[APP][Pro] Support for ONVIF compatible cameras (Release 2.0.70, Test 2.0.76)
Done. 65001 is routing to one of the camera’s on the NVR. It’s not working after adding but we are one step further.
What’s not working?
The log stops just as it is trying to get the snapshot, so I can’t see if that’s working.
I changed a log again. There is a time-out after 10 sec.
If you paste:
http://192.168.254.2/onvif-http/snapshot?Profile_1
in to your browser can you see any image?
No. I need to change to 192.168.2.18:65001/onvif-http/snapshot?Profile_1 (and login)
2.18 is the NVR and 65001 routes to cam 1 on the NVR. 65002 is cam 2. I have activated this on NVR, this is not standard in Hikvision.
After changing to 192.168.2.18:65001/onvif-http/snapshot?Profile_1 still no image. In the browser, after sharing credentials, the image is visible. I have send log.
It looks like you have missed the http:// from the front of the URL.
That’s working but I do get a ECONNRESET
Do you get that every time?
The app initially tries various methods to authentic until it gets it right. After that it should keep using that method.
Everything is working perfect now. Thanks for support. Please keep in mind that you need to uncheck ‘add nvr’ and use ports 65001 etc. You have to add all the seperate cameras
I bought a Tapo C520 SW camera.
I added it to Homey via the app using ONVIF.
After that, I wanted to add the camera feed to the Dashboard.
However, when I go to the camera section in the Dashboard, the camera is not found.
Does anyone have an idea how I can fix this?
Does it show an image when you open the device settings?
Example:
No, it doesn’t
OK. You’ll have to fix that first.
I have a feeling the Tapo cameras don’t support snapshots :thinking:
Hey, got a question for you: I was able to include an Instar IN-8415 2K+ I do get snapshots, and I believe motion works as well, could not test it yet.
Now, I was wondering if there’s a way to trigger – say with a contact alarm on – the camera to start recording.
There’s nothing in the app to control the cameras.
I see, would “Enable Motion” work if the camera is set to record a video if motion is detected? forget this, this can’t work
Yes all ports are enabled and the values ​​given are as below.
Hi Adrian! I have been following this thread for a long time and I am impressed by your endurance taking care of all questions. I have 8 Reolink RLC-811A cameras connected to a NVR and it’s easy to import them via Onvif in Homey but then I get the ERR_INVALID_PROTOCOL. Processing: Skärmavbild 2025-03-25 kl. 21.14.00.png…. I paste my diagnostic error report here and would be so thankful if you could help out :slight_smile: I have seen in the other posts that I should change in. my Reolink settings to HTTP instead of HTTPS but there is no such setting? Log ID: 2025-03-25T08:06:20.420Z
App version 2.0.48
8:6:20.420: Closing server
8:6:20.654: cpuwarn! 1 of 5
8:6:20.666: Server closed: undefined
18:39:0.725: SnapShot error (192.168.0.36 (Ch3)): Protocol “https:” not supported. Expected “http:”
18:39:0.737: SnapShot error (192.168.0.36 (Ch3)): Protocol “https:” not supported. Expected “http:”
18:39:0.747: SnapShot error (192.168.0.36 (Ch3)): Protocol “https:” not supported. Expected “http:”
18:39:0.755: SnapShot error (192.168.0.36 (Ch3)): Protocol “https:” not supported. Expected “http:”
18:39:0.767: SnapShot error (192.168.0.36 (Ch3)): Protocol “https:” not supported. Expected “http:”
18:39:0.770: Fetch NOW error (192.168.0.36 (Ch3)): ERR_INVALID_PROTOCOL
18:39:0.779: SnapShot error (192.168.0.36 (Ch3)): Protocol “https:” not supported. Expected “http:”
18:39:0.781: Fetch NOW error (192.168.0.36 (Ch3)): ERR_INVALID_PROTOCOL
18:39:4.880: SnapShot error (192.168.0.36 (Ch3)): Protocol “https:” not supported. Expected “http:”
18:39:4.888: SnapShot error (192.168.0.36 (Ch3)): Protocol “https:” not supported. Expected “http:”
18:39:4.903: SnapShot error (192.168.0.36 (Ch3)): Protocol “https:” not supported. Expected “http:”
18:39:4.910: SnapShot error (192.168.0.36 (Ch3)): Protocol “https:” not supported. Expected “http:”
18:39:4.923: SnapShot error (192.168.0.36 (Ch3)): Protocol “https:” not supported. Expected “http:”
18:39:4.924: Fetch NOW error (192.168.0.36 (Ch3)): ERR_INVALID_PROTOCOL
18:39:4.931: SnapShot error (192.168.0.36 (Ch3)): Protocol “https:” not supported. Expected “http:”
18:39:4.933: Fetch NOW error (192.168.0.36 (Ch3)): ERR_INVALID_PROTOCOL
18:39:29.753: SnapShot error (192.168.0.36 (Ch3)): Protocol “https:” not supported. Expected “http:”
18:39:29.759: SnapShot error (192.168.0.36 (Ch3)): Protocol “https:” not supported. Expected “http:”
18:39:29.773: SnapShot error (192.168.0.36 (Ch3)): Protocol “https:” not supported. Expected “http:”
18:39:29.780: SnapShot error (192.168.0.36 (Ch3)): Protocol “https:” not supported. Expected “http:”
18:39:29.789: SnapShot error (192.168.0.36 (Ch3)): Protocol “https:” not supported. Expected “http:”
18:39:29.790: Fetch NOW error (192.168.0.36 (Ch3)): ERR_INVALID_PROTOCOL
18:39:29.799: SnapShot error (192.168.0.36 (Ch3)): Protocol “https:” not supported. Expected “http:”
18:39:29.800: Fetch NOW error (192.168.0.36 (Ch3)): ERR_INVALID_PROTOCOL
18:39:44.262: SnapShot error (192.168.0.36 (Ch6)): Protocol “https:” not supported. Expected “http:”
18:39:44.271: SnapShot error (192.168.0.36 (Ch6)): Protocol “https:” not supported. Expected “http:”
18:39:44.282: SnapShot error (192.168.0.36 (Ch6)): Protocol “https:” not supported. Expected “http:”
18:39:44.294: SnapShot error (192.168.0.36 (Ch6)): Protocol “https:” not supported. Expected “http:”
18:39:44.307: SnapShot error (192.168.0.36 (Ch6)): Protocol “https:” not supported. Expected “http:”
18:39:44.310: Fetch NOW error (192.168.0.36 (Ch6)): ERR_INVALID_PROTOCOL
18:39:44.319: SnapShot error (192.168.0.36 (Ch6)): Protocol “https:” not supported. Expected “http:”
18:39:44.321: Fetch NOW error (192.168.0.36 (Ch6)): ERR_INVALID_PROTOCOL
18:39:46.144: SnapShot error (192.168.0.36 (Ch6)): Protocol “https:” not supported. Expected “http:”
18:39:46.155: SnapShot error (192.168.0.36 (Ch6)): Protocol “https:” not supported. Expected “http:”
18:39:46.166: SnapShot error (192.168.0.36 (Ch6)): Protocol “https:” not supported. Expected “http:”
18:39:46.167: Fetch NOW error (192.168.0.36 (Ch6)): ERR_INVALID_PROTOCOL
18:39:46.272: SnapShot error (192.168.0.36 (Ch6)): Protocol “https:” not supported. Expected “http:”
18:39:46.283: SnapShot error (192.168.0.36 (Ch6)): Protocol “https:” not supported. Expected “http:”
18:39:46.298: SnapShot error (192.168.0.36 (Ch6)): Protocol “https:” not supported. Expected “http:”
18:39:46.300: Fetch NOW error (192.168.0.36 (Ch6)): ERR_INVALID_PROTOCOL
18:39:52.273: SnapShot error (192.168.0.36 (Ch6)): Protocol “https:” not supported. Expected “http:”
18:39:52.282: SnapShot error (192.168.0.36 (Ch6)): Protocol “https:” not supported. Expected “http:”
18:39:52.294: SnapShot error (192.168.0.36 (Ch6)): Protocol “https:” not supported. Expected “http:”
18:39:52.299: SnapShot error (192.168.0.36 (Ch6)): Protocol “https:” not supported. Expected “http:”
18:39:52.312: SnapShot error (192.168.0.36 (Ch6)): Protocol “https:” not supported. Expected “http:”
18:39:52.314: Fetch NOW error (192.168.0.36 (Ch6)): ERR_INVALID_PROTOCOL
18:39:52.319: SnapShot error (192.168.0.36 (Ch6)): Protocol “https:” not supported. Expected “http:”
18:39:52.321: Fetch NOW error (192.168.0.36 (Ch6)): ERR_INVALID_PROTOCOL
18:40:23.635: SnapShot error (192.168.0.36 (Ch6)): Protocol “https:” not supported. Expected “http:”
18:40:23.641: SnapShot error (192.168.0.36 (Ch6)): Protocol “https:” not supported. Expected “http:”
18:40:23.660: SnapShot error (192.168.0.36 (Ch6)): Protocol “https:” not supported. Expected “http:”
18:40:23.666: SnapShot error (192.168.0.36 (Ch6)): Protocol “https:” not supported. Expected “http:”
18:40:23.677: SnapShot error (192.168.0.36 (Ch6)): Protocol “https:” not supported. Expected “http:”
18:40:23.679: Fetch NOW error (192.168.0.36 (Ch6)): ERR_INVALID_PROTOCOL
18:40:23.684: SnapShot error (192.168.0.36 (Ch6)): Protocol “https:” not supported. Expected “http:”
18:40:23.688: Fetch NOW error (192.168.0.36 (Ch6)): ERR_INVALID_PROTOCOL
18:41:7.635: SnapShot error (192.168.0.36 (Ch5)): Protocol “https:” not supported. Expected “http:”
18:41:7.646: SnapShot error (192.168.0.36 (Ch5)): Protocol “https:” not supported. Expected “http:”
18:41:7.667: SnapShot error (192.168.0.36 (Ch5)): Protocol “https:” not supported. Expected “http:”
18:41:7.675: SnapShot error (192.168.0.36 (Ch5)): Protocol “https:” not supported. Expected “http:”
18:41:7.695: SnapShot error (192.168.0.36 (Ch5)): Protocol “https:” not supported. Expected “http:”
18:41:7.699: Fetch NOW error (192.168.0.36 (Ch5)): ERR_INVALID_PROTOCOL
18:41:7.706: SnapShot error (192.168.0.36 (Ch5)): Protocol “https:” not supported. Expected “http:”
18:41:7.709: Fetch NOW error (192.168.0.36 (Ch5)): ERR_INVALID_PROTOCOL
18:41:9.831: SnapShot error (192.168.0.36 (Ch5)): Protocol “https:” not supported. Expected “http:”
18:41:9.837: SnapShot error (192.168.0.36 (Ch5)): Protocol “https:” not supported. Expected “http:”
18:41:9.852: SnapShot error (192.168.0.36 (Ch5)): Protocol “https:” not supported. Expected “http:”
18:41:9.861: SnapShot error (192.168.0.36 (Ch5)): Protocol “https:” not supported. Expected “http:”
18:41:9.872: SnapShot error (192.168.0.36 (Ch5)): Protocol “https:” not supported. Expected “http:”
18:41:9.874: Fetch NOW error (192.168.0.36 (Ch5)): ERR_INVALID_PROTOCOL
18:41:9.879: SnapShot error (192.168.0.36 (Ch5)): Protocol “https:” not supported. Expected “http:”
18:41:9.883: Fetch NOW error (192.168.0.36 (Ch5)): ERR_INVALID_PROTOCOL
18:41:11.032: SnapShot error (192.168.0.36 (Ch5)): Protocol “https:” not supported. Expected “http:”
18:41:11.038: SnapShot error (192.168.0.36 (Ch5)): Protocol “https:” not supported. Expected “http:”
18:41:11.052: SnapShot error (192.168.0.36 (Ch5)): Protocol “https:” not supported. Expected “http:”
18:41:11.059: SnapShot error (192.168.0.36 (Ch5)): Protocol “https:” not supported. Expected “http:”
18:41:11.073: SnapShot error (192.168.0.36 (Ch5)): Protocol “https:” not supported. Expected “http:”
18:41:11.076: Fetch NOW error (192.168.0.36 (Ch5)): ERR_INVALID_PROTOCOL
18:41:11.082: SnapShot error (192.168.0.36 (Ch5)): Protocol “https:” not supported. Expected “http:”
18:41:11.085: Fetch NOW error (192.168.0.36 (Ch5)): ERR_INVALID_PROTOCOL
18:45:25.790: SnapShot error (192.168.0.36 (Ch3)): Protocol “https:” not supported. Expected “http:”
18:45:25.800: SnapShot error (192.168.0.36 (Ch3)): Protocol “https:” not supported. Expected “http:”
18:45:25.811: SnapShot error (192.168.0.36 (Ch3)): Protocol “https:” not supported. Expected “http:”
18:45:25.813: Fetch NOW error (192.168.0.36 (Ch3)): ERR_INVALID_PROTOCOL
18:45:28.998: SnapShot error (192.168.0.36 (Ch3)): Protocol “https:” not supported. Expected “http:”
18:45:29.009: SnapShot error (192.168.0.36 (Ch3)): Protocol “https:” not supported. Expected “http:”
18:45:29.020: SnapShot error (192.168.0.36 (Ch3)): Protocol “https:” not supported. Expected “http:”
18:45:29.022: Fetch NOW error (192.168.0.36 (Ch3)): ERR_INVALID_PROTOCOL
18:45:31.108: SnapShot error (192.168.0.36 (Ch3)): Protocol “https:” not supported. Expected “http:”
18:45:31.122: SnapShot error (192.168.0.36 (Ch3)): Protocol “https:” not supported. Expected “http:”
18:45:31.138: SnapShot error (192.168.0.36 (Ch3)): Protocol “https:” not supported. Expected “http:”
18:45:31.141: Fetch NOW error (192.168.0.36 (Ch3)): ERR_INVALID_PROTOCOL
18:45:31.860: SnapShot error (192.168.0.36 (Ch3)): Protocol “https:” not supported. Expected “http:”
18:45:31.870: SnapShot error (192.168.0.36 (Ch3)): Protocol “https:” not supported. Expected “http:”
18:45:31.882: SnapShot error (192.168.0.36 (Ch3)): Protocol “https:” not supported. Expected “http:”
18:45:31.884: Fetch NOW error (192.168.0.36 (Ch3)): ERR_INVALID_PROTOCOL
18:45:32.630: SnapShot error (192.168.0.36 (Ch3)): Protocol “https:” not supported. Expected “http:”
18:45:32.649: SnapShot error (192.168.0.36 (Ch3)): Protocol “https:” not supported. Expected “http:”
18:45:32.661: SnapShot error (192.168.0.36 (Ch3)): Protocol “https:” not supported. Expected “http:”
18:45:32.663: Fetch NOW error (192.168.0.36 (Ch3)): ERR_INVALID_PROTOCOL
18:56:46.966: Sending log
19:2:5.608: SnapShot error (192.168.0.36 (Ch3)): Protocol “https:” not supported. Expected “http:”
19:2:5.638: SnapShot error (192.168.0.36 (Ch3)): Protocol “https:” not supported. Expected “http:”
19:2:5.669: SnapShot error (192.168.0.36 (Ch3)): Protocol “https:” not supported. Expected “http:”
19:2:5.672: Fetch NOW error (192.168.0.36 (Ch3)): ERR_INVALID_PROTOCOL
19:5:3.323: SnapShot error (192.168.0.36 (Ch7)): Protocol “https:” not supported. Expected “http:”
19:5:3.333: SnapShot error (192.168.0.36 (Ch7)): Protocol “https:” not supported. Expected “http:”
19:5:3.343: SnapShot error (192.168.0.36 (Ch7)): Protocol “https:” not supported. Expected “http:”
19:5:3.348: Fetch MOTION error (192.168.0.36 (Ch7)): {
“ok”: false,
“statusText”: “ERR_INVALID_PROTOCOL”
19:5:3.350: Event SnapShot error (192.168.0.36 (Ch7)): ERR_INVALID_PROTOCOL
19:5:9.178: SnapShot error (192.168.0.36 (Ch8)): Protocol “https:” not supported. Expected “http:”
19:5:9.192: SnapShot error (192.168.0.36 (Ch8)): Protocol “https:” not supported. Expected “http:”
19:5:9.212: SnapShot error (192.168.0.36 (Ch8)): Protocol “https:” not supported. Expected “http:”
19:5:9.215: Fetch MOTION error (192.168.0.36 (Ch8)): {
“ok”: false,
19:5:9.217: Event SnapShot error (192.168.0.36 (Ch8)): ERR_INVALID_PROTOCOL
19:5:9.732: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:5:9.742: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:5:9.753: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:5:9.756: Fetch NOW error (192.168.0.36 (Ch1)): ERR_INVALID_PROTOCOL
19:5:11.052: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:5:11.067: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:5:11.082: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:5:11.085: Fetch NOW error (192.168.0.36 (Ch1)): ERR_INVALID_PROTOCOL
19:5:13.372: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:5:13.390: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:5:13.404: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:5:13.407: Fetch NOW error (192.168.0.36 (Ch1)): ERR_INVALID_PROTOCOL
19:6:41.084: SnapShot error (192.168.0.36 (Ch2)): Protocol “https:” not supported. Expected “http:”
19:6:41.100: SnapShot error (192.168.0.36 (Ch2)): Protocol “https:” not supported. Expected “http:”
19:6:41.121: SnapShot error (192.168.0.36 (Ch2)): Protocol “https:” not supported. Expected “http:”
19:6:41.126: Fetch NOW error (192.168.0.36 (Ch2)): ERR_INVALID_PROTOCOL
19:6:43.631: SnapShot error (192.168.0.36 (Ch2)): Protocol “https:” not supported. Expected “http:”
19:6:43.643: SnapShot error (192.168.0.36 (Ch2)): Protocol “https:” not supported. Expected “http:”
19:6:43.655: SnapShot error (192.168.0.36 (Ch2)): Protocol “https:” not supported. Expected “http:”
19:6:43.657: Fetch NOW error (192.168.0.36 (Ch2)): ERR_INVALID_PROTOCOL
19:7:17.621: SnapShot error (192.168.0.36 (Ch3)): Protocol “https:” not supported. Expected “http:”
19:7:17.644: SnapShot error (192.168.0.36 (Ch3)): Protocol “https:” not supported. Expected “http:”
19:7:17.660: SnapShot error (192.168.0.36 (Ch3)): Protocol “https:” not supported. Expected “http:”
19:7:17.663: Fetch NOW error (192.168.0.36 (Ch3)): ERR_INVALID_PROTOCOL
19:16:11.326: SnapShot error (192.168.0.36 (Ch4)): Protocol “https:” not supported. Expected “http:”
19:16:11.336: SnapShot error (192.168.0.36 (Ch4)): Protocol “https:” not supported. Expected “http:”
19:16:11.355: SnapShot error (192.168.0.36 (Ch4)): Protocol “https:” not supported. Expected “http:”
19:16:11.358: Fetch NOW error (192.168.0.36 (Ch4)): ERR_INVALID_PROTOCOL
19:19:28.186: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:19:28.200: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:19:28.213: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:19:28.217: Fetch NOW error (192.168.0.36 (Ch1)): ERR_INVALID_PROTOCOL
19:19:29.194: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:19:29.211: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:19:29.223: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:19:29.227: Fetch NOW error (192.168.0.36 (Ch1)): ERR_INVALID_PROTOCOL
19:19:31.280: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:19:31.291: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:19:31.302: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:19:31.305: Fetch NOW error (192.168.0.36 (Ch1)): ERR_INVALID_PROTOCOL
19:21:29.420: SnapShot error (192.168.0.37 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:21:29.432: SnapShot error (192.168.0.37 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:21:29.447: SnapShot error (192.168.0.37 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:21:29.450: Fetch NOW error (192.168.0.37 (Ch1)): ERR_INVALID_PROTOCOL
19:21:33.271: SnapShot error (192.168.0.37 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:21:33.289: SnapShot error (192.168.0.37 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:21:33.300: SnapShot error (192.168.0.37 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:21:33.303: Fetch NOW error (192.168.0.37 (Ch1)): ERR_INVALID_PROTOCOL
19:21:58.701: SnapShot error (192.168.0.47 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:21:58.718: SnapShot error (192.168.0.47 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:21:58.729: SnapShot error (192.168.0.47 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:21:58.732: Fetch NOW error (192.168.0.47 (Ch1)): ERR_INVALID_PROTOCOL
19:27:26.756: SnapShot error (192.168.0.47 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:27:26.776: SnapShot error (192.168.0.47 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:27:26.795: SnapShot error (192.168.0.47 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:27:26.798: Fetch NOW error (192.168.0.47 (Ch1)): ERR_INVALID_PROTOCOL
19:27:57.904: SnapShot error (192.168.0.47 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:27:57.931: SnapShot error (192.168.0.47 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:27:57.949: SnapShot error (192.168.0.47 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:27:57.955: Fetch NOW error (192.168.0.47 (Ch1)): ERR_INVALID_PROTOCOL
19:29:23.097: SnapShot error (192.168.0.47 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:29:23.117: SnapShot error (192.168.0.47 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:29:23.132: SnapShot error (192.168.0.47 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:29:23.135: Fetch NOW error (192.168.0.47 (Ch1)): ERR_INVALID_PROTOCOL
19:33:11.811: SnapShot error (192.168.0.47 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:33:11.823: SnapShot error (192.168.0.47 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:33:11.841: SnapShot error (192.168.0.47 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:33:11.847: Fetch NOW error (192.168.0.47 (Ch1)): ERR_INVALID_PROTOCOL
19:34:15.597: Connect to camera error (192.168.0.47 (Ch1)): connect ECONNREFUSED 192.168.0.36:8080
19:34:25.878: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:34:25.888: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:34:25.901: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:34:25.904: Fetch NOW error (192.168.0.36 (Ch1)): ERR_INVALID_PROTOCOL
19:34:47.380: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:34:47.392: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:34:47.417: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:34:47.421: Fetch NOW error (192.168.0.36 (Ch1)): ERR_INVALID_PROTOCOL
19:40:26.374: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:40:26.387: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:40:26.402: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:40:26.405: Fetch NOW error (192.168.0.36 (Ch1)): ERR_INVALID_PROTOCOL
19:40:49.027: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:40:49.040: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:40:49.053: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:40:49.056: Fetch NOW error (192.168.0.36 (Ch1)): ERR_INVALID_PROTOCOL
19:41:9.142: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:41:9.162: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:41:9.173: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
19:41:9.177: Fetch NOW error (192.168.0.36 (Ch1)): ERR_INVALID_PROTOCOL
20:10:49.331: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
20:10:49.350: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
20:10:49.366: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
20:10:49.372: Fetch NOW error (192.168.0.36 (Ch1)): ERR_INVALID_PROTOCOL
20:13:30.349: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
20:13:30.380: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
20:13:30.409: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
20:13:30.417: Fetch NOW error (192.168.0.36 (Ch1)): ERR_INVALID_PROTOCOL
20:13:37.276: SnapShot error (192.168.0.36 (Ch2)): Protocol “https:” not supported. Expected “http:”
20:13:37.287: SnapShot error (192.168.0.36 (Ch2)): Protocol “https:” not supported. Expected “http:”
20:13:37.297: SnapShot error (192.168.0.36 (Ch2)): Protocol “https:” not supported. Expected “http:”
20:13:37.300: Fetch NOW error (192.168.0.36 (Ch2)): ERR_INVALID_PROTOCOL
20:13:47.178: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
20:13:47.190: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
20:13:47.206: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
20:13:47.212: Fetch NOW error (192.168.0.36 (Ch1)): ERR_INVALID_PROTOCOL
20:13:56.321: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
20:13:56.335: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
20:13:56.351: SnapShot error (192.168.0.36 (Ch1)): Protocol “https:” not supported. Expected “http:”
20:13:56.354: Fetch NOW error (192.168.0.36 (Ch1)): ERR_INVALID_PROTOCOL
