Check out 2.8.9
Yes with the fix I can save it !!! GREAT
Thanks! It’s working now. ![]()
That it fails to send an Image. If you scroll to the left you can see the reason
Send me a diagnostic report or try to understand the error message
613019e5-443d-4903-acc1-4c25101da559
Thank you for helping
Before the update it working fine !
Bad Request: can’t parse entities: Character ‘(’ is reserved and must be escaped with the preceding ‘\’"
Please read the error. Make sure you‘re escape non markdown characters.
It looks like your variables have special characters in it. Ether switch to html or use BLL to escape
So in the flow above what must I do then ?
This
Yeah oke but why does it not work in this flow ?
If I make a normal flow and worry bold then I’m
Sending a message
Because you’re using variables that use SPECIAL characters. e.g . , * / & % $
And Telegram can’t differ from a Markdown SPECIAL character.
So these non-Markdown Characters have to be escaped using a / e.g., /( or /* or /, since you can’t do this, because you’re using variables, you have two ways to fix this. Either use HTML Markdown or use Better Logic Library and add a custom function for escaping
Like this one and use it like this: {[escapeRegex(variable)]}
function escapeRegex(string) {
return string.replace(/[/\-\\^$*+?.()|[\]{}]/g, '\\$&');
Is it possible to call the inline menu by a /command command like
If telegram was received
And it contains /lights
Show inline menu “lights”
I’ve been using the other Telegram Homey app for many years. It’s a live ‘logbook’ on what is happening in my house. Almost every action/motion etc. is reflected there.
However, I’m missing important capabilities that I do find here. So I’m going to slowly move over my integrations to this app. First of all, thanks for the efforts so far!!
A simple integration, but important to my security system is sending images to my Telegram bot.
I’ve tried a direct URL, an Image tag from the security camera and Image Grabber, but all are failing to get the image in my telegram using the “Send Image with message” card.
Any ideas? Normal messages are send ok.
This error below from the logs is when I directly use the snapshot tag in my flow.
GrammyError: Call to ‘sendPhoto’ failed! (400: Bad Request: IMAGE_PROCESS_FAILED)
at toGrammyError (/app/node_modules/grammy/out/core/error.js:35:12)
at ApiClient.callApi (/app/node_modules/grammy/out/core/client.js:86:48)
at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
at async /app/flow/actions/sendTagImageWithMessage.js:23:17
Flow:
Could you send me a diagnostics report right after this error is happening?
Hi all,
Has anyone been able to get the URL/Hyperlink markdown to work?
I would like to send a Google Maps link over Telegram, but don’t want to include the full url.
I’ve been reading that [text](http://example.com) should work, but it doesn’t.
Looking forward to your thoughts on this!
it should work. Did you enable MarkdownV2 in the settings?
*Hi\!* _Welcome_ to [Telegram](https://telegram.org)\.
This worked for me.
