined by the app or perhaps my Tibber integration). And stop the charging when prices go above the same level.
Looks like this could perhaps be done in several ways in the app. What would be the most elegant solution?
You can create a diagnostic report by pressing the “Create diagnostic report” - button in the app settings, and I might see what’s wrong.
First try to add the car, then create the report.
It is working again. Cool
I have an assumption to verify: with the previous version I tried to rebuild the connection, using the iPhone “Auth for Tesla” app. I think requested a refresh token too many times, resulting in a (temporary) block from the Tesla service. When I obtain the token on 5G it works, but the token is not accepted on Homey. So my assumption: Do you have to be on the same network as the Homey device when you request the token? I’ll retry it when I get back home.
I’m new to this app, just started using it after the latest update. I’ve disabled data fetch since I only use it to trigger my garage port when my vehicles comes home.
The problem is that it doesn’t always work, and it seems like restarting the app makes it work again (might be a wrong assumption).
I’ve created a diagnostic report: d4c302a2-33e8-4100-8440-d4d592b88507
The only way for the app to figure out where the car is, and if it’s coming home, is by polling the position or receiving the positing when streaming.
From reading previous posts I understood that it will stream the position when the car is driving even if data fetch is disabled. It worked this morning when arriving home, but didn’t later in the day.
I got the 2022.8.3 Update and the conection is still working
It only starts streaming if it sees that the car is online and driving. So it must pull at least once to see that.
Thanks @balmli it works again.
Did any write a flow or script to use the smart charger in combination solar panels and energy levels at home to balance the charging of the car and the power used at home?
I would like to use the “extra” capacity of my solar panels to charge the car. The best way to balance this is to increase/decrease the “charging current” amperes I suppose.
So I am looking for a flow/script that does this based on the energy used from my home.
